Question about Texas Instruments TI-Nspire Graphic Calculator
I just wanted to change from spanish to english ti-nspire
  • 51 Answers
To change the language on a TI-Nspire Handheld, complete the following steps: • Press [home].
• Select 5: Settings & Status.
• Select 1: Change Language.
• Press [?].
• Change the language using [?] or [?].
• Press [enter] twice to save.
Posted on Apr 03, 2011
The calculator writes 8 all over
During operation of the TI-Nspire handheld it may be necessary to reset the device. Circumstances which may require a reset include; keys not responding, device will not turn on or a garbled display. To reset the device:
• Remove the keypad (for TI-Nspire with ClickPad, TI-Nspire with TouchPad, and TI-Nspire CAS with Touchpad) or the battery door (for TI-Nspire CAS with ClickPad) and remove at least one battery from each column of batteries. After 2-5 seconds, reinsert the batteries but do not turn the handheld on.
For the TI-Nspire and TI-Nspire CAS handheld units with ClickPad:
• Hold down [home] [enter] [P].
• While holding these keys press [on].
For the TI-Nspire and TI-Nspire CAS handheld units with TouchPad and the TI-Nspire CX and TI-Nspire CX CAS:
• Hold down [doc] [enter] [EE].
Please Note: For TI-Nspire Family handheld units that contain rechargeable batteries you can alternatively hold the above keys while pressing the [reset] button on the back of the handheld rather than removing the battery for 2-5 seconds.
• The device will boot up as in the previous reset, but will display a menu with the following options. Please try options 2, 3, and 4 in that order.
• 1: Cancel - The most non-intrusive reset option; no changes are made, the unit restarts.
• 2: Delete Operating System - The operating system will be deleted without deleting any documents on the system.
• 3: Delete Document Folder Contents - This will delete the user's documents, but will not delete the OS. Selecting this option is the same as using the RESET hole on the back of the unit.
• 4: Complete Format - This will delete the OS and all documents for a total wipe of the handheld.
Please note that the second and fourth option will require that the OS will need to be reinstalled
Mar 12, 2014 | Texas Instruments TI-Nspire Graphic...
Download new OS and now stuck on Loading Operating System Screen
Hello , I'm a french boy and I have a bad English If you want solve this problem you want to keep HOUSE ENTER AND "P" button et you keep ON HOUSE ENTER and "P" button. The Ti nspire load and a new menu open you make the option 2 , and you install OS 1.7 or 2.0 because the problem is a TI problem beacause the boot is not the name . The french forum who you can read the solution is http://tibank.forumactif.com/problemes-divers-f9/sujet-tn-spire-bloque-sur-loding-operying-system-a-la-suite-t6088.htm :)
Sep 20, 2010 | Texas Instruments TI-Nspire Graphic...
My ti-83 is stuck on Spanish
Press APPS, then select Espa~nol. Press 2 to select English, then press any key as prompted. This will get you to English. If you want another language, select it instead of Spanish (and you won't have to press any key at the end).
Apr 19, 2010 | Texas Instruments TI-84 Plus Silver...
TI-nspire will not turn on
Yes we changed out the batteries on now the TI-84 will not turn on HELP
Nov 23, 2009 | Texas Instruments TI-Nspire Graphic...
How do I change the language from spanish to English? My calculator is in spanish..my guide book is in french and English. How do I change the language setting? I have a TI-84 + silver Edition! Thanks!
Turn your calculator ON. Press the [APPS] button. Scroll till cursor reaches Spanish or Espanol, highlight it and press [ENTER]. The launch screen for the App gives you the choice to set
1:Espanol as the language, or
2: English.
Obviously you select 2: and press [ENTER].
Hope it helps.
Oct 05, 2009 | Texas Instruments TI-84 Plus Calculator
Havent used my ti-inspire since last school year.wont turn on
Here is what the TI knowledge base says about a calculator failing to turn on
For the TI-Nspire™ Family:
  1. Remove thekeypad (for TI-Nspire) or the battery door (for TI-Nspire CAS) andremove at least 1 battery from each column of batteries. After 2-5seconds, reinsert the batteries and turn the unit on. This will causethe unit to reboot the operating system.
  2. Remove the keypad(for TI-Nspire) or the battery door (for TI-Nspire CAS) and remove atleast 1 battery from each column of batteries. After 2-5 seconds,reinsert the batteries and LEAVE THE UNIT OFF (do not turn on and thenback off). Hold down [Home] [Enter] [P], and while holdingthese keys, press [On]. The device will boot up as in the previousreset, but will display a menu with the following options. Please tryoptions 1, 2, 3, and 4 in that order. ** The [Home] key is located atthe top right of the TI-Nspire keypad and has a picture of a house onit.
Note:TI-Nspire family model options 2 and 4 above require that the OS be installed. The reset menu will only display if the unit is off and batteries have been removed/replaced as described above.
1. Cancel - The most non-intrusive reset option; no changes are made, the unit restarts.
2. Delete Operating System – The operating system will be deleted without deleting any documents.
3. Delete Document Folder Contents – This will delete the user’s documents, but will not delete the OS.
4. Complete Format – This will delete the OS and all documents for a total erase of memory.
Hope it helps you solve the problem.
Aug 30, 2009 | Texas Instruments TI-Nspire Graphic...
My TI-nspire CAS doesn't want to go on! I changed batteries! Tried the contrast buttons! Nothing works
Try the other recipes from the TI knowledge base concerning a calculator failing to turn on
Jun 10, 2009 | Texas Instruments TI-Nspire Graphic...
Here is what the TI knowledge base says about a calculator failing to turn on.
Mar 08, 2009 | Texas Instruments TI-Nspire Graphic...
Changing from Spanish to English
In APPS, there is no option for English. You need to select another language (DANSK usually comes first), then select option 2 for English (option 1 will be the language you chose in APPS).
Sep 17, 2007 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-Nspire Graphic Calculator Logo
1,132 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
