I have a Kenmore Elite HE3T washing machine. I just put a load in and pressed the Sanitary button to start the wash and received no response. I then pressed several other buttons, but again received no response till I got to Delicate when it responded. I then unplugged and replugged the machine, but this problem continued. I then unplugged it for several minutes, but the problem continued.
  • josue865 Sep 05, 2010
    The door was closed fine and only the Delicate button worked. I lightly hit the control panel to jiggle it and then all the buttons worked. I started the machine and it's working. It appears that the connection in the control panel is loose or something. Is there anything I can to do address this? Is there a place where I can find out how to take out the control panel and check the fittings? Thanks for your help so far.
  • 5,081 Answers
Unless you have an service manual you cannot know how to take it apart and work over that.
Posted on Sep 06, 2010
  • 2,272 Answers
Does the motor spins when you start any cycle.Also does any kind of error light starts blinking.If there is no response at all when you press the button,and if there is power to the machine ,then the door has to be checked.Is it properly getting closed and is the door latch properly working.If the door is closing properly and latch is functioning then the control panel can be the issue,that has to be checked to resolve the problem.As there is power so power supply is working but no button responding so the control panel board has to be checked and replaced.Remove the control panel and check its connections and check,if its got loose then it has to be refitted also wiggle the control panel connections and check if machine starts responding to the function. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 05, 2010
Kenmore he3t door locked cant reset or open
Kenmore HE3t sanitary cycle setting has changed. Water temp selection only allows Hot/Cold selection but should offer the Extra Hot selection. All other settings test out properly. Is there a way to reset factory settings for cycles?
Jul 08, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Need a manual for my kenmore elite he3t front load washer
My Kenmore Elite HE3 has been great for many years, and now I have a little problem for the first time.
I can usually press cancel to change the program. This morning, after I selected one program and press cancel, it won't cancel. Lights just blinked. So, I press Start to wash with selected program, but it won't start. It won't start nor cancel no matter what I do.
Should I unplug the unit?
Thank you so much!
Apr 03, 2009 | Kenmore Washing Machines
Kenmore Elite front-load
you must remove bottom panel ,,in the center front you will find pump,,remove pump filter,,always unplug first..it has slugg,..than after you clean filter run your unit once a month with a pint of bleach and hot water only..also wipe your rubber gasket or bellows with a touch of bleach..
Dec 27, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite He3t front load washer - error code reads H & F
the F code is a puwer outige. This is how to fix
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
This is what an HF code is.
"FH" (Water Inlet Problem--no water or insufficient water
supply)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer clogged?
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Plug in washer or reconnect power. Re-select cycle and press
START. If the problem remains, call for service.
Dec 15, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3t Model#11044932200
How long is long? I have to hold the button down for about 5 seconds and I think that is to keep from accidentally turning the machine on . If it is longer than 5 seconds then maybe something IS wrong.
Sep 14, 2008 | Kenmore Elite 45986 Front Load Washer
Kernmore elite He3t
Well there is one of two control boards that is malfunctioning, most common is the Machine (or Main) control board, there is also a display pc board in the control panel, but i have had few problems with that control. Unfortunately the main board is $300.
Sep 04, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3t control panel locked
you must press and hold a button it should show it on the control panel something like press/hold to lock unlock
Mar 12, 2007 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
