Question about Sport & Outdoor - Others
Won't start want to change fuel filter i think its in the tank
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
Replaced fuel tank now tractor won't start. It cranks good but just won;t start.
Probably have air in the fuel line not letting any fuel getting past, it will collect at the highest point..
If you have inline filter replace with a drill pump to suck fuel along pipe, or to force fuel back to tank, you will also need to fill the part that is post filter point
Sep 29, 2015 | Cars & Trucks
Won't start. Have I missed something?
Starter is good,battery and connection,Cap is good no cracks.
Apr 23, 2013 | 1987 Chevrolet Camaro
Why won't my new fuel pump in my 2002 kia sedona pump even though it's getting juice from the battery
Have you checked the injector rail with a gauge to know for sure the injectors are not getting fuel ?
If the pump is running but not pumping fuel I would think it is a clogged filter or screen in the tank.
Sep 04, 2012 | 2002 Kia Sedona
93 chrysler t&c awd changed fuel pump and filter, van ran fine again for about 2 months now won't start and don't hear the fuel pump. changed the oil pressure sending unit and still won
fuel pick-up in tank is blocked it has a sock over the end as a gross filter to keep out any big junk from getting sucked into the pump and causing damage to it. the sock can get so plugged up that no fuel will flow, causing the pump to run for a short time then with no fuel flow to cool it it trips the safety and shuts off
Aug 12, 2012 | Cars & Trucks
14" Mac Cat gas engine won't start. Changed spark
Check tank fuel filter. safe way, put hose on end of filter blow through hose, fuel should come out of filter easily.
Sep 04, 2011 | McCulloch Garden
I have a 2001 Chevy Malibu 3.1 Liter. I was driving it last night, and I parked it, everything was fine. 15 minutes later I had to go somewhere, went to fire her up, and it wouldn't start. It's...
Assuming there's enough fuel in the tank - If the fuel filter is extremely clogged - try starting with the fuel cap off so it won't have work against the vacuum in the fuel tank. Fuel caps have breather holes which can be clogged also. The holes release the vacuum in the tank slowly. If it starts ok then, the problem sits in fuel supply - for example the fuel filter.
Smell the exhaust pipe - if it smells strongly like petrol, most likely it's the ignition system requiring service. (sparkplugs, distributer, sparklines)
Jul 01, 2011 | Chevrolet Malibu Cars & Trucks
I ran out of gas I put 2 gallons in but the car won't start. It will tunr over, the lights come on, but the car won't start. Do you think I need to keep cranking it and add a can of starting spray...
sounds like when you ran out of gas, you clogged your fuel filter. Change your fuel filter and put a little bit more gas in it and she should fire right up. Hope this helps, James Booth. :)
May 17, 2011 | Volkswagen Jetta Cars & Trucks
MY 2003 toyota camry will turn over, but will not start and also do you have to drain fuel before changing the fuel pump
check the fuel pressure with a gauge first before jumping to the fuel pump as being the problem.if it is the pump and the fuel level is below 3/4 of a tank you won`t have to drain the fuel tank,as it will be lighter to lower the tank to gain access to the pump.have you checked for spark at the plugs and inspected the condition of the plugs.does your car need a tune-up,is the air filter plugged up,how long has it been since the fuel filter has been changed,it may be plugged.
Apr 14, 2011 | 2003 Toyota Camry
F150 fuel pump replacement
You could have rust in your gas tank, what will happen if that is the case is crank and run and when the rust gets stirred up it will clog your pump and filter. After a while it will kill your pump, and ruin your filter, and cause it not to crank at all. I would drain the tank and look at the fuel as it comes out if it has any red in it that is your problem. I had the same problem and that sounds just like my problem. I hope that helps you out.
Nov 10, 2008 | 1990 Ford F150
Sport & Outdoor - Others Logo
43 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
