Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Frigidarie fridge I'm trying to clean the coil of my freezer on top fridge on bottom Frigidaire refrigerator and I dont' know where it is. Can you help? I have the thing pulled out... Thanks
The refrigerator is getting a lot of water in the meat department, the crisper and in the bottom of the refrigerator what is this problem
Posted on Jan 03, 2009
  • 828 Answers
Coils location is in one of three places;
1. under the refrigerator compartment in the back, must remove fiber panel to access. If this is yours be sure to replace the panel after cleaning.
2, Black grill on back of refrigerator about 1.5" stand-off from back.
3 built into the outer walls of the refrigerator, Not accessible, provide air clearance for free air circulation around unit.
Posted on May 12, 2008
I have a frigidarie and water is flooding the bottom of the veggie drawer, no where else is containing water
I AM ALSO HAVING THIS PROBLEM. i HAVE LOOKED IN THE BACK FOR SOMETHING TO REMOVE AND CLEAN BUT EVERYTHING SEEMS VERY TIGHTLY ATTACHED.
Mar 17, 2011 | Frigidaire FRT21H8 Top Freezer...
Refrigerator doesn't stay cool enough
Sometimes it is just a matter of excess dirt and dust build up on your coils. Take the bottom toe- kick louver off your fridge and try to clean off your coils. Use a very small hosed wet-vac and a long neck feather duster to reach in and clean as best as you can. If this does not seem to help within a couple hours you may want to try a manual defrost. Reply back to this post and let me know.
Nov 30, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
Fridge & freezer are cooling on bottom but not
when you open the freezer door do you hear the fan blowing?sounds like the air isn't moving,there's also a damper on the fridge side,the door opens to let the cold air in and then closes,make sure the door is opening,you can take the cover off and put an ice cube on the twirled up metal part to close it and put your hand on it to open it to see if it's working
Mar 21, 2010 | Frigidaire FRS26H5AS Side by Side...
Not giving up on frigidarie
this would appear to be a thermistat control issue.make sure that the doors are closed tight and the seals are in good shape this will also cause long periods of run time.if those thing are good replace the thermistat control.good luck with your fridge let me know hwo things worked out for you.
Jan 21, 2010 | Frigidaire FRT15B3A Top Freezer...
Freezer freezes up and don't know if there is a reset
sounds like the condenser is bad, feel the copper coils they should be cold and the condenser should be hot/
May 20, 2009 | Frigidaire Gallery GLHT214TJ Top Freezer...
Fridge running but not cooling
Sounds like you're low on gas...assuming that the condenser coils are clean.
Nov 20, 2008 | Kenmore 64802 Top Freezer Refrigerator
Side by side frigidaire
check the evaporator fan motor, behind the back wall of the freezer. If that is turning check if the damper is opening, top lt of the refrigerator compartment. I hope this helps you.
Jul 09, 2008 | Frigidaire FRS3R5EMB Side by Side...
Fridge losing coldness
Defrost problem. Either defrost heater, defrost thermostat, or defrost timer is bad.
Sep 05, 2017 | Frigidaire GLRT184RA Top Freezer...
Frigidaire Side-By-Side Top Not Cooling
the unit is loosing the freon supply to the evaporator.you either have a leakage,a blockage or the compressor is not pumping to full capacity.
Nov 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Fridge is hot while freezer works fine
Defrost for 24hrs with doors open, turn back on it will then work ok. Regards Advisor
Aug 18, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
51 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
