I have a Lexsor electronic safe which I can't open. It used to beep when I put in the code now it is just dead, nothing happeing. Do you know if there is a battery replacement somewhere.
Thanks.
Lucy
Hi there, I don't have the same problem but i have a lexsor safe and can't seem to find the pin code that came with it. Now the safe is locked and I can't open it. I assume that all safes have the same pin code when they are sold and then it is up to the purchaser to change it. Would you by any chance have the original pin code?? Thanking you in advance for your assistance
Norma
Solution #1
posted on Jul 30, 2008
Guest
Rank: Apprentice Rating: 0%, 0 votes
I am not familiar with Lexsor safes, but I have dealt with another brand. The lack of beeping probably means the internal battery died. Some safes I've seen have external power contacts that are used to restore power long enough to open the safe and replace the internal battery. Look to see if your safe has these; if so, it may require a safe/brand-specific device to restore power or it could be rigged with a simple battery. You'll need to find a manual for more information. If there is no way to power it externally, or it requires special equipment, you'll need to take it to a locksmith/safe-crack/keymaker (and it will likely cost you quite a bit)
Was this solution helpful? Show your Appreciation by rating it:
