Question about AquaVac Tigershark Plus Robotic Automatic In Ground Pool Cleaner
Water is forced thru the impeller, but the treads seems locked and wouldn't mve forward or reverse
Same thing happened to mine. Do you have a schematic for the circuit board? I took mine apart (I know, I shouldn't). When I hit drive motor directly with 24V DC from separate power supply, motor works. Is there a fuse/relay/etx on the board I can replace? What if I bypass the board and wire 24 VDC direct to the drive motor? I know it won't reverse, but at least it will move when it's on?
Posted on Jul 16, 2013
    President:
  • AquaVac Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
Look as best you can inside the side plates around the tracks for debris obstructing the tracks. If you need to, remove all 7 screws inside the cleaner to remove a side plate and clear whatever may be inside. If nothing is blocking the tracks the motor unit has failed and needs to be replaced. For an estimate or for information about getting it serviced please contact us thru our site at www.arrowpools.net.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Sep 05, 2010
1983 Johnson outboard . Model J25TECTE. Runs Forward/Reverse. Shift rod connection OK. Shift in neutral it runs in reverse. Do I need to change something in the gear case section?
you have removed the leg to replace the water pump impeller
the leg has the selector rod for the forward and reverse action
as the direction selection is a simple dog that moves forward or back to connect the spur gears and it was working before you pulled the leg off , then I am thinking that when the leg was reassembled that the selector was in a wrong position and now you are only moving it in one direction neutral or reverse instead of the 3 positions forward neutral reverse
nothing else can change except where the rod connects in the leg
Jul 07, 2016 | Boating
Pool pump wont prime
if this is a inground try only the main drain if it works something is in the skimmer line
Jun 01, 2013 | Pentair Pinnacle High Performance 1 HP...
Won't go back
If your vehicle is fitted with automatic gear box sounds that you are going to loose the transmission.For not going on reverse like having locked wheels,I believe looks like the brake bands in the gear box are the reason and the minimal power you have for forward drive are the clutches which are slipping. Visit an experts shop and please do not force it.
Aug 16, 2012 | 1999 Toyota Camry
Slow or no drain of water. cleaned out sump covers and ran drain cleaner thru cycle. looking for possible secondary filter.
Hi, if the water doesn't drain from your dishwasher, check the drain line and pump..
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Hope it helps...
Jun 27, 2011 | Hotpoint Dishwashers
My Kitchenaid Superba will not drain. The drain line does not seem to be clogged.
There may be a pump with an impeller that forces(pumps) the water out. The impeller may be defective.
Jun 09, 2011 | KitchenAid Dishwashers
I have a proline 1.5hp pump need to replace the shaft seal. I can't seem to get the plastic impeller off. We use a screwdriver to hold the shaft screw and try to turn the impeller counter clockwise...
Keep trying - It is stuck and will likely break but you have to remove it to change the seal. It is not uncommon to need to replace the impeller when the seal fails since the water gets behind the impeller shaft and rusts the metal causing the impeller to bind. If you still cannot get it free pull the motor thru-bolts and lock the rotor once removed from the motor in a vice. Use a large pair of channel locks to break the impeller free...replace it if necessary.
John
May 15, 2011 | Waterway 1.5hp Hi Flo Above Ground Pool...
I was wondering how much trouble it would be to change out an impeller on a esrly 80's 110 hp evinrude tracker outboard engine.
Impeller? or Propeller? Propeller is just a nut with a carter key holding it on.
Impeller, or water pump? It isnt too bad. You have to take the lower uint off. There is a roll pin in the linkage going to the forward/reverse mechanizm. Then take out the bolts and drop it down. It has a shaft that comes with it out of the engine. Then the water pump is bolted on that shaft. Check the seals under the pump and the oil in the gearbox for water. Mine was bad and pumped water into the gearbox and oil up and out. Then froze and busted.
Dec 17, 2010 | Ford EXP Cars & Trucks
I have a 98 yamaha 150 2 stroke outboard engine, when cruising about 23 mph she runs fine, but when i run her faster a alarm under the dash goes off in which i will slow it down to idle and the alarm will...
Although water is seen thru the tell tail hole, your engine is overheating. When were the thermostats replaced last? Water pump impeller may also be fatigued, and not pumping enough at high RPM's.
May 11, 2010 | Boating
On a 1997 f150 with 4.6 engine I cannot get heat.. It seems as if water is not circulating thru the heater core as I can feel the two hoses going to the core and one is hot and the other is cool. I have...
There should be a valve on the heater hoses leading to the heater core in the engine compartment or under the dash that would allow hot water to the heater core check this valve before changing out any more parts.
Mar 29, 2010 | 1997 Ford F150 Regular Cab
What does error E20 mean?
Error Code E 20 is a drain problem in the water pump. Your lines or water pump impeller may be blocked with animal hair, cloth fragments or foriegn materials.) The Impeller is an internal "Fan" that forces water thru the water pump)
Check this FixYa site for the many possible solutions
Aug 17, 2009 | Frigidaire Affinity ATF6000F Front Load...
AquaVac Tigershark Plus Robotic Automatic In Ground Pool Cleaner Logo
429 people viewed this question
Top AquaVac Pool & Spa Experts
Thomas Perkins
Thomas Perkins
Steve Slater
lioneltrain5
Level 1 Expert
Are you an AquaVac Pool and Spa Expert? Answer questions, earn points and help others
