Question about Canon iP100 Portable Printer
I do not have CD slot in my computer to install the printer cd program
  • Canon Master
  • 6,487 Answers
In order for you to install the printer you need to download the printer software from this link and use that, just click HERE.
Posted on Sep 05, 2010
  • 6,831 Answers
Hello
OK, at the link below you will be able to download the driver requested. Just remember to choose the operating system you are using before you download the driver.
Click HERE.
Kind regards
Andrea
Computer is not reading the installation disk
By installation Disk do you mean the CD/DVD-ROM? If yes
Check to see if the drive's LED flashes when the system is trying to boot. If it doesn't, open the system and make sure all the cables to the CD/DVD- ROM is properly connected and to the right slots. If the cables are properly connect and the CD/DVD- ROM is still not working replace the CD/DVD-ROM.
However, if its that the system could not install a particular program, make sure the installation files are complete and try again. If its a downloaded program, verify the completeness of the file downloaded and try reinstalling the program.
Feb 13, 2012 | Peachtree Software Computers & Internet
Hello,everyone!! i have lenovo ideapad y560 with inbuild tv tuner & also a connector wire to connect dish cable to laptop... but my question is that how do i watch tv on my laptop OR in which...
Hi
TV tuner cards allow you to view programming on a computer system. Although desktop computers allow you to install internal TV tuner cards, laptop systems do not have the available space for internal cards. Because of this, laptop computers have PCI express card slots. This slot allows you to install and remove (at your will) additional hardware, such as TV tuner cards.
  • TV tuner card
  • Driver installation CD
  • Software installation
  1. Locate the PCI express card slot (located on the side of your computer opposite the disc drive). Push in on the protective cover on the slot to unlock it from the case. It pops out slightly, allowing you to remove the card.
  2. Slide in the TV tuner into the PCI express card slot. The card clicks into place and a light blinks on when the card has connected successfully to the laptop computer.
  3. Insert the driver installation CD into the disc drive of the computer. Momentarily a driver installation wizard appears on the screen. Click "Next" on the welcome page, then accept the given license agreement. Choose "Next" two more times, then select "Install" and the drivers from the driver installation CD install onto the computer.
  4. Eject the driver installation CD and insert the software installation CD. This is the program you use to view the connected receiver. As with the driver installation CD, wait for the installation wizard to load up onto the screen. Accept the license agreement, leave the installation name and location blank, then click "Install" to install the software.
  5. Restart the computer. Upon restart the laptop is ready to begin using the TV tuner card.
Jun 12, 2011 | Lenovo IdeaPad Y560 Laptop
I have a Gateway laptop that does not have a cd slot, but i need to install my Dell printer to it..how can i do this. it is saying it needs the CD that came with the printer to install
You don't actually need the CD, but just the installation software on it. You should be able to find what you need for download from Dell's support site. Once you have the software on your computer you can run it to install your printer. You can also use an external USB CD drive if you have the CD. Maybe you can borrow one from someone, or consider buying one. A USB burner isn't expensive, and you'd have it available if you want to make discs or install other software in the future.
Jun 03, 2011 | Office Equipment & Supplies
Says ocr application not installed and installed on cd
An "OCR" , or "Optical Character Recognition" program needs to be installed on a computer to which the printer is connected. These programs convert scanned text into editable documents. I'm confused about you meant about OCR being installled on a CD.
Mar 21, 2010 | Dell A920 InkJet Printer
Need software to install hplaserjet p1006
Kindly insert the PROGRAM CD in the CD ROM drive and auto run the aplication CD without connecting the printer,in few minutes of installation progress you will get alert to connect the printer and then printer is configured by OS Above is the normal procedure,
very minute but technical tip is to
connect the printer first and insert program CD for printer in the ROM drive and open device manager and scan for hardware changes ,you will get alert on task bar that new hardware is found and new window for device installation ,click continue with browsing file path for CD in drive and continue installation ,in next few minutes your device shall be ready to use. In case there is problem with installation with CD kindly go to manufacturers website and download windows compatible drivers.
For Safe Computing Kindly keep your antivirus updated and firewall is on.
Thanks And Regards
Kindly rate this solution
Mar 03, 2010 | HP LASERJET P1006 Printer
The computer is not reading the installation cd for the computer so i can't used the printer cause it is not installed.. can i get the installation program
if you have the printer cd,first uninstall all printer software,inplug printer also. take cd out restart computer.when redone rebooting ,reinstall cd,after complete installation restart computer,leaving cd in drive. when computer is booted back up again,plug in printer and you should be fine,if not go to control panel and on the left hand coner of your screen it should say add printer,click on that and follow the wizards step through.good luck.hope i helped u
Apr 14, 2009 | Canon PIXMA iP1600 Printer
Im trying to install a canon mp 360 to my computer
first have your installation cd ready. if you dont have an installer cd, go to canon website to download the driver. insert the cd and wait for the autorun or find the install/setup program on the cd. follow the instructions and when it says you plug the printer, that was the time that you will power up the printer and plug it to one of the avail usb port of your computer. once the computer detects it will continue the process and instruct you on what to do next. remember run the cd installer or downloaded installer first before plugging the printer.
Feb 17, 2009 | Canon Office Equipment & Supplies
Computer Won't Recognize Printer
This is a tough one. When you say that "My Device Manager isn't showing up any of my hardware..." does that mean that there are other hardware problems in the device manager? When you plug the printer in, how des it show-up in the device manager (ie: unknown device under HID)? Why did you "... recently reformatted my computer ..."?
Sep 24, 2006 | Brother MFC 210C All-In-One InkJet Printer
Canon iP100 Portable Printer  Logo
37 people viewed this question
old marine
old marine
