Question about RCA P52926 52" Rear Projection Television
Sorry, here is the original post.
Comment by Nos8, posted on May 12, 2008 We have a RCA D52W26 HDTV. It worked fine one night, then would not turn on the next morning. There is no power. It is 2 years old. Any suggestions?
I guess you see a lot of posts....you must not have noticed the model number in there :) I got confused when you asked for the model number, because I though there was only one. As you can see from the original post we have no power. Any help would be greatly appreciated. My husband just wants to bue a new tv.....but this one is only 2 years old and hardly gets used, so for me it the principal of the stupid thing!!!
  • 3 more comments
  • Nos8 May 12, 2008
    No....there is nothing. Completely dead. Nothing lights on the screen or the power button.
  • Nos8 May 12, 2008
    If it is the fuse.....where would I get a new one? Do you have a part number? I will have my husband check when he gets home. Thank you.
  • Nos8 May 12, 2008
    How do I get to the chassis to check the fuse? Do I take it out of the tv?
  • Nos8 May 13, 2008
    Thank you for your help!!!
  • Affy007 Dec 06, 2008
    I have a RCA D52W6 that has this same problem. The led will flash 3 times slowly then go out but it makes a whistling sound three times at the same time. Do you think it needs a lamp?
  • RCA Master
  • 8,617 Answers
When you press power does the led light at all? That chassis has been plagued with bad flyback causing dead sets sometimes the led will flash 3 times slowly then go out. Other times it will make a soft short hiss. Does your set exhibit any of these signs?
Posted on May 12, 2008
  • 2 more comments
  • Sonny Berry
    Sonny Berry May 12, 2008
    I would check the fuse. it is located on the small narrow board that is farthest into the set on the right side of the chassis. Up towards the front of the set
  • Sonny Berry
    if its the fuse you will see the rating stamped on the end of the fuse. radio shack should have the replacement. Make sure the set is unplugged at least an hour before checking the fuse.
  • Sonny Berry
    No just remove the back cover and you will see the small rectangle board towards the front of the set on the right side you will see the fuse on the board just pull it out of the fuse holder
  • Sonny Berry
    Sonny Berry May 13, 2008
    youre welcome, let me know if you need any further assistance with your TV
How to reset rca d52w26
Hello
Unplug the mains cord from AC mains wall socket, and wait for at least three minutes, and replug it again. that is the only way to reset this set's parameters to its original factory reset conditions.
If this does not help you, its memmory IC shoud be suspected. Replace it with same type and number. Its number is most important to note, when you buy a new one. OK.
Feb 19, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
I need to find a bulb for a D52W26
your model doesnt have a bulb like the DLP projection. Instead you have three CRTs ( picture tubes) one red, one green and one blue. If you respond to this same post with your symptoms I can assist with diagnosis.
Oct 25, 2011 | RCA HD52W56 52" Rear Projection HDTV
Rca d52w26 hdtv, work's fine for fifteen to twenty minutes. then screen fades away go's blank, the sound and channel's still work. help!
Replace the deflection board. You can get a replacement deflection board from www.tvrepairworld.com which also contains instructions on how to remove and replace the board.
Apr 16, 2010 | RCA R52WM24 52" HDTV Projection Television
RCA D52W26- 52 " rear projectio- 3d
try to inspect the convergerce power supply and the convergence output module for cold solder joints around the mos fets...i had seen many of them on the same condition.
Jan 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W26- 52 " rear projectio- 3d colors,,,is convergence issue
um i think your gona meet your maker,,,your solutions are not being tolerated.. listen...to the new maker, he can and will make you learn what manners are!!
Need solution
Appreciate the direct "Ask Me".
Your concern with an RCA D52W26 is when you attempt to turn it on, it powers up as indicated by the LED lights but they then power OFF a few seconds later? or it powers on then you get to see bright line(s) left to right, then the TV powers OFF? or it powers on but only bklinking LED lights? If yes on the last any sequence to the flashing/blinking?
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 28, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Link
I was referring to the links posted by Ekse. If you could send me the info you have, I will point you where the capacitors are.
My email is jah2mil@hotmail.com
Aug 08, 2008 | RCA L32W11 32 in. HD-Ready LCD Television
RCA D52W26 that won't power on.
Yes that would be the model number. What item are you needing assistance with, as I have so many people I am helping that I need you to indicate the problem unless you respond by the origional post. Let me know what you need help with and I will be able to help you I have alot of experience with RCA/Thomson models
May 12, 2008 | RCA P52926 52" Rear Projection Television
RCA D52w26
Your CRT leaked on the board. You will need to replace the seal as well as the board which got leaked on. Can you post a picture of the board and I will post the board number as well as post a link where you can get another boards at.
Apr 14, 2008 | RCA P52926 52" Rear Projection Television
Rca d52w26 makes a long whistle noise
how long? 3 seconds.. does it sound like chirping? is it comeing from back. smell anthing?
Nov 09, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P52926 52" Rear Projection Television Logo
101 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
