Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
My whirlpool refrigerator is leaking water from the top freezer down to the refrigerator. What is causing this?
  • Whirlpool Master
  • 2,694 Answers
Most likely you have a clogged drain,when the fridge goes into defrost it melts the ice off of the evap coil and it drains down to where the compressor is in the bottom section of the fridge,if the drain is plugged up the water will leak into the fridge section,take out all the food and shelves and remove the back wall of the freezer,if you know where the timer is or if it has a timer you can advance it and turn the heater on to help you out or unplug the unit so the fan isn't blowing or shut off the control,with a hair dryer melt all the ice,where ever you see styrofoam try not to leave the hair dryer in one place to long you can damage the styrofoam,the vents are under the fan,you can put a plate or something inside the fridge and pour hot water down the vents to melt out the ice if the vents have ice in them and it melts the ice faster and won't damage the styrofoam,now when you have the ice melted i use a steamer to clear the drain but if you don't have one you can use a turkey baster or a piece of hose and blow through it,anything you can think of to blow through the drain line,when you think you've cleared it pour hot water down the hole,if like a half a cupful goes down it's clear if it stays there it's not clear and you'll have to blow it out again,if you have any electrical wire with the ground wire in it you can use the copper wire wrap it on the heater or near it if it's a glass heater and when the heater comes on the wire will heat up and stop the drain from freezing in the future,stick it in the hole as far as it will go and leave a little extra so you can wrap it around the heater or like i said if you have a glass heater attach it to the metal frame as close to the heater as you can and you should be fine,they sell heater probes at the parts store also,let me know how you make out
Posted on Sep 07, 2010
  • 3 more comments
  • huppjt Jan 22, 2011
    Awesome information thank you
  • elaynecutter Mar 08, 2011
    I had to take out the bottom freezer panel first then the rear panel. It was so covered in thick ice I could not find the drain hole till the very end of melting it with the hair dryer. Took awhile to unplug the drain but with the turkey baster and boiling water; sucking out the cold and adding boiling it was clear and flowing. I put in the copper wire as suggested so now I'll see if that helps. Thanks so much.
  • Sal De Mar 11, 2011
    sorry i didn't get back to you but it sounds like you have everything under control,this is why i use a steamer,it's around 50 bucks,it cuts through the ice so fast.good job
  • jpmlmw May 31, 2011
    How does one remove the styrofoam to get inside
  • Sal De May 31, 2011
    what are you trying to fix?also if you can send the model number so i can look up your machine.are you talking about the drain block,the styrofoam between the freezer and the fridge?
SOURCE: frigidaire refrigerator leaking water inside refrigerator
There is a plastic panel inside the frigidaire looking at the underside of the freezer inside the refrigerator compartment which holds the thermostate dial and the light fixture. remove the four 1/4 in hex head screws holding the assembly. pull the panel toward the front. you will expose the drain hose connection you can let it dangle from the plug wires or remove the panel completely, I worked with mine in place. look at the back funnel shape drain. just in front of that see a rectangular styroform collar which should be snug fit to match the underside. clean and dry all. there is a divider between the two funnel compartments, mine was separated between the plastic and the styroform. I used kitchen and bath tub caulking to seal the gap. and a little around the rectangle shape that fits to the underside. plug the wire back in if disconnected. reassemble the panel. that may fix it. good luck.
Posted on Jun 17, 2008
aborcass
  • 2651 Answers
SOURCE: Amana 18 Top freezer Refrigerator-leaking water in refrigerator
the middle insulation hasbecome water logged, forma faulty defrost tube, so, every time trhe unit defrost, 2 maybe 3 times a day it will spill water inti the vents, andin to the refrig, the only correct way to fix is to have the enitre center drain block replaced, part not that expensive but labor to install may be, ohter then nussincence, not really affecting machines workings
Posted on Jan 11, 2009
SOURCE: WATER DRIPS DOWN FROM INSIDE TOP REFRIGERATOR BELOW FREEZER
Not an original solution - but a good one. Remove panels at the back of the freezer compartment to expose the heater unit or heater wire that defrosts the freezer coils and wrap a solid copper wire gently around the heater/ heater wire and place the loose end in the drain. This will conduct heat to the freezer drain and help keep it open. I did see a manufactured part in one of the appliance parts websites but it did not match my unit.
Posted on Jun 09, 2009
woodchuck789
  • 4070 Answers
SOURCE: Refrigerator freezer drains keeps freezing over, not plugged.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Take a bare copper wire and wrap it around a fin near the heater and put the other end a few inches down the drain. The heat convection may prevent it from freezing.
Posted on Jul 02, 2009
aasc
  • 1606 Answers
SOURCE: water leaks from top mounted freezer area into the refrigerator
Remove the food from the freezer and the icemaker if equiped . Remove the air tower at the rear of the freezer section and remove the rear panel inside the freezer . Using a hair dryer to the drip pan , below the coils ( probably ice ) , starting at the center , defrost until you see the drain hole . Keep defrosting the hole ( hot water helps ) until water starts to flow down . Using a short piece of hose , insert it into the drain hole and blow . This should blow out any debris inside the drain hole . I would use a short piece of solid ALUMINUM wire ( 14-16 guage about 8 " long ) striped of all insulation , and insert it into the hole as far as possible , without any force . Wrap the other end about 1--1 1/2 turns around the black tube ( defrost heater ) above the hole . When the heater comes on , heat will transfer to the aluminum wire and keep the drain from freezing up again . Reasemble back panel , air tower , and , icemaker . Reinstall the food and its FIXYA'd .
Posted on Sep 02, 2009
Testimonial: "Thanks for the suggestion. "
My Whirlpool ETIFTTXKO2 is leaking water inside the refrigerator. What is going on? What can I do to fix it?
is there a ice maker on this unit if there is its probably over filling the ice and leaking. Is there ice in the freezer it may not be getting cold enfough to freeze and that could be caused by a dirty coil in the back and under the fridge
Jan 19, 2012 | Whirlpool Refrigerators
I have a whirlpool imperial refrigerator; freezer on top; with icemaker....water is leaking from the freezer section down onto top shelf in refrigerator, near back, any help??
Hello and Welcome to FixYa!
Actually the leaking water is from the evaporator coil unit.... Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit....
The channel or tube is clogged and the water is leaking to the refrigerator unit, so you need to clear that contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the top shelf in the refrigerator compartment. This is all you need to do....
Best of Luck,
Please do Rate the solution, if you feel that this helps you,
Concerned.
Aug 10, 2010 | Whirlpool Refrigerators
My Whirlpool refrigerator is leaking and water is dripping on to the shelves and in the bottom of the fridge under the crispers. I had a guy from Cal Tech Services to look at it 3 times now and it still...
On a top-freezer when the drain stops up water will back up turning to ice and eventually filling the air ducks with ice blocking airflow to the fresh food section causing it not to cool. You will also see a water leak inside the fresh food section. To fix this, remove the evaporator cover, (back or bottom of freezer) and then remove all the ice. Once all the ice is removed, you need to unclog the drain. I do this by forcing hot water down the drain with a turkey baser but you can use any squirt bottle, I have even used the water hose. Once the drain is clear, mix water and baking soda and pour it down the drain to prevent this from happening again anytime soon.
Hope this helpout,
Jul 28, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
What causes water to leak into whirlpool regrigerator instead of draining through the hose when defrosting?
The drain is clogged. You can fix this yourself by removing the bottom panel of the freezer. (Where you stack the items on the bottom of the freezer). The pour VERY hot water down the drain. You will see a little hole in the very back
Jan 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
Whirlpool Custom Series refrigerator leaks -Model ET18JKXSN05
It sounds like the line you found is for draining the water from the defrost cycle. It should drain the water from melting the ice into the pan at the bottom so it will evaporate. Sounds like its being clogged is the cause of the water in your fridge.
May 13, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Freezer leaking water
My Whirlpool has been filling the bottom under the crispers with water and leaking out the vents (?) from the freezer down into the fridge compartment. I finally caught it today being rather loud, probably in a defrost cycle, and it was positively POURING in the fridge. After some more research on this site I removed the freezer bottom tray (1/4" ratchet needed) and found a layer of 1/2" thick ice under the tray. My guess is the drain hole iced up. Removed all the ice from under the tray and on the metal drain run in the back (danger, seemed sharp) and put it all back together. I didn't try to pour hot water down the drain yet, thinking positive thoughts that the drain itself isn't iced all the way to the tray near the floor. Will watch it carefully.
Apr 20, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool refrigerator leaks
the drain hole at the bottom rear is blocked. a pipe cleaner run down it should clear it out.
Apr 09, 2009 | Whirlpool ET8FTEXM Top Freezer...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
587 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
