Question about KitchenAid Kitchen Ranges
Ignition source on all 4 burners will not stop arcing. This started while we were using one of the burners and it will not stop. It is a counter-top gas range.
  • KitchenAid Master
  • 43,501 Answers
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Posted on Sep 07, 2010
Have trouble starting gas burners on nobel fse90-1. Is there a trick to starting the burners. I need serious help before I go mad!
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 20, 2010 | Cooktops
All 4 electrodes spark when only one is turned on
Jul 20, 2010 | GE 36 in. JGP628 Gas Cooktop
GE stove JGSP28 igniter has been clicking non-stop for the last 2weeks. Blow drying the burners has slowed down the clicking to every 5sec. Front two burners seem to be clicking at the same time while...
A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you make need to replace the electric igniter module. Good luck.
Jul 16, 2010 | GE JGSP28SEKSS Stainless Steel Gas Kitchen...
Having serious problem with the ignite. When I turn it on and its lit the clicking of the spark does not stop. Also, one of ranges will not light at all! Help.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 09, 2010 | DCS RGS-305 Professional Gas Kitchen Range
Ge Spectra Xl44-three of 4 gas burners will not ignite without a match.
May 19, 2010 | GE Spectra JGBP35 Gas Kitchen Range
One of the burners on my Dacor 4 burner gas cooktop no longer ignites automatically, it just continues to spark, but it will light with a match. Is this something I can fix myself, and if so, what should I...
Mar 28, 2010 | Dacor Preference SGM304 Gas Cooktop
On my gas stove, 3 out of 4 burners light correctly. The 4th however will not light- doesn't show a spark. Though you can use a match to light the burner and it works fine. what gives? Can I do the repair?
Feb 10, 2010 | Frigidaire FGF326AS Gas Kitchen Range
None of my 4 ignitors will spark
Oct 25, 2009 | Maytag MGS5870 Gas Kitchen Range
Ticking sound of gas igniter continues after off.
try to clean the place wen u remove the control knob,by using a vacium.
Nov 19, 2008 | Cooktops
Ignitors are not working
Nov 17, 2008 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Kitchen Ranges Logo
97 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
