Question about Refrigerators
Goldtech commercial 2 door upright freezer. door hinge replacement. model # J2SFF-21B
3 Suggested Answers
  • 3 Answers
SOURCE: Freezer door on Kenmore AS-18 is sagging
I have this fridge and the sagging door means that you are missing a plastic washer. you might have accidentally placed this washer on the top rather then on the bottom where it belongs.
Posted on May 17, 2010
SOURCE: The top hinge of my neff integrated fridge freezer has broken.
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
Posted on Jun 12, 2010
Commercial freezer stops cooling and goes into delay start mode.
unfortunatly the company has gon out of buisnees and parts available
are kind of hit and miss. As a profesional technician it really frustrating.
I would definitly look at the control side of it. some it could be the relay or digital controller. Good luck hunting the parts down. There are some online parts dealers that still carry some parts. Have your model number
and serial number readily available when ordering.
Jan 17, 2013 | Coldtech 21 cu. ft. / 595 liter Commercial...
My freezer has a a sound like oil burnd and bulds up ice on pipes
sounds like it may be overcharged. The popping sound is actually liquid refrigerant coming back to the compressor. Has it been worked on recently? If it has trefrigerant will have to be removed.
Jan 19, 2011 | Coldtech 21 cu. ft. / 595 liter Commercial...
Completely dead
let's start with the basics. Are you sure you are getting the correct power to the unit? If 120 volts, use meter and check across power and neutral, not power and ground. If correct power is present, check the defrost timeclock for proper operation. If bad and stuck in the defrost cycle, nothing will work except for the defrost heaters. It should terminate defrost cycle and return to the freeze cycle, but if terminator is bad, it will just sit in defrost. Start here and get back to me and we can continue.
Oct 07, 2010 | Coldtech 21 cu. ft. / 595 liter Commercial...
Coldtech freezer door reversal
http://www.ascendmfg.com/PDFs/CT/hdmanual.pdf
start at this web site and see if this manual will help. It has phone number on last page if you need to call them.
ColdTech is now Jimes Corp. Just Google you unit if what I have does not help enough.
Good luck to you.
Oct 21, 2009 | Coldtech 21 cu. ft. / 595 liter Commercial...
Re: danby upright freezer 20.1 cubic ft., model #
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Oct 13, 2009 | Freezers
Door doesn't close properly, leaks water
If the door seals are still pliable and intact there are two possible causes.
1/ The upper door hinge on the top of freezer unit has two adjusting screws under a plastic cover/cap which allows the upper hinge to be set forward or back altering/adjusting the spacing of the door seal to the freezer body. Moving the hinge outward at the top will cause the door to seal tighter at the bottom and lessen escaping cold air and condensation to form (water droplets). Adjust carefully so as not to create a weak seal (air gap) along other sealing edges of the door frame.
2/ Many United Refrigeration Commercial Freezers are manual defrosting. Moisture from inside the freezer can condense between the inner molded door panel (door shelves) and the exterior metal door. Usually ice buildup will occur in this space, but when defrosting or during high ambient temps the ice will melt and drip out along the bottom door edge/seal. Screws alomg the door frame (hidden by the door seal) hold the seal in place and also the inner molded door panel. The inner panel can be removed to replace the seal or to remove the ice buildup.
Jun 04, 2009 | Freezers
Kenmore commercial upright freezer not sealing well - thawing
If the door seal does not seal completely, replace it. This is very important for freezers.
Contact Rick at Restaurant Parts and More.
\1-888-814-1110. He can most likely get what you need. Just have model and serial numbers and he'll do the rest.
Home Depot and Lowes is a definite no.
Apr 04, 2009 | True 23 cu. ft. / 651 liter Commercial...
How do you adjust a Westinghouse 2 dooe refrigerator door
Loosen the top hinge screws.
Pull up on the door to where you want it.
While holding the door in place, re-tighten the screws.
Mar 11, 2009 | Frigidaire Freezer Refrigeration White...
Evaporator freezes up
No model # .. Im assumeing its frost free.. so that means a defost problem.. heaters, defrost themostate or timmer.
Aug 30, 2007 | Coldtech 21 cu. ft. / 595 liter Commercial...
Refrigerators Logo
96 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
