Question about HP PSC 2110 All-In-One InkJet Printer
Glass removal How do you remove the glass to clean the under side?
  • d bruce May 30, 2008
    Where are the screws located and how many are there? I removed the control panel cover and the only screw I see is in the rear left corner of the top.
  • 21 Answers
Pry off the control panel, remove the scanner cover, remove all the screws (usually star type) then the whole top section should come off. You should clean the scanner mirrors while you're in there.
Posted on May 12, 2008
How to removed error E000202-0000 for ir 5800
unplug the copier .remove copyboard glass,slide scanner towards right side, under copyboard glass on left side rear corner there is a black sensor which will look the shape( 'F'-side view) clean the cavity between two horizontal arms of 'F' shape sensor with a soft painting brush(10 mm).replace copyboard glass ,swich on the machine.
Jan 21, 2011 | Canon imageRUNNER 8500 Copier
LHow to clean under side of glass plater
note where the dirt is located,unplug all wires from back, remove top hinged cover, undo 2 screws at the top, remove cover plate by gently tipping toward top, slide glass with plastic sides up and out, clean with approved cleaner, reverse to reinstall glass (plug in power cord prior to replacing top cover plate to check for any missed fingerprints or dirt on underside of glass), once your happy with cleaning complete the reassembally.
Oct 06, 2010 | Canon CanoScan D1230U Flatbed Scanner
Hello, i keep getting error #6 message on my printer...i clean the glass both top and bottom with a micro-fiber cloth with no results
What do you mean "top and bottom"? Are you removing the glass from a flat bed printer and cleaning the bottom side?
Please clarify if this is an all in one machine or provide the model number so I can give more detailed information.
If its an HP printer with a flat bed (printer that you place the paper on the glass in order to scan, copy or print) then the place you need to clean that it is refering to is not the glass where you place your document. It is a small square of glass that is usually under the rollers off to the side on top of the flat bed area. You should be able to put your hand under the hood of this area and pull upwards to release it. You will find the small piece of glass to clean under the rollers right there. Wipe it off and this should solve your problem. After wiping it, unplug the printer from the computer and power supply for a couple of minutes. Plug the power supply back in before connecting to the computer and allow the printer to warm up and then connect to the computer. This should remove the error code.
Sep 27, 2010 | HP Office Equipment & Supplies
Need to clean the under side of the glass. Need
I found a service manual on-line that showed the method for removing the glass on the scanner.
Nov 16, 2009 | HP Office Equipment & Supplies
C0f22 error code
Atomatic Intensity Density Cotrol sensor malfunction.
Clean the optical parts:lens,mirrors and original glass.Remove the OPC unit clean the AIDC sensor under drum in the rear side,use the vacuun cleaner for remove the used toner under cleaning blade,reasamly the unit.Clean the transfer and separator corona holders and wires and perform the F5.Enter in the service mode Stop key-0-Stop-1 Function menu ,place A3 sheets in the original glass place and perform F5.See the F code history and reset it.This code reset if you open and close the front door.
Sep 09, 2009 | Minolta EP4000/5000 CS/PRO Copier
Lines all over second page
It is possible to clean the inner side of the glass. First you need to remove the scan module by removing two screws on each side, then remove the cable. Carefully take out the module. You will notice 4 small screws in the side, after removing which you can detach the LED module. Remove the vertical screws and this will detach the Lens Module. Now you will have access to the inner side of the glass. Ensure that the electronics, the Lens module and the LED are carefully placed back and cable connected properly. There is a small spring plate screwed along with the LED module, which needs to be placed properly. Please do not use any sharp instrument.
S. Mohan, Chennai, India
Jan 28, 2009 | Canon DR-5060F Pass-Through Scanner
Disassembly of HP ScanJet 4470c.
You remove the panel that holds the control buttons by putting a small flat head screwdriver under the both outside edges (held by two small pins). Be carefull the ribbon cable does not unplug. After removing the two screws that are under the back hindge slots, the whole top pivots up and off of pins at the front. You feed the panel thru the hole left when you removed it. This frees up the top and the glass on both sides can be cleaned. Hold the glass up to a strong light to be sure it is clean before putting everything back in reverse order
Dec 05, 2008 | HP Scanjet 4470c Flatbed Scanner
Cleaning inside glass door, kitchenaid range
you do no tneed to remove the top to release the glass, yea aslong as the lower trim is removed then the only thing holding the glass, is the grease/sticky rubber gaket. lift up from the bottom slightly and twist out from the tabs. just be carefull when cleaning inner door glass, those "ridges in the paint, are just that paint, so dont use anything abrasive, youll ruin the finish!
Oct 30, 2008 | KitchenAid KGST307 Gas Kitchen Range
HP 6110 All-In-One Printer
there should be two screws on the right side of where the glass, take them out, some models you also have to take the screws off of the left side since it is one piece, lift the whole unit With the glass and set aside to clean. ( With power off)
Oct 21, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP PSC 2110 All-In-One InkJet Printer Logo
182 people viewed this question
Seeker5211
Seeker5211
