Question about JBL On Stage Speaker Dock for Apple iPod and iPhone - Black/Silver
Power cable on back of speaker station has broken - every time you move the wire it tries to connect but just crackles instead - so no sound. Where can I get a replacement power plug JBL on stage 11 model no. MV18-4180080-82
3 Suggested Answers
SOURCE: will the jbl on stage micro charge the new ipod touch
I can tell you that I have the on stage micro, bought this past winter. And it does charge my iPhone 3G. Works great, I love it.
Posted on Jun 19, 2009
  • 3 Answers
SOURCE: JBL on stage II speaker doesn't work
If your 120v unit is not marked for use with 220-240v and you plugged it into such a socket (even once), you probably fried the AC adapter and will need to get a replacement.
Posted on Sep 26, 2009
Ac adaptor crackling thru external speakers
Allan, It sounds like you have what is called a ground loop. A ground loop can occur when two pieces of equipment are connected together through a home or buildings safety ground through the same power source. For instance, your PC is connected to a power source through the AC adapter or plug, and your external powered speakers are receiving power from the same power source. The surrounding cables as well as the AC adapter(s) can act like an antenna. This will cause a low hum or crackling that would be audible through the speakers or headphones.
You may want to try plugging all components into a power strip so they are all on the same circuit. You may also want to be sure that the AC adapter cables are not not laying or running across other electrical components plugged into a different socket.
If you get the same hum through your headphones check to see if the headphones were manufactured with shielded cabling. A shielded cable is made with a wire mesh around the outside that helps reduce electrical noise. Hope this helps a little. Thanks!
Aug 31, 2012 | HP Pavilion dv6000z Notebook
The sound on my Dell W4200 is crackling some times even when the sound is on mute. Sometimes the sound is fine, other times no sound and other times the crackling noise. Any idea what problem may be?
Hi There,
Crackling sound is often an indication of bad connections to the speakers. Are you listening with the built-in speakers or through an external amplifier?
If you are listening through an external amplifier or speakers, check all of the connections to make sure the cables are properly inserted, and wiggle the cables from each end and the middle to see if that reproduces the symptoms. Sometimes a cable can become damaged from being squashed or bent, and it may be as simple as replacing the faulty cable with a new one.
If you are listening with the built-in speakers the situation might be harder to identify and correct. Sometimes it is as simple as nearby wireless devices or radio towers causing interference with the speaker. You can try repositioning wireless devices such as computer routers, cordless landline phones or radios to see if that helps.
However, over time the solder used to connect the internal components can wear and sometimes break the connection. For this type of situation repair is usually the only option. If the warranty of your TV has expired you may have to take it to a local TV service center. Typically a loose solder joint is easy to identify and fix, so the repair bill should not be high.
Please post back with your results.
May 26, 2011 | Dell W4200 42 in. HD-Ready Plasma...
I have a problem with the tweeter sound in one of my VR975 Boston speakers. The highs seem to come and go. It is definitely limited to one of the speakers because I can switch cable connections in the...
Register and download the manual for free at retrevo.com'
http://www.retrevo.com/support/Boston-Acoustics-VR965-Speakers-manual/id/522dj380/t/2/
A loose or intermittent cable contact on the OUTSIDE would affect ALL speaker output, not just the high frequencies, and it would probably produce speaker-threatening crackles.
That loose tweeter connection the other guys found isn't fixed. Go back and make them fix it right.
What are your present speaker connection ends if NOT bare wire?
Feb 19, 2011 | Boston Acoustics VR965 Speaker
M-audio av20 right speaker has no sound coming out of it at all...
To troubleshoot the problem start with the bit that is working - the left speaker.
  1. Unplug the input leads on the back of the left speaker and swap them round.
  2. If sound now comes out of right speaker and not the left the problem is with your sound source (computer, IPOD or whatever) or the connecting cable is faulty.
  3. If there is still no sound from the right speaker try turning the volume control knob up and down quickly several times - does this produce any sound from the right speaker? Sometimes the electrical contacts get dirty and this can help clean them.
  4. Turn the speakers off using the volume control knob. Disconnect the speaker wire for the right speaker from the OUTPUT on the left speaker (push the red and black tabs downwards and gently pull the wires out. Find a small 1.5 volt battery (an AA or AAA size will do nicely) and touch the bare ends of the speaker wire briefly on the battery terminals. If you hear a slight crackling sound the wire and the speaker are okay and the problem is in the amplifier, which will need repair or replacement - not a job for an amateur.
  5. If you don't get any sound from the battery test find another piece of speaker wire (any piece of 2 core cable with bare ends will do for testing) and repeat the battery test. If you get sound then replace the speaker wire. If not remove the speaker wire again and go to next step.
  6. Lay the speaker face downwards and carefully unscrew the back panel (don't do this if it is still under manufacturers warranty - take it back for repair or replacement). Lift the back panel off carefully and slowly taking care not to pull the connecting wires inside the cabinet, which will probably be quite short. You may have to settle for just rotating the back panel slightly so that you can see inside if the wires are too short to do otherwise.
  7. Use sticky tape to tightly attach the bare ends of the speaker wires to the terminals of the battery. Touch the loose ends of the speaker wires on the two metal terminals where the internal wires are joined onto the back of the big loudspeaker cone. If this produces a crackling sound it is the internal wiring in the cabinet that needs re-soldering. Otherwise the loudspeaker unit has failed and will need replacement.
Jan 29, 2011 | M-Audio Avid Maudio 99005226600...
Crackling sound
The crackling could be due to a faulty wire or jack connection. If you have any other sound device (e.g. headphones), try connecting that one instead of the Z4 and see whether the crackling disappears (in which case it's the Z4) or not (in which case it's the jack or the computer). Could arguably be an EM or electrical interference, but you'd need a laptop running on batteries to check the second, and trying orienting differently the speakers to try checking the first.
The music slowing down means something's wrong in the computer: the Z4 are purely passive, they can't do anything to the music tempo. Try running an antivirus check or try Task Manager (or Process Explorer) and see whether anything's eating more CPU than it should.
Mar 28, 2010 | Logitech Z4 Speakers
Crackling noise coming from 1 channel
sounds like you are picking up some interference first try swapping out the RCA cables you are using to connect that component. also keep your RCA cables away from any 110V AC power lines.
same thing with speaker cables, speaker wire should intersect power lines at 90 degrees and should not run parallel to power lines.
many people use the wires that come with their components. these cables are thin and offer very low performance a thicker higher quality cable with a gold connector will not only better maintain the quality of the signal being transferred between components but will also have better shielding to protect the cable from picking up interference from other electrical components and power lines.
Also should point out that a blown speaker sometimes produces a crackling sound, swap your left / right speakers and see if the crackling sound still comes from that speaker if it does you have a blown / damaged component.
Dec 30, 2009 | Onkyo Audio Players & Recorders
Car audio issue
You should probably take out the stereo and check the cable connections. If it has been taken out recently and put back in wrong a wire might have been pinched blocking power going to speaker or the wire is shorting out.You might just even have a cable that got burned up somehow. Mike.
Sep 19, 2009 | 2004 Nissan Altima
Crackling and popping sounds in surround sound speakers
Could be your head unit or the connection to the speaker may be bad. Also if the wire to the speakers in your ceiling is bare and touching any ground it would interfere. Start by checking connections by playing something and messing with wires. Listen for a difference. Next check by putting the wires that power those speakers in a known working output and listen for different quality
Apr 04, 2017 | SpeakerCraft 8" 150W In-Ceiling Speaker...
Only one speaker working
Even I have faced the same problem for the past six months.. Today i have fixed only issue with the back jack.. removed slowly and fixed it tightly.. it's works. :)
Oct 06, 2007 | Harman Kardon HK206 Computer Speakers
JBL On Stage Speaker Dock for Apple iPod and iPhone - Black/Silver Logo
105 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
