Question about Citizen 8700 BL8000-54L Wrist Watch
Will u pls tell me any citizen eco drive repair shop in delhi so that i can get it repair,
  • 73 Answers
SOURCE: Setting the time on a Citizen Eco-Drive Watch
Go to this link and pay particular instructions on how to find your watches movement or caliber number.
http://www.citizenwatch.com/COA/English/settings.asp
Posted on Dec 31, 2007
escapement
  • 2334 Answers
SOURCE: setting time on my citizen eco drive skyhawk model jr3090-58l
Go to this site and choose interactive settings for your watch:
http://www.citizenwatch.com/COA/English/find.asp
Do not forget to rate, please.
Posted on Jan 19, 2009
escapement
  • 2334 Answers
SOURCE: Need manual for Citizen Eco-Drive Calibre 8700.
Use this link: http://www.citizenwatch.com/COA/English/settings.asp Fill in requested details of your watch and click on GET SETTING INSTRUCTIONS, then click on INTERACTIVE SETTING INSTRUCTIONS. There you will find everything you need to set up your watch. You can download instructions on this site as well.
Rate me, please.
Posted on Jan 08, 2010
Testimonial: "Provided great info and quickly."
  • 8 Answers
SOURCE: i need user manual citizen eco drive calibre 8700
http://g-ecx.images-amazon.com/images/G/01/watches/H500_ebook.pdf
this should take care of your needs!
Posted on Mar 21, 2010
escapement
  • 2334 Answers
SOURCE: need to shorten my band
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Jul 31, 2010
Citizen eco drive stopped working
Bad capacitor (Titanium Ion Battery)... probably a $30 or so repair on a fine watch.
Feb 17, 2014 | Citizen Watches Citizen Atomic Perpetual...
I am desperate to find an owner's / instruction manual for the Promaster SST Citizen Eco Drive watch.Please TELL ME A PHONE NUMBER I CAN USE TO OBTAIN THIS.
To determine the exact model and specifications of your Citizen Eco-Drive, flip the watch to the reverse. On the case back will be extensive information about your timepiece. You're looking for the "movement caliber," a four-character combination of letters and numbers, separated from the seven-digit "case number" by a hyphen.
Next step, visit this links:
- citizenwatches.com.au/instruction-manuals
- citizenwatch.com/COA/English/settings.asp
Hope this helps (remember to rate this answer).
Apr 14, 2011 | Citizen Eco-Drive watch
I need new pins for my womens eco drive citizens watch to re size. where do i but them and what size do i need.
mcdevito75 here, besides the pins, you"ll need a special tool called a Pin Removal tool. By the time you order and recieve, it"s better to look for a small watch repair shop in your area for the removal / Install of these pins and links.
Aug 02, 2010 | Citizen Eco-Drive BL006056H Wrist Watch
Replacement mineral glass for Citizen Skyhawk AT
mcdevito75 here, Yes, there should be, look for a small watch repair shop in your area, for this crystal.
Jul 05, 2010 | Citizen Eco-Drive JR3080-51L Wrist Watch
Taking off a link from a citizen eco drive watch band
mcdevito75 here, Best Bet, look for a small watch repair shop in your area, You"d need a tool to remove that link, by the time you get the tool, the time to remove the link, is about the same cost of haveing a shop do the job.
Jul 04, 2010 | Citizen Eco-Drive Aqualand BJ2004-08E...
I have a Citizen, Blue Angel eco drive c300 caliberwatch with buttons on left that stuck Is this a fixable item
Sounds like it needs a cleaning like mine did. Go to stewarttime.com.
They are a Citizen Eco Drive repair shop. I can't say enough good things about them. They have repaired both my Eco Drives and I am a very satsified customer of theirs.
Feb 09, 2010 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Citizen Eco-Drive
Could be that the watch inside and outside numbers do not match. If the dial says Eco Drive, that should be the first step. Next, find out about the 4 digit number that tells you which type we are looking at. You may want to open the back and look at the number on the watch internals. But be aware you may damage the water proof seal in doing so.
Really, you should write down all numbers you can see and send an email to citizen. They will help you.
If you need to know more about the Eco Drive, look for detail tech manuals for all types here: http://www.citizenwatch.com/downloads/tech/tech.htm
Those are great watches as long as you remember it needs light to charge.
Jun 09, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
I purchased my second citezen watch in auburn, Massachusetts also i purchased the two year warranty. My warranty expired in february and my eco drive watch expired in july of 2008. I took the watch to get...
this does not sound indicative of citizen watches...they usually have great movements. A new watch movement might be $100 when shipped back; I had a Kenneth Cole that cost $60 to get a new watch battery and link removed. Check with them, or on the internet; there are tons of e-tailers that sell used or new movements. Buy it and take it to a GOOD watch repair shop. Most shops have the tools but little knowhow so check around. they should be able to drop it in with little hassle, otherwise my recommendation is to go to Zales and pick up a preowned watch for $60...I got a beautiful Calibre 2100 for $105!
Aug 17, 2008 | Citizen Eco-Drive Silhouette EW869452D...
Citizen 8700 BL8000-54L Wrist Watch Logo
19 people viewed this question
Top Citizen Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
