Question about Motorola Mobility Blnc Bluetooth Car Kit Portfolio Ihf1000
How do we reset the password for the Motorola IHF1000 car kit?
Volvo bluetooth handsfree
What do you need help with?
Mark
Motorola Support
May 07, 2014 | Motorola Mobility Blnc Bluetooth Car Kit...
Can't answer calls using IHF1000 when paired with my iPhone. Green button just hangs phone up..
Press the big blue button in the middle. It will take the call but you have to wait a couple of seconds. Don't answer the call with the phone though as it will not transfer to bluetooth (it's a sort of privacy option)
Dec 04, 2009 | Motorola Mobility Blnc Bluetooth Car Kit...
Need to delete paired phones from Motorola IHF1000 car kit
Hit the talk button. Say Setup Menu. Then Say Remove Phone (phone # you want to remove). Alternately, say "remove all phones", then re-pair just the ones you want.
Manual : http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/US-EN/User_Guide.pdf
Jul 14, 2009 | Motorola Mobility Blnc Bluetooth Car Kit...
What to do
If you are sure that the handsfree system in your truck is an IHF1000, then long pressing ( >2s ) the center "talk" button on the IHF1000 will put the system into pairing mode. Follow the instructions that are spoken from the kit - have your phone scan for handsfree devices then, find the IHF1000, select it, then enter "1234" for the passcode and complete the pairing.
Jun 25, 2009 | Motorola Mobility Blnc Bluetooth Car Kit...
Pairing an "universal" bluetooth to the samsung behold
Do you still have the user manuals for both the phone and the IHF1000? Start by reading the bluetooth pairing sections in both manuals and trying what is listed. If you have already done this, then please detail where you are having difficulty in the pairing process.
Apr 20, 2009 | Motorola Mobility Blnc Bluetooth Car Kit...
People can't hear me on my Blackberry Curve unless I turn the phone and talk loudly right into the speaker. I am so sick of having the "I can't really hear you" conversation! With my bluetooth, I have the...
When using the IHF1000 with your Blackberry Curve, I recommend to go into the device properties for the IHF1000 in the phone's Bluetooth devices listing. Under that, there should be a phone setting to turn Echo Canceller: On, Off, or Automatic. By default, it is Automatic. For this phone with the IHF1000, I would set it to Off. This has solved audio quality problems for a number of people.
Note: this may or may not directly address the low uplink audio level you are experiencing, but it does seem to help with general call audio quality when connected to the IHF1000.
Mar 06, 2009 | Motorola Mobility Blnc Bluetooth Car Kit...
Code for bluetooth car kit
Also note that some of the IHF1000 carkits may also use 1234 for the passcode. When you go into the Setup Menu and ask it to Pair a Phone, the prompt will tell you the correct passcode (0000 or 1234) to enter by saying, "Enter xxxx, when requested".
Nov 24, 2008 | Motorola Mobility Blnc Bluetooth Car Kit...
Motorola IHF1000 bluetooth
Hey mawcab,
Based on the information provided it sounds like your microphone is not working. There a possibility it could simply be unplugged from the car kit control module. It will look like a head phone plug. If your car kit is aftermarket it was probably installed under the steering column. Check for a black box with an unplugged wire.
What type of work was done on the car?
Hope this helps!
Nov 05, 2008 | Motorola Mobility Blnc Bluetooth Car Kit...
Motorola Mobility Blnc Bluetooth Car Kit Portfolio Ihf1000 Logo
282 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
