How do I tell if my wireless router is setup properly or of If I have RF blocks in my house
  • 388 Answers
Use a program called Xirrus wifi inspector.
Posted on Sep 05, 2010
Can i setup the belkin f7d4302 as a wireless bridge
belkin does not support this. The only way you can do it is by running a cable to the router to extend your wireless signal around the house. I did a similar setup with a powerline network adapter if running a cat5 cable is not a option. just make sure you change the main ip address for the 2nd router to like 192.168.2.2 and disable dhcp since the main router will handle dhcp. also make sure the wireless settings are the same and channel is different if 1st router is channel 1 then use channel 6 or 11 for the 2nd router.
Feb 26, 2012 | Belkin Wireless Play Router (F7D4302)
2 routers. Can i have two routers within the same workgroup. My wireless router will not work from one end of the house to the other. I need to have more than one wireless transmitter so my laptop will...
Yes you can have the setup in your workgroup in multiple ways.
Solution1:-
The logic will be making your new wireless router to act as a wireless booster which will receive the signal from your old wireless Router and then retransmits the signal.But this needs some extra configuration on your new wireless router
1. You have to select the WDS ( wireless Distribution System) mode in the new wireless router.
2. Set the same SSID on the new wireless router.
3. In the new wireless router config page , search for the wireless signals and select your old router from that list.
The WDS mode tells the new wireless router to send/receive the wireless signal to the old wireless router.
Solution 2:-
Connect your old wireless router LAN interface to a network switch through a CAT5e UTP cable and the new wireless router to another port of the switch (use a cable which can be extended to the other room where you want the new wireless router to be placed).
Configure the same SSID you have set in the old wireless router.
Best Regards
Nov 15, 2010 | Computers & Internet
Neighbors stealing internet access
It's no problem all you need to do is access the administration page of the wireless router and setup security. Depending on what type of device you have there are several options. The most basic security is fine and you will need to create a passcode so that the PC's you want to access then internet will work. Then when security is setup you type the access codes in your PCs and you are good to go. I know this is very generic but I don't know which router you have. I can be more specific if you need, just let me know. Usually you access the admin page by the IP address of the router entered in Internet browser then it will ask for user and pass. ( if I know the model I might be able to tell you that as well)
Hope this starts the process for you, just send me comments if you need specifics
TankMurdock
Apr 24, 2009 | D-Link AirPlus DI-524 Wireless Router
Orange blink of death!!!
Hello houng_lee,
I have the exact same modem, if the modem/router light is blinking, that indicates a problem with the modem. You indicate that you have internet connectivety, so you should have modem light solid blue. When you look at the Wireless light it's probably off. Which means that at this point you have internet connectivety, you should put the cd in and run through the wireless connection wizard on the CD. It will check to see 1) if you have internet connection, 2) the type of connection you have (comcast) 3) if you have any wireless devices to be hooked up. 4) That all connections are working properly.
If you have a laptop that you want to connect to the wireless router, have it next to the router, so once you've finished setting up your Wireless security and issing a WEP number for local access, you can test your setting immediately with the Laptop. I always suggest that you create a WEP number for securty reason, If you perfer not to create a WEP number, and leave it as an open access (which is fine, and easier to setup) make sure that you shut off broadcasting, So your neigborhood doesn't jump online once they see an open access router.
If you've tried these steps let me know what problems your getting during the wizard setup. It will tell you if everything is setup correctly, or their is an error. Right now, I think the problem is your setup, and it's not communicating correctly. But, the wizard will tell you that as well.
Let me know,
Good Luck
Mark
Feb 17, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Motarola VT2542 Wireless Router: If you disable the wireless on the router's software does that stop the router from broadcasting rf frequency? I would like to use the router as a wired router without rf...
Hi! It's ok to disable the wireless broadcast of the router however, it wont stop the router from broadcasting the wireless frequency. It will only hide itself from the people who are trying to connect to a free signal that are available.
Dec 19, 2008 | Arris Wireless G Broadband Router (wr850g)
My new alarm system / wireless router
What type of Alarm system? If that pakervision has network ports on the back there is no reason they couldn't run a cable to it and setup the security for you. I've never heard an alarm company tell a consumer "No you can't have wireless in your house" I'd need to know the model # of that parkervision because this doesn't make sense to me. If that parkervision doesn't have any network ports on it... yea go out and buy a wireless router that has ports on it.
May 01, 2008 | ParkerVision SIGNALMAX WR1500...
Cannot get printer hp psc2355 to work with br6215srg router can you please advise
This router has a built in print server. What type of cable setup are you using; USB, LAN, Firewire ?? All of these methods should work.
For me, I have usb printer and wireless router connected to my desktop in the office, and I use a wireless LAN laptop around the house and I can print from my wireless laptop.
Tell me what setup you want to use so we can narrow this down.
I'm assuming this is a NEW setup your trying to get started.
Apr 18, 2008 | Computers & Internet
Connection Not Consistent
You shouldn't have to run the setup wizard to reconnect. It sounds like you just haven't configured it to auto-connect to that wireless connection. Right click on My Network Places and select Properties. Right click on your Wireless LAN connection, and tell it to connect. You should be able to go through those settings and tell it to auto-connect to your router as well.
Sep 09, 2007 | Linksys Wireless-N WRT150N Router
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
