Question about Kenmore 73952 Gas Dryer
Brown streaks Thanks. This sounds like the problem I have. It's only 3 years old but we do have inadequate ducting. My model number is: Kenmore Elite HE 4 Gas Dryer Thanks, Dave
  • 943 Answers
Hi thanks for the question-yes if the venting is not good ,you dryer will take 3 times as long to dry the clothes. its a must to have a clean venting. clean all venting thanks the appliance doc
Posted on Oct 03, 2008
Hello I have an 2004 HE4 Nat Gas smartheat quick pack 9 model 9587 / 110.9586. It seems to be leaving brown markings or streaks on the clothes more and more frequently any ideas on how to best deal with...
the felt seal part number 697694 could be worn,if the drum sags down from the felt wearing down it forms a gap and the clothing can even get stuck in gap,some dryers have glides that wear down and some ride on a back bearing,but the problem usually is from a part wearing down and a gap forms from it and it damages the clothing,hope this helps
Nov 06, 2009 | Kenmore Elite HE4 Electric Dryer
5 Year old Kenmore Elite Electric Dryer will not heat.
limit switch either the one on the heating element or the one in the air duct they are easy to check if u know how to use a meter they should read continuity when they are cold and open up at a certain temp
Aug 24, 2009 | Kenmore Dryers
HE4 propane dryer wont heat, how do I get the codes display?
Sounds like a clogged exhaust duct or vent. If not venting properly, most dryers will turn the heat off, for safety reasons.
Go for the easy fix first. Before removing your exhaust ducts from the dryer, look for any kinks that may cause blockage. Clean out the duct of any lint or water that may have accumulated. Check the vent on the outside of the house and make sure that its not clogged and opening properly.
Jun 05, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Dryer - Series 80 - Model 96586200
the brown streaks are from the seals most likely from the front seal ... if your handy it will be an easy fix..
Oct 12, 2008 | Dryers
F Code for the Kenmore Elite he4t Front Load Washer (3 years old)
Hi! ricksmith
What is the first three digits of the model number.
The he4t I have reference to does not have a "F" code error. Most of the codes are two digit, PF, F1 to F9 etc.
You could try: Pressing Pause/Cancel two times to clear code. As well as unplug for 20 seconds. Do you have power fluctuations in your area.
InMrFixIt
Aug 27, 2008 | Kenmore Elite HE4 Electric Dryer
Brown streak on clothes
It could be from scorching due to getting too hot. This may be the start of a problem for you.
It is best to judge how long clothes need drying for before drying them. If they are left too long, sometimes the heat builds up.
Try a smaller load in there, and if you can reduce the temperature any then do.
Often it's just overloading is the issue.
Hope this is a solution for you, If so, Please rate as Fixya! Thanks.
Jun 18, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer is leaving brown streaks on cotton clothes
To all victims of the brownish colored streak marks: I share your frustration!!! I have the same problem with my dryer which started when my dryer was only 3 or 4 years old - - totally unacceptable for an expensive top of the line dryer! A repair guy showed me how the brownish streak marks come from the felt liner which goes around the drum. Look inside your dryer for the beige or tan colored felt which sticks out around the circular drum. If you rub the felt with an old white t-shirt or paper towel, you will see the same brownish colored marks. My repairman recommended getting the felt replaced eventually, but until then, he gave me the following tips which really help avoid getting the streaks: For white or light colored clothes susceptible to the brownish streak marks: I dry these items as part of a very lightweight dryer load - with just a few other lightweight items. By doing a small lightweight load, clothing is less likely to get caught up & rub against the felt edges. For example, I dry 4 light colored men's dress shirts with 2 or 3 other lightweight shirts. OR for white or light colored athletic "dry fit" type athletic apparel, I dry 6 - 8 total lightweight shirts/shorts. If I throw my white Nike top or white pair of summer pants into the dryer with all my "whites", they will be doomed to getting brownish streaks due to the heavy load pushing them against the darned felt liner! Whenever possible, I wash susceptible items on permanent press to avoid wrinkling, then hang dry. Prior to putting these clothes in the dryer, I also "pre-clean" the felt with an old white cotton t-shirt by reaching into the dryer and rubbing along the felt edges until I'm not getting as much brownish color on the t-shirt rag. For a permanent fix, call a repairman or see the following do-it-yourself YouTube video on "Dryer Repair - Replacing the Lower Front Drum Felt Seal": http://www.youtube.com/watch?v=XoYP_YsGP68 . I have a repair person coming today to fix 2 other appliances, so I'm finally getting my dryer fixed, and I will post an update soon.
Dec 30, 2007 | Dryers
Kenmore Elite Gas Dryer 7 years Old Mod# 110 72982101
Make sure your vent duct is not clogged up. If the machine can't breathe properly it will short cycle the burner.
If this is ok, it sounds like the flame sensor has failed. Also, the thermistor should not read open, it should have some resistence. It changes depending on the temp. Open the back of the console and you should have a tech sheet that gives all the readings and diagnostic checks.
Post back to this thread if you need help going through it.
Oct 23, 2007 | Kenmore 63942 Dryer
Kenmore Elite Heavy Duty King Size Capacity Quiet Pack II Dryer
cutiepie, I've seen this many times on these dryers. You need to replace the door hinge. Not really a hard job to do. Post a model number (inside door) and we'll get you a part number...Catriver..post back.
Feb 18, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore 73952 Gas Dryer Logo
61 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
