Question about Eiki LC NB2UW Multimedia Projector
Display color problem, Eiki projector LC-NB2UW
After we went to menu on the projector, we could not find an "advance" selection anywhere. Where do we find advance to set the color adjustments to RGB?
  • 563 Answers
Hi sjmuseum
If you cannot find the advanced option in the standard users menu , then it will only be in the Service Menu which you would have to call Eiki support to find out how to enter the Service Menu.
Posted on May 14, 2008
I have some picture distortion - pink fuzzy color where white should be (like on hockey ice). I'm trying to determine if the t-con board is to blame and if I might fix it easily
Hi Bill.
I don't see a specific model for your TV, but have owned a rear projector system before. There is usually a sub-menu where you can do fine alignment of the Red, Green, and Blue projectors to get rid of the pink fringe. There is generally a white crosshair at center screen where you can fine align the three colors to get rid of the fringing, and sometimes an advanced menu where there are crosses all over the screen that you can individually select and fine tune, (tweaking the different optical distortions of the individual projectors to overlap).
If the fringe is a big swath instead of a fine edge, or if a color is totally gone, then you may be talking power amp issues. For fine fringes, the adjustments usually work fine.
Hoping that helps!
Dec 18, 2015 | Televison & Video
How do I reallign the LCD panels on a sony FE-40 projector?
From the 'Screen' menu, select the 'Adjust signal' option. From there, try playing with the 'Phase' values to see it things get better. If that doesn't work, try playing with the different color systems in the 'Setup' menu. You may need to select a specific color system instead of allowing the projector to 'auto'matically select one. Also, try turning off 'Smart Apa' in the 'Functions' menu.
Feb 28, 2014 | Sony Computers & Internet
How do you align the colors?
Press MENU button and ON-SCREEN MENU will appear. Press
POINT LEFT/RIGHT buttons to move a red frame pointer to
Press POINT DOWN button to move a red frame pointer to the
item that you want to adjust. and then press SELECT button.
The level of each item is displayed. Adjust each level by
pressing POINT LEFT/RIGHT button(s).
Move a red frame pointer to
the item to be selected and
Press POINT LEFT button to decrease contrast, and POINT RIGHT
button to increase contrast. (From 0 to 63.)
Press POINT LEFT button to adjust image darker, and POINT
RIGHT button to adjust brighter. (From 0 to 63.)
Press either POINT LEFT button or POINT RIGHT button to obtain
better balance of contrast. (From 0 to 15.)
To store manually preset image, move a red frame pointer to
Store icon and press SELECT button. Image Level Menu will
appear. Move a red frame pointer to the Image 1 to 4 where you
want to set and then press SELECT button.
Image Level Menu
Move a red frame pointer to any
of Image 1 to 4 where you want
Store icon
Press SELECT button at this icon to
store the adjustment.
Menu icon
Press POINT LEFT button to lighten red tone and POINT RIGHT
button to deeper tone. (From 0 to 63.)
White balance (Red)
Press POINT LEFT button to lighten green tone and POINT RIGHT
White balance (Green)
Press POINT LEFT button to lighten blue tone and POINT RIGHT
Jan 22, 2011 | Sanyo PLC XU35 Multimedia Projector
The color on our cp-s240 projector is really bad. When I go to menu, color and tint are greyed out so I cannot adjust them, what should I do?
Often you will see that you have lots of options in your menu that appear grayed out. This occurs when you do not have an input device connected to your projector.
In order to have access to all the menu options, simply connect an input device (TV,DVD player, computer, etc) to your data projector and start the projector.
Assuming everything works properly, if the projector starts receiving a signal, you will have all your menu options available.
I'd also note that image discoloration can also be caused from defective/damaged cabling, cables not being connected fully, bent pins depending on the type of cables you are using, and also for internal problems. If you can not adjust your settings to achieve satisfactory color, check your cables for damage and make sure they are all connected properly.
Jan 05, 2011 | Hitachi CP-S240 Multimedia Projector
What are the picture,color,tint,bright,and sharp settings because the picture quality is bad for the proscan ps27108 tv?
You would go into the menus to adjust the picture settings. Press the menu button repeatedly until you get the 'video' menu hilighted, then press the 'select' or enter or whatever button chooses, and then use the left and right arrows to adjust the settings, and the menu button to advance to the next selection.
Nov 02, 2009 | Proscan PS27108 TV
1. Use the menu on the monitor to turn up the volume
2. right click anywhere on the desktop- select properties - select the "settings tab" at the top - click on the "advanced" button. this will open your video cards display settings .
you will need to look for a brightness controll or color corection section to adjust the brightness as all video cards have different software for controll.
Gamma will increase you brightness also. a ballance od gamma and brightness is neccessary, so change em both small amounts , then check your desktop or applications, then re-adjust.
This should Fixya up ! Please rate.....
Oct 28, 2008 | Computers & Internet
Colors displayed
Go to Menu, Advanced, and set the color adjustments to RGB. That should work.
Dec 03, 2007 | Eiki LC NB2UW Multimedia Projector
Proxima C160 Color Convergence Issue...
There are no adjustments for convergence in the service menu. The code is: Effect, Blank, Video, Computer, Volume Down, Volume Up.
Jun 01, 2007 | ASK Proxima C160 Multimedia Projector
Eiki LC NB2UW Multimedia Projector Logo
294 people viewed this question
Top Eiki Office Equipment & Supplies Experts
Level 1 Expert
Jaime Hernandez
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
