Question about Dishwashers
Not draining totally - Dishwashers
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Sep 07, 2010
Is there a drain plug on kia rio 2003 automatic transmission to change oil and how many leater is needed to change the oil.
Most cars, you have to drop the entire transmission pan to drain out the fluid. You have to buy a new pan gasket and filter too. Use Dexron VI transmission fluid. Total 5.9 liters. This is probably for the total system capacity. When you drop the pan, only about half of the transmission fluid drains out of the system. Only a professional shop can push out all of the transmission fluid.
Aug 31, 2015 | Kia Cars & Trucks
Holding water
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 02, 2013 | Washing Machines
Washer won't spin
Good Day,
Avanti washer repair
Good Day,
Nov 01, 2013 | Washing Machines
Won't drain and showing F 01
Good Day,
Oct 31, 2013 | Maytag EPIC MFW9700S Front Load Washer
I have been getting the Sd code and then F21 code during regular wash. I followed directions cleaning out white filter on bottom of machine and it did not help. So I followed directions for resetting the...
need to replace the part but dont try it if you dont have idea how to do.
call the technician for your safety and not to waste money.
Oct 30, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not drain totally when in final rinse mode.
Hello & Welcome to FixYa
Washer not draining completely problem usually occurs due to clogged/blocked drain hose or the drain pump not working. First try to clean the drain hose and drain pump filter for any clogs, then check drain pump operation. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 09, 2010 | Maytag Dishwashers
I would like to know if you have water left behind in the area of the drain is that normal? Should this be completely drained away?
No, it's totally normal, The pump can't totally empty the washer and the hose because once it starts pumping air and water the air gives least resistance so the water remains in the hose. When the pump switches off gravity pulls a small amount of water back into the drain.
Your washer is 100% fine.
Oct 16, 2010 | Bosch Evolution 800 SHE58C02UC 24 in....
MY MC1000 SCANNER COMES UP WITH BACKUP BATTERY LOW HOW DO I FIX
when the unit is totally drain (main battery and back-up batter is totally drain), you need to charge the device at least 20hrs to fully charge the main and back-up battery check manual of mc1000 re battery charging @ page 21-22
Sep 16, 2010 | Symbol MC1000 Barcode Scanner
Water on floor
they drain inbetween the bulkhead of your car. no access is available to get to that. if the evaporator case is totally removed you can run a new hose for it although they are usually short in most cases for the bulkhead is totally sealed watertight
May 24, 2009 | 2001 Mitsubishi Eclipse Spyder
Dishwashers Logo
153 people viewed this question
Top Dishwashers Experts
