Question about Polk Audio PSW50 Subwoofer
I need an instructional manual for a Polk Subwoofer PSW50
    President:
  • 1,851 Answers
At this link you can see and download the user manual for your Polk Audio Sub-woofer. In case you need further details for installation or in case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on Sep 05, 2010
  • stephk96 Mar 01, 2012
    Link is gone! :(
NEED REPLACEMENT NON OEM REPLACEMENT WILL WORK WITH POLK AUDIO WIRELESS SUBWOOFER PSWi225
sq nearest expert radioinstaller I'm sure he will know the answer and have the replacement part you need
Feb 08, 2015 | Polk Audio Audio Players & Recorders
Where is the fuse in Polk psw 10 subwoofer?
You will have to remove the plate amp and look on the pcb, it is generally located near where the main power lines come in.
If you still can' find it contact Polk tech support, Ive owned several Polk products and always found there tech support very helpful; very helpful;
Tech/Product Support
9AM-5:30PM EST Mon-Fri
1-800-377-POLK (7655) Option 1
FAX: (410) 764-5470
polkcs@polkaudio.com
International: +1-410-358-3600
Nov 23, 2014 | Polk Audio PSW Series PSW10 Black 10-inch...
PSW 125 Diagram Schematic
download with model number suport e-manual pdf
Aug 28, 2014 | Polk Audio Psw 300-watt 12" Powered...
Subwoofer set up polk audio 6750
Connect the subwoofer to an amplifier/audio receiver with the proper cables. Reply back with your setup so I can get some more information.
Dec 25, 2011 | Polk Audio Audio Players & Recorders
Have a blown vintage polk audio psw50 subwoofer 8". Cannot find the value of the Ohms. Could you please provide this info and make recs for best place to replace this sub that is most cost efficient....
It measures in at just under 4 ohms, so assume a 4 ohm speaker. You can replace this with any number of similar subs, using perennial DIY favorite PartsExpress, there are two under $30 that would meet your needs (Dayton SD215-88 and Goldwood GW408). Looks like they both have dual 8 ohm coils, so you would simply wire them in parallel for your application.
Feb 18, 2011 | Polk Audio PSW50 Subwoofer
Have a polk psw50 with a bad driver( voice coil drags) looking for a good replacement or having it reconed. Have emailed Polk, no response yet. Any recommendations?
You might get luckier than me at tapping it with a hammer. I ended up ordering a replacement from Parts Express. 8 inch, 4 ohm subwoofer, pick something in your price range, but don't go crazy. Many of the current subwoofers have dual 8 ohm coils. If you get one, connect the coils in parallel.
Nov 26, 2010 | Polk Audio PSW50 Subwoofer
No sound comes out of the subwoofer. Sound passes through and the power light is on, but no subwoofer sound. Any ideas? Fuse? Easy fix? Can this subwoofer be replaced? is it still available? Can I buy a...
this may be a dumb question but have you turned up the signal. there should be a dial on the back that you can turn the power up. power light on, signal passing threw, the only other thing it can be is the built in amp itself may be dead.
Aug 02, 2009 | Polk Audio PSW50 Subwoofer
Polk Audio PSW 350 sub has no power
Hi, Just call the parts line at Polk Audio. They should have the fuse. You can also ask for technical if you're not sure of the problem. Here's the number for Polk: 800-377-7655 Good luck to you.
Dec 30, 2008 | Polk Audio PSW350 Subwoofer
Polk Audio PSW50 Subwoofer Logo
750 people viewed this question
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
ed_dantes
Level 1 Expert
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
