How do I replace ac plug in on a toshiba laptop?
    Guru:
  • 374 Answers
You can buy any standard "universal AC/DC adapter". They will come with several different tips to fit your laptop. I bought this one for my Toshiba Satellite series and it works well:
LINK HERE. It is available in store and online at best buy.
There is also a cheaper one available from Walmart HERE. It is from Kingston and has a 1 year warranty so it should work well and have you covered.
Let me know what area you live in and I can track one down close. I have also bought one from Ebay that was cheap and worked without a problem. Let me know and I can look one up(ebay tends to be cheapest with power adapters in the 10-35$ range.
Posted on Sep 05, 2010
Toshiba laptop will not turn on
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
http://www.chargerbuy.com/laptop-ac-adapter/toshiba-ac-adapters.html
Mar 01, 2013 | Computers & Internet
I have a toshiba laptop about 2 years old. I didn't use it for a few days and now it won't turn on at all.
was it plugged in when you tried to turn it on?
if not, try charging it for a couple of hours. the battery must be completely empty
other than that I might need more details
Aug 07, 2011 | Toshiba Computers & Internet
My toshiba laptop wouldn't work well when connected to power source but will function well am using the battery
Laptop shuts off when AC adapter plugged in
Problem description: The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause: 1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution: First of all, test the power adpater. Make sure the apdapter outputs correct voltage. It's possible that the outup voltage is not correct and the laptop shuts down to prevent the damge. Test your laptop with anohter known good power adapter.
If the problem still exists, even after replacing the adapter, most likley it's the motherboard failure. Replace the motherboard
Jun 20, 2011 | Toshiba Computers & Internet
My battery doesn't recharge laptop when laptop is plugged in . What to do and at what approximate cost if new battery needed?
Hi there! There are two possible causes of the problem - it's either your battery or your AC Adapter. To diagnose whether or not it is your AC Adapter, test it this way. Does your laptop function with the power cord plugged in and the battery out? If this is the case, your AC adapter is fine and your battery is done. To replace the battery, expect somewhere between $75-$175. Here is a link to the cheapest battery site I've found so far - I use it for work all the time. http://www.batterydepot.com/mfg/TOSHIBA/LAPTOP-BATTERIES
If your laptop doesn't work with just the AC adapter plugged in, then that is your problem! AC Adapters are cheaper than the batteries. They can be purchased here for around $50: http://www.buylaptopadapter.com/toshiba-adapters.html
Make sure you match the model number on the bottom of your laptop perfectly with the model number of the battery or AC Adapter! Good luck! Alex
Apr 30, 2011 | Toshiba Satellite PSPA0U01S006 Notebook
It works good on battery but when AC adaptor is plug in the laptop cuts out and restart by itself.
Possible troubleshooting steps and repair solution: First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
Toshiba Satellite A305 AC Adapter
If the problem still exists, even after replacing the adapter, most likely it's the motherboard failure. Replace the motherboard.
Mar 11, 2011 | Toshiba Satellite A305-S6857, A305-S6858,...
My daughters Toshiba satellite l505d will not boot up correctly. It starts but then nothing happens. What do I need to do. Have already taken battery out and restarted. Any help would be helpful.
Try the following.
1. Remove battery and plug in the AC Adapter and check if it works
If yes - Battery is defective
If no - Motherboard Problem/AC adapter
2. Check the AC adapter LED indicator if its lighted or not(double check by a multitester)
If lighted - it works properly
if not - replace
3. Try to reinstall WINDOWS operating system by the use of the installer CD
4. Reformat your computer and install necessary drivers and applications
Thanks. Cheers!
Apr 15, 2010 | Toshiba Satellite L505-S5966 Notebook
Hello. I have Toshiba Satellite U205-S5034
Yes, this is replaceable. However, it is not easy to do and requires taking the motherboard out of the laptop and decent soldering skills. If your laptop is under warranty, consult the manufacturer and they may replace it for free. If not, computer repair places can do it for around $100 or so I believe. It is expensive due to the skills and time required.
Sep 23, 2009 | Toshiba Satellite A105 Notebook
Toshiba satellite m55-s135 won't power on even when plugged in
When the AC adapter is plugged to the wall, if it has an LED make sure it is on, remove the battery and connect the adapter to the laptop, does it power up?
Install the battery after charging, see if your laptop powers up.
If the laptop does not power up, the motherboard needs replacing.
I hope this helps to resolve your issue.
Good Luck.
Mar 15, 2009 | Toshiba Satellite M55-S135 Notebook
Toshiba Satellite A55-S306
Sounds like you have snapped the centre connector in the laptop. If you look at the AC connector on the laptop there should b a "pin" in the centre. These frequently snap off, symtoms are :
Battery will not charge
Will not turn on from AC supply.
There are some firm which will replace the ac jack for you but it will cost.
Interent search .. replace DC jack on toshiba
Sep 05, 2008 | Toshiba Satellite A55-S306 Notebook
Toshiba Portege 7100 AC Adapter
all are not same but you buy through ebay you cant replace it go the shop and verfy onces
Jun 11, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Computers & Internet Logo
David Payne
David Payne
