Question about Garden
John Deere L120 STOPS MOVING AFTER THE TRANSMISSION GETS HOT
  • 18 Answers
SOURCE: blades will not ingage
is it electronic engage or manually?
Posted on Sep 03, 2008
SOURCE: John Deere L120 transmission high pitch noise and no forward move
Try jacking the unit up. Start it up and try moving pushing the forward and reverse back and forth and see if it does it then. It sounds like an oil way in the hydrostatic unit has a check valve stuck. Of course make sure that the fluid lever is up. Hope this will help you. donnyb60
Posted on Mar 23, 2009
SOURCE: replace blades on a john deere L120 mower deck
First make sure you have the tools, metric that is. The deck must be removed and turned over. To do this you must put the deck in the lowest position. Using a 15mm socket pull the belt tension spring pulley forward to detach from clutch. Next remove retaining pins located at the five deck brackets. This will allow the arms to slide off and the deck can be dragged out from under the mower. Turn deck over. Use a 18 inch 2x4 to block blades while removing the two 15mm bolts. The bolt heads will need to be cleaned so the socket can seat on bolt head. I use my torque wrench to get more leverage and i can use it to reset blade bolts to 64 ft lbs. While blades are of it is a god time to thoroughly clean underside of deck.
Posted on May 25, 2009
jyackle5
  • 8197 Answers
SOURCE: I need a routing diagram for belt routing on L120
For belt routing please go to link below.
http://manuals.deere.com/cceomview/OMGX21647_K3/Output/Index.html?tM=HO
Good Luck and please rate 4 thumbs up for free answer
Posted on Jun 13, 2010
John Deere L120 gets hot and shuts down after mowing for short time
remove the top cover and see if there is a nest or grass build up on top of the fins or are you loosing spark when it gets hot then remove the cover and check the coil
Apr 11, 2012 | John Deere Garden
I have a John Deere L120 tractor with a hydrostatic transmission which after a half an hour of mowing struggles to go in reverse and seems to loose power when moving forward without stressing the motot. I...
Hi, your problem is caused by the transmission over heating. Remove the battery and battery carrier and clean all grass and debris from the hydro cooling fins and fan. Hope this is helpful, regards Phil.
Sep 08, 2011 | John Deere 22HP VTwin 48" Riding Mower
My johnb deere L120 engine runs fine, but after about 20 minutes the tractor slowly stops moving, i dont know if this is a drive belt problem or something wrong with the hydrostatic?
Hi, most likely the hydrostatic is over heating. Remove the battery and battery carrier. From here clean any grass and debris from the hydro and cooling fins, also check the cooling fan condition. Under the mower check the idler pulley on the hydro drive belt is travelling freely. Hope this helps, regards Phil.
May 08, 2011 | John Deere Garden
Problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Jul 25, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Drive-train failure -- John Deere L120 Automatic -- don't have an owner's manual -- could this be a diy fix?
my L120 does not want to pull itself up a grade or hill but will still go on level ground
May 29, 2010 | John Deere Garden
John deere L120 riding mower with IntekV twin 22hp
Try replacing the gas in the fuel system. The manufacturers are telling us that gas over 30 days is considered bad gas.
Good day.
Nov 02, 2009 | John Deere Garden
Mar 23, 2009 | Garden
John Deer riding mower
http://www.deere.com/specsapp/CustomerSpecificationServlet?sbu=CCE&pciModel=L120%20GX&displayModelName=L120%20Lawn%20Tractor&tM=HO&pNbr=SKU20346
Here is a link to John Deere website for this model, it states that it has a 16 amp charging system. It also has the phone numbers listed for contact, and requesting the manuals for this mower.
Sep 18, 2008 | Garden
Garden Logo
141 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
