Question about Icon F152WIR 15.2 in. Car Monitor
Replacing in-line fuse - Icon F152WIR 15.2 in. Car Monitor
Replace thermal fuse for LG microwave LMV1813ST
If too much current passes through the microwave circuitry, the line fuse will blow. If the line fuse blows, the microwave won't start. To determine if the line fuse is at fault, use a multimeter to test it for continuity. If the fuse does not have continuity, replace it. In addition, you should investigate and resolve the problem that caused the fuse to blow. If you don't resolve the underlying issue, the new fuse will blow too. (Caution: The microwave oven can store thousands of volts of electricity in its high voltage capacitor, even after the microwave oven has been unplugged. Due to the potential for electric shock, it is extremely dangerous to replace the electronic components in a microwave. Only a licensed technician should replace the line fuse.)
Sep 28, 2015 | LG Over-the-Range Microwave
Why does the fuse in the plug keep blowing?
-The line go to the device touch ground or bad device.
-Check the device and line . If it's broken, replace it before replace
new fuse.
Good Luck
mai
Aug 05, 2015 | Cars & Trucks
Line fuse replacement
There is no line fuse, the only fuse is in the wall plug ,this link is for the manual
http://hoover.com/file/604/
Apr 28, 2013 | Hoover SteamVac F5914-900 SpinScrub...
I have misplaced my manual for a 1980's zenith tv. I need to replace the fuse and I can't.
If you want to replace the fuse try to follow your ac cord and it will direct you to your power supply there you will see the fuse. Just trace the line 1 and line 2 of your ac connection in the pcb you will see the fuse it is printed in the pcb. Good day and best regards. Note be sure to unplug the unit before opening the back cover of your tv and replacing the fuse.
Jul 29, 2011 | Zenith Televison & Video
I recently purchased model vrvd640g and it continually blow fuses. my installer says the power supply is defective. can you help or replace the unit?
the problem can be solved my unit blew the fuses on the harness and actually melted the plastic that held the in line fuses in so i went to pep-boys and bought 3 hevy duity in-line fuses and cut and spliced them into the harness removing the 3 original factory in-line fuses and i never had that problem again and also for the cars radio fuse i replaced it with a higher amp fuse so i took out the 1amp red fuse and replaced it with a white 25 amp fuse or u can use a green 30 amp fusethey are all the same size they just dont blow with the new power load of the radio.
Sep 15, 2010 | Car Audio & Video
No power-inadvertently left on empty GE je1160wmc
Hi. the inverter in your unit has failed. have it replaced asap. It is possible that the In-line fuse has blown as well. you can access this fuse by removing the cover. the fuse is locate din the inverter sector, in line with the power cord. If this fuse is not blown, replace the inverter assembly.
Aug 27, 2009 | GE Microwave Ovens
Burned the in line fuse on my expedition.
The cover of the fuse shouhd twist off so you can replace the fuse.
Jan 21, 2009 | Xtreme Sound WMS230 Cassette Player
Car Amp keeps blowing fuses
The reason why fuses blow is that the current is too much. Is the fuse rating according to the specs ? If yes then ... One or more output power transistor (or audio power IC) may be shorted. have it checked before replacing another fuse as this might cause more damage.
May 22, 2007 | Profile CL1200 Car Audio Amplifier
Icon F152WIR 15.2 in. Car Monitor Logo
42 people viewed this question
Top Icon Car Audio & Video Experts
xxxxxx xxx
Are you an Icon Car Audio and Video Expert? Answer questions, earn points and help others
