Question about Radio Shack Pro-97 Handheld Scanner
SCANS BUT NO VOLUME - Radio Shack Pro-97 Handheld Scanner
    Genius:
  • 1,274 Answers
Hi, Try using a external speaker, or headphones, if that does it, replace the speaker. I will post further here, let me know....John...Rate this solution on the four thumbs-up
Posted on Sep 05, 2010
Lost volume on radio now lost power all together
triple posted.
fuse
or it's asking for radio codes.
some radios (all new) will either do dead
or look ok (dials and scans) but the amp is cut.
that is radio code, losts.
read the operators guide in the glove box, it cover this, RTM)
this is a FEATURE. called antitheft. protection.
Feb 11, 2014 | 2010 Toyota Matrix Automatic
Jbl radio A56840 loses station presets and no volume
Toyota vehicles have a fuse in the kick for the amp and sometimes there is located under the hood ... This is the switch turn on for the amp ... And 1 of the fuses is most likely the memory or constant power. B sure to check all fuses ... I do not have AllData pulled up . If the fuses are all good the amp or radio may be bad ... Or both ... Be sure to check all the fuses ... Many times I get clients that say allthe fuses are good and it is still the first thing I check ..Usually is a fuse ..Good Luck
Jan 27, 2014 | JBL Car Audio & Video
Scans fine but no volume
broken wire to speaker, damaged speaker, bad volume control, it gets worse from there and requires a electronics specialist
Jul 09, 2012 | Uniden Vintage Works Bearcat Bc145xl16...
SCANS BUT WILL NOT ICK ANY CHANNELS AND HAS NO
Turn the scanner on and volume up all the way, turn the squelch until you hear static, then turn the squelch down slowly until its silent, press scan, has it ever been programed? Just a thought. hope this helps..
Mar 25, 2010 | Radio Shack Pro-94 Scanner
I have a acer aspire 7730 and when it boots up it is going to start up repair it then scans to repair then says the root cause is system volume on disk is corrupt.please help someone. thanks Rob.
That's a hardware problem, the file system is munged and the hard drive cannot be loaded. Often times, this is only resolved by recreating the system volume and starting from scratch. Boot from the DVD and try running a chkdsk /r from the recovery environment (choose the
command prompt option), see if it can fix the drive. Otherwise, you may have to go the long way 'round. Hopefully you backed up your data on a regular basis.
Aug 09, 2009 | Computers & Internet
NO SQUELCH
I have a Radio Shack Pro 97 Scanner that I received as a present 1-1/2 years ago. It was working just fine and then suddenly there was no squelch or volume. The keys make noise when pushed, but there is no sound for the squelch or volume. The scanner scans the frequencies but does not stop and play. I went on line and found that other people were having the same problems. I went back to the store that the unit was purchased from and received no help what so ever, they said it’ s off warranty and I was out of luck, nice way to do business??. I think that something that cost as much as this should not be junk after a short period of time. I hope you can help me with this problem I do like radio shack, but I can’t afford to buy items that don’t stand up.
Sincerely
Greg Stevens
e-mail
fooyun@sbcglobal.net
Aug 07, 2008 | Radio Shack Pro-97 Handheld Scanner
SMB settings error.
if i remember right, the settings should be:
server: 192.168.1.10 / or server name
folder: Sbssvr1\Scans\SCANS
and if still not working, try give some user name and pwd, some networks require this.
Apr 24, 2008 | Konica Minolta bizhub C250 All-In-One...
Radio Shack Pro-97 Handheld Scanner Logo
41 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
