Question about JoWood Productions Alien Nations for Windows
I want to play Alien Nations on my windows 7 PC... it doesnt work, only plays as audio. What can I do? Is there a newer version of the game I can download?
My Gateway 504 GR won't play WSOP or most Reel Slot games. How can i play newer games on my pc? 2002 version Windows XP Home, 915 chipset, Intel proc. 4 cpu 3.00GHZ 512mb 3000mhz. Thanks
Hello there,
The image below indicates the minimum and recommended system requirements of WSOP most probably you will be able to play the game. The problem might be your Adobe Flash Player or your Internet Explorer version. If your Windows Xp Home is genuine you might consider updating or download a Mozilla Firefox.
The links for Adobe and Firefox are located below the image.
Flash Player
Mozilla Browser
From what I know Windows XP by default have an Internet Explorer v.6.0 that is why you need to update your Windows. by the way you have to download Flash player if you have Internet Explorer v.7. if this does not work try the step below
1. Download the Mozilla Firefox browser and install setup 5.0.1exe. 2. Download Flash Player it will automatically update your Flash.
Hopefully this information helps.
Thank you for using FixYa.
Aug 04, 2011 | Gateway 504GR PC Desktop
Is there a way to get the old game Enemy Nations to run on 64 bit windows 7
Hello there,
From my searching it doesnt look like you can play the game directly in Windows 7. You can, however, run a virtual box of windows XP and attempt to run the game in the virtual environment. That would take a fair amount of work though and requires a certain level of windows 7 and a compatible CPU. Here is some information on it.http://www.microsoft.com/windows/virtual-pc/default.aspx
I hope that helps! Thumbs up are always appreciated.
May 04, 2011 | Enemy Nations for Windows
Hello, my game earthworm1-2 dont work my computer say that this game incompatibiliteit is with the 64 bits version from windows i have an asus laptop 1/2 year old with windows 7 version wath can i do to...
Hi, phoogland!
Older products aren't compatible with newer OS. The best way you can play these games is probably by emulating a virtual PC. Try installing Windows 98 on a Windows Virtual PC.
Here's a link to a detailed manual: http://www.essjae.com/virtualization/WinVPC-InstallingWin98.pdf
If this didn't fix your issue please let me know. Hope this helped you!
-Luchen
Mar 07, 2011 | Activision Earthworm Jim for Windows
Il2 1946 ver 4.10 crashes (application hang, il2fb.exe was shut down) in long missions. My computer is high end, and other games with higher spec requirements run flawlessly. I just bought a new copy of...
It might sound wierd but newer machines tend to have problems with older software. You do not give details of your system specification, but this game is not listed as compatible with Vista or Windows 7. It may work up to a point in compatibility mode but this may be the reason for it crashing. Other reasons can be that it was tested with graphics cards available at the time and newer cards may have some features not accounted for in the software, which may also cause problems.
Feb 24, 2011 | Ubi Soft IL-2 1946 PC
I have windows 7 have just installed war leaders clash of nations. when i open the game and hit play the sound plays but there is no visual just a black screen then when it gets to the main cover windows...
I had the exact same problem. I had to locate the actual program with Program Files and change the Compatibility of the program. If you are running 32-bit it will be located in "Program Files\DreamCather\War Leaders Clash of Nations"
In 64-bit it will be "Program Files (x86)\DreamCather\War Leaders Clash of Nations"
The file is called "War Leaders - Clash of Nations" and you will want to right-click it. Then click Properties and then click the C"Compatibility" Tab at the top of the window. Then adjust it to what I have shown below. Be careful as you can not alt-tab out of the program or switch windows in any way while playing, it will put it back to the black screen and you will have to force close the game.
Hope this helps you too. Have fun gaming!
Feb 23, 2011 | Dreamcatcher War Leaders: Clash of Nations...
Failing to initialise d3d when trying to play tekken 3 game
if problem with d3d
then you need install a other version of windows
because your game need newer version of d3d
i think you are using windows xp which have a direct x ver. 9
so you need directx ver. 10 or 11
you have two chices
you may go for windows vista which have directx ver. 10
or for windows 7 which has directx ver. 11
i thinck you understant
Jan 29, 2011 | Computers & Internet
I'm playing rise of nations and the screen is small like wide screen not full screen on my laptop.
for a mac laptop the answer is command M for PC i believe is alt tab to maximize and minimize
Jan 15, 2011 | Microsoft Rise of Nations for Windows
Atari Scrabble Complete has been playing well on XP for years. New computer has Windows 7 and Scrabble freezes when it begins loading. I also have BitDefender Anti-Virus installed but it does not seem to...
Unfortunately not all games will work with newer versions of Windows even with the compatibility modes. Atari Scrabble is an older game, and Atari stopped providing updates for the game some time ago. At this point your best bet is to find a version of Scrabble that is compatible with Windows 7. Microsoft has a Windows 7 Compatibility page on their site. The website address that is below lists another companies version of Scrabble that will work with Windows 7. Check out your local PC game retailers or the Internet to find and purchase a copy or search to see if there are other versions that will work with Windows 7.
http://www.microsoft.com/windows/compatibility/windows-7/en-us/Details.aspx?type=Software&p=Scrabble%20Journey&v=Encore&uid=&pf=0&pi=5&c=PC%20Gaming&sc=Board%20%26%20Puzzle&os=32-bit
Mar 04, 2010 | Infogrames Scrabble Complete for Windows
JoWood Productions Alien Nations for Windows Logo
375 people viewed this question
Top JoWood Productions Video Game Consoles & Games Experts
James Wishart
andrewcahoon
Carlos L. Burgos
Carlos L. Burgos
Are you a JoWood Productions Video Game Console and Game Expert? Answer questions, earn points and help others
