Question about Canon PowerShot A620 Digital Camera
Powershot A620 Zoom Lever
The zoom lever on my A620 is loose and looks like the cap is coming off my camera. It doesn't sit flush against the camera any more. Also the button inside the zoom lever that snaps the picture sometimes won't click to take the picture. The button pushes down but it doesn't click.
  • Canon Master
  • 4,738 Answers
Remove your batteries and look inside the battery compartment. Notice that there should be three small phillips screws at the bottom of the compartment. Tighten up all of these screws.
Posted on Jun 04, 2008
Turn on digital zoom
Turn the zoom lever toward the single-tree symbol and hold it until it zooms all the way. Release the lever then turn it toward the single-tree symbol again to engage the digital zoom.
Full details are in the "Zooming in More Closely on Subjects (Digital Zoom)" section beginning on page 60 of the manual.
Jul 16, 2012 | Canon PowerShot SD960 IS Digital Camera
How do I enable samsung tl105's digital zoom?
From the manual:
Optical zoom TELE : Push the Zoom W/T lever to the right to
enlarge the subject.
Digital zoom TELE : Push the Zoom W/T lever to the right again
in optical 4x zoom mode to enable digital
zoom (software tele). Release the Zoom
W/T lever to stop digital zoom (tele). When
the 5X digital zoom reaches its maximum
magnifi cation, it will not enlarge the image
further, even if you push the Zoom W/T
lever.
Jul 18, 2010 | Samsung TL 105 Digital Camera
My Canon PowerShot A620 has a black screen, any ideas on how I can fix this? I can't even take pictures, all of them come out black
My A620 JUST started doing the same exact thing last night. LCD works, lens works... but something possibly wrong w/the shutter so it won't open.. everything black.
Jan 05, 2010 | Canon PowerShot A620 Digital Camera
Zoom will not retract
Dear Grammie,
You have either experienced a lens error or your zoom dial is broken (both usually caused by some sort of impact damage, but which can be spontaneously occuring).
Look for an error message on your camera's LCD screen such as "E18," or "lens error restart camera." If you do not see a lens error but simply cannot retract your zom lens (go into wide angle mode) via the zoom lever then it simply maybe a broken command dial. Either way, however, you will need to have the camera serviced in all likelihood. Call tech support at 1-800-828-4040 M-F from 8 am to 12 midnight EST and Saturdays until 8 pm EST. Hope this helps.
Sincerely,
HeavyDLB
May 22, 2008 | Canon PowerShot A540 Digital Camera
Shuts down while using the zoom lever
see this thread :
http://www.fixya.com/support/t225803-canon_powershot_s3_switches_off_when
Mar 21, 2008 | Canon PowerShot S3 IS Digital Camera
Zoom broke
Solution: Procedure for setting Digital Zoom PowerShot A520
Digital Zoom When the LCD monitor is on, images can be zoomed with the combined optical and digital zoom functions as follows (figures are approximate): 5.7 times, 7.1 times, 8.9 times, 11 times, and 14 times 1. Press the <DISP.> button to turn the LCD monitor on.
2. Turn the shooting mode dial to any Shooting mode except for stitch_assist_icon_a70.gifor movie_icon_a70.gif.
3. In the [ rec_icon.gif(Rec.)] menu, select digital_zoom_icon_a70.gif(Digital Zoom).
digital_zoom_menu.gif 4. Select [On] using the left_arrow.gifor right_arrow.gifbutton and press the <MENU> button.
5. Press the zoom lever toward tele_icon_a70.gifand hold it.
  • The lens will zoom to the maximum optical telephoto setting and stop. Release the lever and press it toward tele_icon_a70.gifagain to further zoom the image digitally.
  • Press the lever toward wide_icon_a70.gifto zoom back out.
digital_zoom_lcd_a70.gif 6. Shoot the image.
  • Shooting procedures are the same as for the auto_mode_icon_a70.gifmode.
  • The digital zoom cannot be used when the LCD monitor is off.
  • images become coarser the more they are digitally zoomed.
  • Since camera shake may become a factor when using the digital zoom, the use of a tripod is recommended.
  • Digital Zoom is disabled when the [Postcard Print Mode] is selected as a image quality setting.
IF this fails, your camera is in need of service.
Dec 30, 2007 | Canon PowerShot A520 Digital Camera
Powershot G6 -- Zoom button stuck
Does it display any of these messages
Dec 15, 2007 | Canon PowerShot G6 Digital Camera
Zoom will not work at all
If you decide to open your camera, here's a pictorial disassembly. Don't go any further than popping the top off to examine components in the vicinity of the zoom lever. Look for anything different than what's showing in the picture. Usually the zoom lever and switch gets gunked up with dust and debris that can easily be cleaned off. Use the pictures on page 2 of this website as a guide :
http://qman.fotokala.ee/Kaamerad/PowerShotA95/index.html
And keep in mind there's a potential for electrical shock. Read this first before you turn any screws:
http://camerarepair.blogspot.com/2007/11/important-warning-camera-flash.html
Dec 10, 2007 | Canon PowerShot A95 Digital Camera
Blurred pictures with A620
Does it zoom ok? If so the AF motor has got stuck. Same old compact camera zoom lens problem.. buy an SLR.
Dec 05, 2007 | Canon PowerShot A620 Digital Camera
Zoom lever (Olympus Camedia C-8080 Wide Zoom Digital Camera ) does not work
If you can get to the ribbon cable that the zoom lever is attached to, you can use a multimeter or a continuity tester to see if the lever is actually shorting any traces on the ribbon. the zoom lever acts upon a motor that rotates the iner lens barrel, possible the motor lead is open or the switch under the lever is dirty/faulty.
Oct 21, 2007 | Olympus Camedia C-8080 Wide Zoom Digital...
Canon PowerShot A620 Digital Camera Logo
109 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
