Washing machine "Crystal Lord" goes to strong vibration when starts spinning
  • 188 Answers
SOURCE: Kenmore 80 Series washing machine - loud banging at end of spin
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further.
Posted on Mar 10, 2009
SOURCE: smelly washing machine
I had that. Eventually found a dead mouse in the door seal. Sorry but it's true.
Posted on May 26, 2007
  • 641 Answers
SOURCE: Machine vibrates excessively during spin cycle
Open washer's cover and look for a released or a malfunction shock absorber. Good luck!
Posted on Sep 04, 2007
  • 1294 Answers
SOURCE: frigidaire washing machine no spin cycle
Check your exit hose spigot, it may be clogged. This is if your filter is all clean.(Refer manual) There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on Feb 11, 2008
  • 135 Answers
SOURCE: brand new washing machine wandering on spin cycle
It sounds like the transit bolts or some of the packing is still in place. Running the machine with these in place can do serious damage.
Thankyou for using Fixya.
Posted on Feb 14, 2009
Admiral washer machine tub appears loose and unattached in rrear
First of all is your machine working or not?
If it is working and it's a front loading machine. The machine drum is hanging inside the machine using strong springs that helps it to reduce vibrations during washing and spin cycle.
When machine goes into spin(dry cycle), it usually shakes a little.
Dec 08, 2014 | Admiral Washing Machines
CRYSTAL LORD 909 not dry spinning or pumping out water
You're the 3rd person to log this problem in 10 minutes!!
Probably a blocked empty pump filter. Spin won't kick in until all the water is evacuated. If there is a little left, the machine will do the slow turn cycle that it does just before spin starts but not start the spin cycle because of the water in the drum.
You need to locate the filter and clean it. That should fix your problem. Once this is done, remember to keep the filter clean every few months.
Jun 23, 2011 | Washing Machines
HE Kenmore washer vibrates quite strongly on high spin, which is the Normal default for the machine. I have had it adjusted for levelling, then had to have a new machine delivered when the vibration...
most of the kenmore front loaders is that way,, if it is on a pedestal or on the second floor it makes them worse,, lg samgung electrolux all shake to a extent but kenmore is the worst
Jan 23, 2011 | Kenmore Washing Machines
WKD 23580 T noise and vibrate problem!How to resolve it?
Did you try to level the washer when it was brought in?
There are two adjustable legs underneath the washer front that you can spin around to set the level of the machine.
Good luck and be careful!
Dec 12, 2009 | Washing Machines
Front loading machine abnormal strong vibration on the spin cycle
Check the tub rollers or wear plates.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore Washing Machines
Brand new washing machine wandering on spin cycle
Feb 14, 2009 | Washing Machines
Whirlpool Front Load Washing Machine is very Noisy when spin
if it make noise like a train coming in on track,,,bad tub bearing,,,do you see any water leaks back there ..on the back tub or on the base of unit...if so seal damage,,
Dec 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Excessive vibration during spin cycle
sure..start by re leveling the unit, with a standard carpenters level.
Mar 02, 2008 | Maytag Atlantis MAV5000
Washing Machines Logo
207 people viewed this question
Top Washing Machines Experts
