Question about Eltax Hollywood Package System
Hi there.My eltax power tower subwoofer needs bass speaker replacement. Where can I get it?
4 Suggested Answers
SOURCE: Eltax speaker problems
I agree, NE Speaker is the BEST repair speaker shop in the eastern half of the USA. I have an EV 12" speaker re-built there and its better than it was before it was blown. Great job NE Speaker!!!
Leo B.
Posted on Oct 31, 2008
chromedragon
  • 16 Answers
SOURCE: eltax millenium 500 speaker problem
Some high end speakers have a fuse to protect the tweeter (treble). Reverse the speakers. Does the problem follow the suspected speaker? If so, the defect is most likely on the crossover inside the speaker.
What do you mean by best place to locate parts?
Posted on Apr 16, 2009
sonicboomele
  • 1557 Answers
SOURCE: Watching television or a film my Eltax Atomic
most active subbs are desinged to shut off untill they are needed ( extreem bass injection) then they come on try setting your sensitivity to low or off
Posted on Jun 18, 2010
Testimonial: "Thanks very much I will play around with that and see how it goes."
I have a replacement tweeter for an Eltax Liberty 5+ floorstanding speaker. I have removed the screws that hold the old tweet in place but can't seem to remove it? Any tips please?
Hi, The hole that was cut for the tweeter is holding the magnet. It was tight going in. And hard to get out. Take a flat screwdriver and pry up one of the edges a little. Then go to opposite side and pry up a little bit. You may need to put something in the gap of the first side you pry up so it doesn't go back in. Once you have both sides up a little bit. You should be able to grab ahold of it with your fingers and remove it. May have to move it back and forth .
Apr 02, 2015 | Eltax Audio Players & Recorders
I have jamo sub200. I connect to pioneer vsx-rs320k audo video receiver. when I turn the volume of subwoofer to a higher value with the receiver, the bass sound becomes distorted and not satifieng to...
hi,
Do one thing set the control behind the sub. set the level and cutoff control at it half position. Set phase control at "0" position. Then test the sound. if you ate using tower speaker as front speaker then you have to set the position of phase control 180 ,
ok
Apr 11, 2011 | Jamo SUB 200 Subwoofer
Unable to receive optimum output. The bass is totally flat !
Hi, ok the Bose Acoustimass III system consists of two small cube speakers and one subwoofer unit called the Acoustimass bass module. If the subwoofer stops working, three points can be the cause of the failure. The Bose Acoustimass III is a passive system, meaning the speakers do not power themselves, but instead are connected to a receiver or amplifier. Thus, the amplifier, the speaker between the amplifier and the subwoofer, or the subwoofer itself could be the issue.
Things You'll Need:
* Amplifier
* Speaker cable
* Extra subwoofer
Instructions
Disconnect the speaker cable from the back of the Bose Accoustimass bass module and connect it to a subwoofer that is known to be working. If the subwoofer works, the bass module needs to be replaced.
Disconnect the speaker cable from the back of the receiver or amplifier you are using and from the back of the subwoofer in Step 1.
Connect a speaker cable that is known to be working between the back of the receiver or amplifier and the back of the Accoustimass module. If the module starts working, then the cable was the issue.
Disconnect the speaker cable from Step 3 from the back of the amplifier or receiver, then connect the cable to the subwoofer port on the back of an amplifier or receiver that is known to be working. If the subwoofer works, the receiver was the issue. If the subwoofer still does not work, verify that the speaker cable is in the subwoofer port of the receiver/amplifier and that the cable is connected securely to the subwoofer.
If you think you did the connection properly,Fine... If not you can use the manual from the below link and know how to connect it properly..
products.bose.com/pdf/customer_service/owners/og_am5iii.pdf
Have a nice day..
Feb 19, 2011 | Bose Acoustimass 5 III System
How to setup an eltax surround system? what exact place do I put them (also behind me)? It contains 4 speakers, 1 sub-w, and 1"tweeter/high range" to put on your tv. I thank You sincerely!
Well, that is pretty dependent on the room size and seating position. Ideally the center channel should be directly under the TV. This is where 90% of the dialog will come from. The two tall speakers should then be placed adjacent to the TV, preferably a couple of feet away. The smaller surround sound speakers should be approximately ear level, to slightly above and behind the viewer. The surround speakers are bipolar, so they will radiate sound out of each side, therefore you do not need to "angle' them towards the listener. The sub woofer doesn't really matter, the bass frequencies are non-directional. I like to hide it under a table or something like that.
Some new receivers have built in surround set up programs that will send a test signal to each speaker and "listen" then adjust the delay and volume accordingly. Without that it will take some trial and error to get any system dialed into the perfect settings. Then what may be ideal for one specific location will sometimes not sound as good from another in the same room.
Good Luck.
Dec 24, 2010 | Eltax Chroma 5-Pack System
Hi there was a pop and burning smell from the box. I guess its bust but hope it can be repaired as I cant find a replacement anywhere.
Unfortunately it does sounds like there has been a system overload. Your speaker is an active system meaning it has its own power unit inside. Somewhere in the internal amplifier there has been a circuit burned. I have copied the link to the contact page for the stereo repair search website. If you will do a search for your state information, this site will locate a repair service near you.
http://www.stereorepair.com/
Oct 31, 2010 | Eltax Thunder 10 Subwoofer
Watching television or a film my Eltax Atomic a-8.2 subwoofer cuts in and out whenever it feels like it! you can hear it click then the bass cicks in then, even when you know there should be some bass...
Jun 18, 2010 | Eltax Atomic A-8.2 Subwoofer
Loud boom when going in standby mode.
i would check your sub connection also make sure the volume isnt set to high. sometimes unplugging the power and cables also helps
May 20, 2009 | Eltax Atomic A-8.2 Subwoofer
Eltax millenium 500 speaker problem
Apr 16, 2009 | Eltax Millennium 500 Speaker
Leo B.
Jun 23, 2008 | Eltax Audio Players & Recorders
Eltax Hollywood Package System Logo
102 people viewed this question
Top Eltax Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Eltax Audio Player and Recorder Expert? Answer questions, earn points and help others
