Question about Yamaha 12V Air Pump
Looking at a 2001 XL800, is there any specific thing I should be looking for, common problems ect.?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 118 Answers
Notorious for broken power valves, simple compression check should tell you unless both are broken, if there is a 15 to 25 psi difference between the 2 cyl chances are the one with higher comp is bad. Those valves change the port timing and are controled by the ECM. In short, the higher the EX port the lower the comp and vice versa IE the lower the port the higher the....
Posted on Sep 10, 2010
I have a 2001 Yamaha 2 stroke XL800. It idles fine but when I go to full throttle it stalls and after that it will start but will stall continuously. Any ideas, thanks
Sounds like it could be fuel related.
When it stalls take a look at your fuel filter to see if its empty or not.
Jun 12, 2018 | Boating
I have a friend that is haveing a prob with her 2001 impala cylder 6 is miss firing and she replace the plugs and wires. what should be then next step or thing we should look at?
Hi, it depends on the type of misfire code. Please see my tip at http://www.fixya.com/cars/r6715318-causes_gasoline_engine_misfires . These are genericinstructions. If you get stuck or need specific instructions for your car, please get back to me with model, year and engine info.
Aug 05, 2011 | 2001 Chevrolet Impala
My check engine light is on, code po302 keeps coming up when scanned.
it's P0302 actually, not the letter "o". That will help you TREMENDOUSLY when looking for answers online.
Click on THIS LINK to a very commonly used and helpful site for all OBD-II code problems (the link is for your problem specifically). Hope that helps!
Please rate me too! Thanks.
Feb 02, 2011 | 2001 Mercury Grand Marquis
I have a 2001 XL800 .Last used end of july. Tried to start today 11/28/10. New battery. No lights on instrument pannel comes on and won't start?
Since you have replaced the battery, check the primary fuse.
Please take a moment and rate my answer..... Thanks
Nov 29, 2010 | Yamaha 12V Air Pump
Looking to find out what Volvo error code 1633 means
Code 1633 is not a manufactures code, it is a genetic one, and is not as specific as a volvo code.
The best thing to do is take it to a volvo shop and get the specific code.
I did find a meaning for it------- speed signal missing or absent.
That could mean either a wheel speed sensor, or a vehicle speed sensor is at fault, that's why you have to get the specific code.
May 14, 2010 | 2001 Volvo V70
Yamaha Waverunner XL800 question? Should the servo motor for the tpvs run or cycle when the mechine is first turned on? I'm looking at a used unit and when fired up out of the water (idle) the sero moto...
The YPVS motor should cycle one time approximately one minute AFTER the engine is shut off. This is a clean out cycle to scrape loose carbon off the exhaust valves.
Apr 06, 2009 | Yamaha 12V Air Pump
I just purchased a used 2001 Yamaha XL800 waverunner
Yes. Those are called power valves. The purpose of those valves is they create a variable height on the exhaust ports. This is desirable because it gives you good low RPM power by keeping the height of the exhaust port low, and as the revs of the engine build, the exhaust valves raise up which opens the exhaust port up and allows the engine to create more peak HP due to the higher exhaust port and larger area of the exhaust port.
There is no additive that will clean your power valves. They have to come out.
Win xp various add remove programs missing remove
Hello, you would not want to remove something from the registry editor to uninstall something, One thing you can do it to locate the folder the program is installed, this will commonly be the C drive and then the Program Files folder, inside there you should see the folder name that matches with the program your looking for, inside you may find an uninstall file there. If not you can delete the folder but it may cause startup issues.
Mar 08, 2009 | Dell Inspiron 1200 Notebook
Looking for engine mounts to purchase 4 Ford Focus ZX3 2001
You can get these mounts from www.rockauto.com ANCHOR Part # 3003, $25.79 each, these are the lower mounts.
Sep 18, 2008 | 2001 Ford Focus
Hi, my name is April. I'm having some problems with my pickup, and I need some advice. What's going on is this morning when I started my pickup, it seemed that it heated up too quickly. Within 20 minutes,...
Your ECT (engine coolant temp.) sensor sounds like it's bad. Check your coolant level and make sure it's full. The ECT sometimes triggers and engine light most don't. This is a very common problem with Chevy trucks.
Jul 14, 2008 | Chevrolet Silverado 1500 Cars & Trucks
Yamaha 12V Air Pump Logo
133 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Craig Butler
Craig Butler
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
