Hello i have a rainbow dehumidifier model number dh-20s4a and it is saying on screen e1
  • ruralfinca Sep 05, 2010
    hello i tried this with power button and it didnt work,but i did exactly the same sequence holding the mode button and it did go through the sequence what you said but it didnt cure the e1 problem...
  • 944 Answers
E1 Means Clean Air Filter.Take the Air filter apart and clean it and place it properly.
After cleaning If still the "E1" display is flashing.
After 720 hours of fan operation, the error code E1 will appear on the display.This error code is intended as a reminder for the user to clean the air filter. Air Conditioners has a nonvolatile memory that cannot be reset by simply unplugging it.
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner.
6. Error code will vanish.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 05, 2010
  • Natarajan Ramasamy
    Natarajan Ramasamy Sep 06, 2010
    Have you cleaned the Clean
    Air Filter.Then if both doesn't cure.
    you have to reset the control board.There will be IC which needs to be soldered out and placed again to loose the memory details.Call the repair person it will cost very less 2 minutes work only.
My fan and compreesor works on my 5 yearold whirlpool dehumidifier but no water collects and the display says e1 all the time
Hi, fusiti. We're sorry to hear about the difficulty with your Dehumidifier. Below are links to our Use & Care guides, Parts Diagrams, Troubleshooting information and the Service are of our website. We hope this helps! http://bit.ly/112Lu7q
May 16, 2014 | Whirlpool AD35USS Dehumidifier
Humidity sensor
Go to Http://www.Haier.com/us/products/home-comfort/dehumidifiers . Select the model number and proceed to the Manual. Download the manual and look at the E-Codes to solve your problem.
Dec 19, 2013 | Haier 65-Pint Dehumidifier
DE' Longhi Dehumidifier - Model: DH=25 - Water does not empty into bucket.
If you're saying the dehumidifier is not extracting moisture from the air?
There are 5 basic, yet solvable reason for this. Please pay particular attention to numbers 1 & 2..
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If yours is a manual unit, turn
the control knob to Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helped you to troubleshoot and solve the problem.
Jul 14, 2011 | DeLonghi DH-25G Dehumidifier
Pressure relief tube behind the collection tank ?? should it point up or down?? model DH 400P
Down. If it's pointing up ans was activated, water could go into parts of the unit, where it doesn't belong.
Jun 08, 2011 | DeLonghi DE400 Dehumidifier
I would like to SEE a picture of how to hook up a hose from the DH to a drain.( no manual & cant find one for this DH 304) TO lift the bucket off & drain has become to heavy for me. Thanks,...
My DH 304 is a hand-me-down so I don't have a manual but it did come with a hose attachment which is plastic tube with a threaded end to which you attach a hose. The other end of the tube goes through a hole in the back of the unit and then through a foam screen inside the unit to slip over the drain plug. Aligning the tube and the drain plug can be tricky; it is helpful to remove the bucket to see if you're getting the tube onto the drain plug. Once you have the tube attached to the drain plug, align the tube in the hole in the rear of the unit so that the tab on the tube is inserted into the slot at the hole in the back of the unit.
Aug 26, 2010 | Goldstar DH304 Dehumidifier
E1 CODE ERROR
E1 code for the primary humidity sensor behind right side grill. Unit MUST be unplugged from outlet. Take right side grill out, unplug sensor from wire socket and plug back. If no help, you need new sensor.
Dec 30, 2009 | Danby DDR451 Dehumidifier
My DANBY Dehumidifier model DDR4588EE has been working ok until it showed a E1 error code and since then it does not work properly. Any ideas please?
Dec 30, 2009 | Dehumidifiers
My model DDR6588EE dehumidifier runs for a while and then stops displaying an E1. If I hit power button it will run a while and do the same thing. This also happens on Continuous mode. Is there some thing...
Dec 25, 2009 | Danby DDR6588EE Dehumidifier
E1 error code
my AC is going on 5-6 years, it's never failed me until the years. The Error E1 code hes been coming on lately.
i wait a few MIN's, then try again. about the 7-10 tries the unit comes on.
1. what is a error code 1
please reply to:
Derrick holiday
Email.... euphoricsounz@gmail.com
thank you.
dh
Aug 03, 2009 | Samsung AW1293L Air Conditioner
Kenmore model # 25800-25801 Error code E1?
unit has a sealed system leak call sears for tech support 1-800-905-9505 it is under warranty
Apr 15, 2008 | Kenmore 53701 Dehumidifier
Heating & Cooling Logo
153 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
