Question about Fire Stone CNE20 Electric Grill
Were can I purchase a grill side heating element with installation instructions for a Fire Stone Legacy 20i/e electric grill ?
I have heat-n-glo BBQ built in that doesn't seem to get over 275 degrees model pge-36-s3
I assume that you know you must keep the hood closed whn cooking with this grill since it cooks by convection. It also requires good airflow from the back of the hood to set up the convection flow.
May 20, 2014 | Fire Stone Legacy 36i (LP)
Manual
Get the pdf online at http://www.outdoorrooms.com/uploads/global_pdfs/Grill-Islands/legacy_grill_manual.pdf
Jun 27, 2013 | Fire Stone Legacy 36i (LP)
Grill not working after replacement element - any ideas?
I would say you are right on your wondering. look at your manuel and it will show you a diagram
May 07, 2012 | Zanussi ZHQ575 Electric Double Oven
I have the Fire Strone Legacy 361 and the electornic ignition does not work. How do I fix it or how can I get a new one. Thanks
Before investing money ... have you changed the battery in the ignitor button? If so, one of the most repeated mistakes grill users make is inserting the battery in the wrong direction. Generally, the + end of the battery should be up, facing you. If that's not the case, then the ignitor will not work. Also, make sure that there is no corrosion inside the battery holder. If there is, clean it out using a Q Tip and WD 40. It also helps to check the wiring of the ignitor , by tracing all the wires to make sure they are firmly connected. And that the spark ignitor for every burner is clean and free of grease.
if after all the above, you find you need to replace the ignitor, you can order one directly from the manufacturer or from the dealer/retailer you purchased it from.
Hope this helps you solve your problem and Happy Grilling!!
Mar 17, 2011 | Fire Stone Legacy 36i (LP)
Ineed the searing plates for the 36i
Here is the number you want to call for this stove.
They will have it. Let me know how it works out for you.
Contact Customer Service
(888) 837 5311.
Have a great day!
Benjamin
Dec 28, 2010 | Fire Stone Legacy 36i (LP)
The cooker stays warm when mains cooker switch is on.
Either teh grill element or the oven heating element is fault or the thermostat or grill regulator, locate which element is warm, if the grill then it is most likely the regulator, if it is the oven it is the thermostat. Engineer
Jul 20, 2007 | Stoves 800DFDOm Dual Fuel (Electric and...
George foeman GF20G grill/griddle
The part your looking for is going to cost you 19.00 + shipping . Total at around 30.bucks. It does not pay to fix this unit. Here is an article about these grills. Crucial product component is defined as a component that will prevent proper functioning of the entire product even though it is the only malfunctioning component. Analysis of the George Forman Grill found that there are three crucial components. The first crucial component of the product is the thermal switch. The thermal switch is a heat-regulating device that acts as a type of circuit breaker. When the grill is turned on, the temperature of the grill is room temperature and the thermal switch will allow electricity to flow through. Once the heating elements heat the grill up to a certain temperature, the switch is triggered and stops the flow of electricity, thus cooling the grilling surface. Once the temperature cools to a predetermined temperature, the thermal switch will no longer be triggered and will reopen the circuit and continue the heating process. The second and third crucial parts are the upper and lower heating elements. If one of these heating elements fails, only one part of the grill will heat and it will not allow for proper functioning of the grill, which is supposed to cook on both sides at time. Could and would the three critical components be replaced or repaired if malfunctioning is another important factor in determining the overall products serviceability. A product is made up of many components and the method used to connect all of these individual parts answers the question of could a part be replace. If a part is welded to another piece or if other components have to be broken in order to remove the malfunctioning component then that part cannot be replaced and the question of would it be replaced does not need to be address. If it is determined that a part physically could be replaced, the next question addressed is would it be replaced. The cost of the individual component verses the entire product cost, the time it takes to replace the component, and many other factors are addressed to determine if a product would be replaced. The overall cost of the George Forman Grill studied is under $60. To purchase an individual thermal switch to repair the grill with would not be a cost effective choice because they sell for approximately $15 to $20. To remove either heating element from the heating plate, the plate needs to be damaged. The heating elements will wear out but typically not until long after the thermal switch malfunctions. Considering both of these factors, the heating elements would not be replaced and if both were to fail, it would mark the product end of life. I have seen these grills/griddles for as low as 49.95
Sep 22, 2006 | George Foreman GF20G Indoor Grill
Fire Stone CNE20 Electric Grill Logo
Top Fire Stone Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Fire Stone Grilling Expert? Answer questions, earn points and help others
