My notebook toshiba portege m300 was dead. but when i push the power button the indicator power is on and there was nothing appear in the LCD
  • 2,567 Answers
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Posted on Sep 06, 2010
Toshiba Portege r200 was working normal (up until yesterday). Today, when I first turned it on, the fan was on and it sounded full blast, but screen remained dark (blank). I held power button until it shut...
The part that supplies the power to the screen is gone. I recall is is called the 'exciter'. They can be replaced, so take it to a computer repair shop. Same thing happened to my Toshiba.
Aug 18, 2017 | Toshiba Portege R200 Notebook
I have a toshiba m300 laptop and my screen goes black (but i can still faintly see the screen) or it is black as soon as i open it. it works again when i open and close it but i'm just scared it will...
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Sep 20, 2009 | Toshiba Satellite Pro M300-S1002X Notebook
How can i enter to the cmos set-up of my toshiba notebook portege r100?
when you press power button just press F2 OR MAY BE F10 AND ALSO YOU CAN TRY DEL BUTTON
Sep 07, 2009 | Toshiba Portege R100 Notebook
I got the right info about toshiba portege 4000 battery on http://www.adapterlist.com/toshiba/portege-4000.htm toshiba portege 4000 battery but i not sure whether it will fit my notebook or not.
TOSHIBA Portege 4000 Series replacement Notebook Batteries, buy Portege 4000 Series battery and other goods are brand new and one year warranty! ship to most countries http://www.power-tool-battery.com/notebook-battery/toshiba-portege%204000%20series-1001022.htm
Feb 18, 2009 | Toshiba Portege 4000 Notebook
Black screen
ur screen is out try hooking ur labtop up to a desktop monitor
Nov 27, 2008 | Toshiba Portege 7100 Notebook
Toshiba L20 - screen appears dead?
Try to plug in an external monitor on laptop to check if there is a problem with your LCD.
Plug in the external monitor then boot the computer. If still nothing happens try removing the battery and the adapter, let it rest for a minute then plug in only the adapter and try to boot up with out the battery.
Hope this helps.
Sep 13, 2008 | Toshiba Satellite L20-S310TD Notebook
Unlocking Toshiba Portege M300
Try logging in as Administrator with no password, if it says that account is disabled, reboot in safe mode (while the comptuer is coming up, hit the F8 key - then choose safe mode) and then log in as Administrator with no password. Then you can go to control panel and take off the passwords for the users.
Mar 28, 2008 | Computers & Internet
Toshiba Portege 4010
U need to test your battery, i think its dead or your battery charger is not ok
Feb 29, 2008 | Toshiba Portege 4010 Notebook
Dead Pixel in Toshiba Porteg? M600 laptop
Without rplacing the main part of the lcd, I'm afraid you're stuck.
Nice laptop. Toshiba service has always been reasonable in my experience.
Sorry I couldn't offer better advice.
Good luck
Nov 25, 2007 | Toshiba Portege M200 Notebook
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
