Question about Refrigerators
The fridge shut off and tripped the breaker, tried to reset breaker and it tripped again. I unplugged fridge, breaker was able to reset, voltage good at outlet, ohmed out fridge plug, appears to have a direct short. What do I look for to repair.
  • 61 Answers
Could be anything, bad cord or plug, possible bad appliance bulb causing short (had that happen on another appliance) or the main problem, bad compressor.
Posted on Sep 05, 2010
Fisher & paykel fridge e521t no power to fridge,not any power coming to fridge
Did you try an other electrical outlet? Can you test the outlet has any voltage?
does the fridge have an on / off switch? I don't think so, so if nothing works also check the cable and the plug going in the outlet.
Mar 17, 2015 | Fisher & Paykel Paykel E521TLX2 Fisher...
No power to the display, dryer will not turn on
First thing you need to do is check the Circuit Breaker for the dryer. If it is tripped unplug the dryer and reset the Circuit Breaker. Now plug in the dryer and try to run it. If it does not work again check the Circuit Breaker again if it is tripped again unplug dryer and call someone that can help you or fix it. If the Circuit Breaker is not tripped check for good power readings on both power lines coming into the dryer. Should have 110V or more on each line to neutral, and 220V or more between each line. If you do not have the correct voltage at each line check Circuit Breaker for good power coming out.
Mar 13, 2014 | Maytag MDE9700AYW Neptune 174 Electric...
Kenmore elite 10654606300 won't turn on
Do you have power at the outlet? If you do, your breaker trip as soon as you plug the unit in? If you have power to the unit and your breaker is not tripping, inspect the wires from the power cord to make sure rodents have not chewed the wires. If everything else looks good then you have a bad cntrl board PART NUMBER: 2252116
Mar 25, 2013 | Kenmore Refrigerators
Hi, my fridge freezer keeps making the electric trip out. help!!!
Try this:
Turn your thermostat as warm as it will go, you are trying to isolate the compressor and keep it from turning on. If your fridge has an "off" position, then turn it off. Reset breaker, plug refrigerator back into the outlet. If the fridge trips while "off", then you are likely looking at a damaged cord / wiring.
If the breaker doesn't trip, unplug the fridge, and move the thermostat to the warmest position possible. Plug fridge back in, If the breaker holds, then you are on right track. Slowly move the thermostat to a cooler setting. You want to just reach the point where the compressor tries to start. If breaker holds here, then you are in good shape so far. It indicates a problem with the defrost heater (if equipped), or the ice maker (if equipped). If the breaker trips as soon as the compressor tries to start, your compressor may be damaged (bad and expensive).
Aug 17, 2010 | Refrigerators
Maytag fridge trips circuit breaker
replace the ptc overload relay on the compressor,it merely unplugs,it supplies start and run power to the compressor and if its bad it will allow the compressor to operate on the start windings too,and draw a lot of current
Apr 06, 2010 | Refrigerators
I have a 15 amp single pole circuit breaker that
It could be either or at this point. First thing to do, is unplug all electric devices from the plugs on that circuit, and then attempt to reset the breaker. If it does not trip, one of the devices plugged into a receptacle on that circuit could have a short. If it doesn't trip, plug each device in one at a time to see it it trips the breaker to pin point what is causing the short. If the above has no effect, I recommend replacing the breaker. It is easy and inexpensive to do. Just make sure you main is shut off before doing any work on the panel. I hope this helps and good luck!
Nov 06, 2009 | Connecticut Electric & SWITCH UBIP130...
Breaker was inadvertantly tripped by person which shut dryer off when reset breaker dryer wont work
You have to test the voltage to verify that the breaker did reset. Unplug the dryer, and verify that you have 240 volts at the receptacle
May 31, 2009 | Frigidaire GLER341A Electric Dryer
LER4634J got ''shocked'' and now won't operate
First, test voltage to be sure your are getting 240v into the machine. Sometimes there are to 120v breakers in the breaker box that have to be reset. Check to be sure yours are fully reset.
Nov 23, 2008 | Whirlpool LER4634J Electric Dryer
Refrigerators Logo
186 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
