Amana washer I have an amana washer mdl # LW8203W2 and when it goes into spin cycle it leaks everywhere now. How do I get into washer to check where it is coming from
  • mikejonz May 01, 2009
    Same problem. Does aggitator come out? I have the top of the machine down to that.
    Novelist:
  • 177 Answers
Take the front panel off, two screws at the bottom of the front panel, probably a 5/16 nut driver will work. You will need a flash light. partially fill the washer with water and then turn it to spin.
Look up underneath the tub and see where the water is leaking from. If its coming from above the bearing you need a seal job.
Bearing, seal kit, not cheap, how old is the machine, time to buy a new one?
T
Posted on May 13, 2008
Amana washer will not go through rinse cycle
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
Mar 28, 2015 | Amana Washing Machines
Washer leaks when on spin cycle
drain is not working properly so that only spin is not starting
Jun 06, 2010 | Washing Machines
Leaks water and is abnormally loud during spin cycle
Sounds like the bearings are broken. This is a serious issue and may be quite expensive. If your appliance still under warranty, contact the manufacturer for assistance. If not, don't be afraid to ask the customer service if they can provide some assistance to replace your washer (as the repair will be quite expensive), perhaps the manufacturer may be able to provide a rebate or something like that if they appreciate you as customer.
Good luck.
Aug 31, 2009 | Amana Washing Machines
Spin cycle stopped on 10 yr old Amana washer
its the brushes on your motor or your pump is blocked or defective
Jun 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Washer wont work.
try putting it on spi - do you hear anything? could be a broken belt - very easy to fix.
Feb 28, 2009 | Amana LW8203
Washer wont work.
I FOUND BROKEN BELT . HOW DO I CHANGE IT ?
Apr 27, 2008 | Amana 3.2 cu. ft. Top-Load Washer
NOISE SOMETIMES
drum bearings MIGHT be gone good luck Eire
Dec 02, 2007 | Amana ALW480DA Top Load Washer
Amana LWA50AW Washer Leaks!
you need to get the front off... grap a light and get down and look inside to find out whats leaking... with out looking its just guessing check all water hose connections, water pump, and main seal where transmission goes thu drum
Sep 05, 2007 | Amana LWA40A
AMANA WASHER WILL LEAKS WATER IN TUB AFTER SPIN CYCLE.
Cylon, sounds like you need to replace the water inlet valve. It's not seating and weeping water. For series 10 the part number would be 40097701. Not that hard of a job. Catriver..post back.
Feb 20, 2007 | Amana ALW880WH Top Load Washer
Washing Machines Logo
466 people viewed this question
Top Washing Machines Experts
