Question about Sony Playstation 3 (PS3) Console
Playstation will not turn on .. when I plug it into an outlet it will blink red, I hit the power button and then the light turns to a solid red light .. I hit the power button again and it begins to turn on with a quick blue yellow light and shuts off.. can this be fixes?
    President:
  • 1,139 Answers
Sadly this is what is known as the Yellow Light of Death (YLOD). This indicates a general hardware failure normally due to overheating. When these PS3's were produced Sony decided to use lead free solder. The problem with lead free solder is that it is not as flexible as leaded solder but it is cheaper and more environmentally friendly. When the console gets hot and cools down hairline cracks appear within these solder joints and a good electrical contact cannot be made. This then causes the console to fail. It could be on a number of different components including the CPU, GPU or memory. There is a temporary cure that may or may not work but ultimately the console will need to be repaired professionally or replaced. If it is out of warranty Sony will not replace it but will offer a refurbished unit for around £130. If you look on Youtube for Yellow light of death fix there is a way that you can re-heat the solder joints using a heat gun but if you are not confident taking apart electrical items then this really may not be something you want to try.
I am sorry I cant give you any better news but unfortunately it is a very common problem with the PS3
Hope this helps and thanks for using FixYa
Posted on Oct 27, 2010
PS3 wont power up
try another outlet if the light still will not turn green you will need to contact sony,
if the light does turn green let me know and we will get this fixed
Dec 24, 2011 | Sony Playstation 3 (PS3) Console
I have a steady red light and it won`t turn on
After plugging the AC power cord into the electrical outlet, the power indicator on the PS system will light up in solid red.Press the power button
Feb 13, 2011 | Sony Playstation 3 (PS3) Console
When i hit "print" the
Does the red light blink or stay on sterady?
Issue: The Compact Photo printer power button is blinking red.
Solution: Turn the Compact Photo printer off, then back on again.
"Paper Jam" appears on the digital camera LCD Turn the printer off and disconnect the power cord from the printer. Then reconnect the power cord and power on the printer. If the printer fails to eject the paper, the printer may require service. Contact the Canon Customer Support help desk for assistance.
When you power down I would recommend also unplugging the printer from the power supply (wall outlet). Let it rest 5 - 10 minutes and then plug back in.
The manual says a blinking red power light indicates a problem in the printer, but the only solution provided it to turn off and on.
If there are no paper jams, and no other error messages hoepfully a completr power down will clear the error.
Issue: Printer's power button lights red without the camera's LCD monitor displaying any error message.
There is a malfunction in the printer.
Remove the paper from the paper-handling slot and take up any slack in the ink sheet. Turn the printe's power off and turn it on again.
If none of this helps I would check to see if my driver is current:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/selphy_compact_photo_series/selphy_cp510#DriversAndSoftware
Trust this is helpful. Please vote. :)
Dec 11, 2010 | Canon Selphy CP510 Thermal Photo Printer
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
My ps3 wont turn on
Hi There,
Your Processor needs reflowing (re soldering on the board) as the system over heated, it caused stress on the solder joints underneath.
Sony charge £150 and give a month warranty to repair it.
We charge £60.00 and give a 6 month warranty.
FixMyConsole
Jun 16, 2009 | Sony Playstation 3 (PS3) Console
My ps3 wont turn on
HI, the power supply is unstable or weak. you will need to replace this failing power supply soon. it is damaged.
2Wire 473 router problem
Take the modem and plug it into a GFCI outlet. You can find one in the bathroom or the kitchen.
If the power light comes on solid green and the dsl comes on red then the modem is good. Was it plugged into a power strip by the computer? If so, plug it straight into a wall outlet.
If the power light comes on solid red then the modem has hardware failure. I would contact your ISP and have them replace it if it is still underwarranty.
Mar 23, 2009 | 2wire (1000-400108-001) Router
Sony Playstation 3 (PS3) Console Logo
19 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
