Question about Sony PCV-RX770 (T99860944) PC Desktop
RX-770 Crash My RX-770 computer crashed and I need to rebuild the hard drive. When I try to use the Sony System Restore disks that I have, I get a message that they are not the correct System Restore disks. How do I get around this or do I need a new set of disks? I'm using the ones that came with the computer.
  • rowalton May 12, 2008
    Problem Solver:
  • 15 Answers
What you need to do it to reinstall windows by finding your windows cd it might be windows xp
seup cd if the prodict key is on your computer you need a windows oem cd or windows xp oem you can make your own by geting the windows xp cd and making an iso image of the cd and go to thei386 file and open the document setupp and in the las line change the last three digits into oem
and save the file and burn the iso image with an iso image burning program to a cd and boot the computer with the cd and follow the instructions
Posted on Jan 17, 2009
Got a problem with my hard drive. I got my hard disk partitioned a while ago. Its 180GB. There are no heavy files on the drive but it keeps popping up the message of low disk space. When i checked the...
Most likely to be either the waste basket not being emptied for a user, or it could be the system restore where old restore points exist. In windows explorer, right click the disk and select 'disk cleanup' Give that a go.
Dec 26, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Tip
How to repair hard drive
<span>Instructions</span> Things You'll Need: <ul> <li> <span>Operating software installation or build CD</span> </li> <li> <span>Boot-up disc</span> </li> <li> <span>System restore CD</span> </li> <li> <span>Backup tape</span> </li></ul> <ol> <li> Look for tell-tale signs that your computer is about to crash or fail. Extreme slowness, repeated blue screen and noise or clicking are sometimes signs that your computer hard drive is about to crash. When you hear the sound of clicking, scraping or grinding, immediately turn off or shut down your computer. Doing so will prevent any loss of data.<br /> </li> <li> Power down and then power up. Sometimes, hard drive crashes can be easily recovered by doing a power shutdown of the computer. Then, after waiting for a couple of minutes, power it back up again. The initial hard drive crash may not be too serious, but if it happens often, start performing a full system backup, if you haven't been doing so, to be able to recover your data should the inevitable happen.<br /> </li> <li> <span> <a><img src="repair-hard-drive-crashes-1.3-120X120.jpg" /></a> jQuery(document).ready(function(){ jQuery('#jsArticleStep3 span.image a:first').attr('href','http://i.ehow.com/images/a04/8f/3a/repair-hard-drive-crashes-1.3-800X800.jpg'); }); PC cable or component connection </span> Ensure that your hard drive and other internal components are seated properly. If Steps 1 and 2 do not work, you may need to open your computer's CPU to check on some of the drive connections. Sometimes connections get dislodged, especially if you move your computer box often. The symptom will manifest as if the hard drive has crashed, giving you a "disk error" when you try to boot up your computer. First, turn off your computer and unplug it. Then remove the case of your computer box. Press on each connector to connect it properly. Put the cover back again, plug the computer and power it back up.<br /> </li> <li> <span> <a><img src="repair-hard-drive-crashes-1.4-120X120.jpg" /></a> jQuery(document).ready(function(){ jQuery('#jsArticleStep4 span.image a:first').attr('href','http://i.ehow.com/images/a04/8f/3a/repair-hard-drive-crashes-1.4-800X800.jpg'); }); Boot from CD drive with a boot disc </span> Insert your boot disc and try to boot up your computer using the disc. Once you are able to do so, you can reinstall your operating system. After installing your software, proceed to perform data recovery using your ghost CD or backup.<br /> </li> <li> Use an emergency repair disc to get your computer to work again. Then restore from the last known good configuration.<br /> </li> <li> Reinstall your operating system using the installation or system restore CD that came with your computer when you first purchased it. It will take you through a series of steps that include formatting your hard drive, which will then erase your data. Do this as a last resort.<br /> </li> <li> Recover your data by using a restore and recovery software or using your most recent backup after you have reinstalled the operating system in the previous step.<br /> </li> <li> Reinstall your applications that did not come with your computer when you bought it. Some examples would be Adobe Photoshop, anti-virus software and movie-making software.<br /> </li></ol> jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); <span>Tips & Warnings</span> <ul> <li> Call technical support if you are unsure of what to do. They can walk you through the important steps. You can also take your computer to a PC technician who, for a fee, will do a system restore and data recovery for you.</li> <li> Make it a habit, even if your computer is healthy, to do a complete backup so your important data will not be lost.</li> <li> Never attempt to open your computer without first powering it off to avoid being electrocuted.</li> <li> Do not open your hard drive case; the components are so sensitive that even a single speck of dust may erase your data.</li></ul>
on Dec 23, 2010 | Computers & Internet
Dban problem ( crash : "dev/sda" )
Use fdisk and / or format from command prompt. Easy and no fuss. gl
Nov 03, 2012 | Computers & Internet
Hard drive crash. Need Systen disks to restore
you can re install and format your drive directly. just boot on cd with your os and select bootmenu choose cdrom. and follow instruction
Jun 02, 2011 | Acer Computers & Internet
Computer crash. Have No recovery disk.
Hi jgar2141,
If you are trying to restore the Computer to the factory settings, it is not required to have the Recovery Discs as you can use the Recovery Partition which is present in the hidden partition of the Hard Drive. To access the Recovery Partition, restart the Computer, press and hold the F10 Key for 7 to 10 seconds. This will boot the Computer to the Edit Boot Options screen. There, please press the Enter Key.This will launch the VAIO Recovery Center. In the VAIO Recovery Center window, you can select the "Restore C: Drive" option to restore the Computer to the factory settings. (Selecting the "Restore C: Drive" option will erase all the Data in the Computer and restore to the factory defaults)
After selecting the Restore C: Drive, please follow the simple onscreen instructions to proceed with the System Recovery. The System Recovery process using the VAIO Recovery Center should fix all the Software issues in the Computer and restore the Computer to the factory defaults.
Good Luck!
Please post back if you have any questions or require any further assistance.
Thanks for using FixYa.
Nov 10, 2010 | Sony VAIO VGN-CR507E/PC Laptop
My ps3 istrying to rebuild database after my dad ripped out of the wall while playing a game. It is not processing and the hard drive will not restore
Guest
Unfortantly it sounds like something happened to the hard drive. Hopefully you just got corrupted data on the hard drive. However depending what you were doing when the system was moved the hard drive may have had a hard crash. Note the hard drive in the system is a notebook drive so it is more resistant to this but it can still happen. The link below will help you address the corrupted hard drive issue. If you still have trouble then you will need to replace the hard drive.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Jul 12, 2010 | Sony Playstation 3 (PS3) Console
Laptop crash after inserting blank disk
do not worry at all. take out the cd and reboot in safe mode by pressing F8 at bootup. Then you can restore your laptop to an earlier date from Start->All progs->Accessories->System->restore. reboot normal this time.
Oct 04, 2009 | HP Computers & Internet
What happen if computer hard disk overload
your hard drive would eventualy crash and seeing that the drive is overloaded there wouldn't be sufficient space left for System Restore to run as it needs a fair amount of space to run. My advice is to always keep about 10% of your HDD size open for System Restore to run properly in case of a HDD crash or system crash.
Apr 21, 2009 | Microsoft Windows XP Professional
Need system restoration
You can restore your computer to an earlier date by using system restore. click-start-all programs-accesories-system tools-system restore. Than follow directions.
Dec 28, 2008 | Averatec AV4155-EH1 PC Notebook
Computer problem, help.
This generally indicates a hard drive crash/failure, in which the hard drive will need to be replaced. Rare, but occasionally you will get this error from an operating system glitch. Before you run out and buy a new hard drive, try reloading the operating system. If you have any problems during or after the install, then the hard drive is shot.
Jul 01, 2008 | Sony VAIO FRV25 Notebook
Sony PCV-RX770 (T99860944) PC Desktop Logo
106 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
