Question about Char-Broil Electric H2O Smoker
Brand new Brinkman Gourmet electric smoker and grill ran it 8 hours first day this morning tried to use it again...breaker trips each time I plug it in. Smoked a brisket yesterday. I have used different heavy duty extension cords and different plugs. Can you help me.
SOURCE: Tripping Circuit Breaker
Same problem I have. I think the element or thermostat is gone. You will have to replace them. Here are the part numbers repectively:
4501649
4160214
Posted on Jul 05, 2008
SOURCE: Need electric plug for smoker
go to home depot and get the replacement element for the brinkmann gourmet smoker. costs $29.95. the replacement parts from charbroil (thermostat and element) will cost about $60.00. just remove the elemnt, replace it with the brinkmann and you're back in business.
Posted on Aug 16, 2008
SOURCE: Tripping the electrical Breaker
I have used the charbroil bullet electric H2O smokers for years (wore 2 out - currently on my 3rd). I won't use anything else (having used many, many others - HOWEVER - as with every product made there are things to watch or overcome. Learn to use it properly and look forward to many years of great BBQ.
Ambient (outside) air temp below 70 (depending on wind also) will affect these smokers drastically - highly recomend getting or making a "smoker blanket" (got mine at cabelas years back - if you can't find one welding blankets from an industrial supply store can be made into one) to insulate the sides - this drastically reduces heat loss and reduces the electrical load.
Another MAJOR mistake many people make is extension cords - avoid the use of them at all if possible - if not possible then purchase the heaviest gauge you can find.
Always pre-heat your smoker - Always use boiling water (or other liquid) in the H2O pan added after smoker is pre-heated - Always minimize opening the smoker once cooking has begun.
The heater element can be cleaned when cold with a very mild detergent and room temp water.
If you have the large 2 rack but are only smoking enough to use a small amount of rack space on only one rack remember that you are heating a whole lot of air - i have a couple (different size) wood boxes wrapped in foil to take up excess air space - this means less air volume to be heated and better heat control - DO NOT use cardboard boxes or other low temp combustable items in the box construction!
Make sure the house outlet you are plugging into is a 3-prong GROUNDED outlet on a 20 amp breaker.
Finally, make sure your smoker is level and remember there can be up to a 20 degree cooking temp swing in temp between the bottom rack and top rack (top rack 5-20 degrees hotter than bottom).
The heater element will cycle on and off during normal use.
Good smoking and enjoy.
Posted on Nov 24, 2008
frcs68
  • 1605 Answers
SOURCE: Need help smoking briskett on Char Broil Grill with smoker box
wood chips in the fire box. very low heat. around 200 degree.
maek sure the wood chip is wet and produce smoke. you need to monitor this through out the process.
briskette in the grill side without any heat. depends on the sixe and the thnikness of the meat, you need approximately 12-20 hours before meat become tender.
here are few web site you can get some information
http://www.smoker-cooking.com/howtosmokeabrisket.html
http://bbq.about.com/cs/brisket/a/aa111503a.htm
http://www.wyntk.us/food/smoking-brisket.shtml
http://www.bbq-fyi.com/how-to-smoke-brisket.html
Posted on May 29, 2009
  • 16 Answers
SOURCE: i just got my charbroil offset smoker and i have
Use approximately 5 lbs of charcoal or a little more that a chimney charcoal starter and let it go grey and get your grill to the temp you are looking for then add the pecan on top of the charcoal in the fire box.
Posted on Apr 04, 2010
Have brand new 810-3330-s brinkman grill main igniter is receiving no gas, is there a screw to adjust flame?
BEWARE: DO NOT TRY SUCH HAZARDOUS TRICKS YOURSELF AS LOCATING A SCREW TO ADJUST GAS PRESSURE. CONTACT THE DEALER OR AUTHORIZED CUSTOMER CARE.
Mar 29, 2014 | Brinkmann Brinkman Barbecue Grill Gas...
Eeaf smoker keeps tripping off
Hi sally mako...
Make sure your breaker is strong enough to handle the ampreage draw of the smoker element.
Try a different receptical with a known larger breaker...
If still kicks the breaker, then remove the electric plug from the receptical and check all connections on the element and controls to make sure they are not corroded or broken and shorting out.
Please take time to rate me
Sep 24, 2011 | Masterbuilt 20070106 Electric Smoker
I do not have manual for using brinkman gourmet charcoal smoker
Hi tsanelli...
I could not find your user manual on the net, but I have this..
To use your Brinkman Smoker or Other Smokers
1... Marinate or place a rub on the meat you will be smoking, and let it sit for a few hours or over night in the refrigerator.
2...Cover your wood chips with water(and if you wish you can add some Jim Beam Whisky or other flavorfull liquids in a bowl with the water, 1 inch above the wood chips and use a flat peice of metal (pie pan,etc.)to weigh the wood chips down underwater.
3...Start a fire in the smoker having the fire below the meat, use hardwood or charcoal,
Once they are coated with gray ash, you can place the meat on the racks.
I would place an aluminum drip pan under the center portion of the cooking area on your smoker, to catch the juices from the meat.
4...Place the meat in the smoker on the grilling surface, and place the wood chips over the charcoal and hardwood in the main grilling area Close the lid and do not open it unless you must add wood chips during the cooking process.
5...Continue adding wood chips to the tray as needed during the time you are cooking.
If you have a Brinkmann or other smoker with one chamber for placing the wood chips and the meat, add wood chips only once per hour.
6...Apply your sauce to the meat one hour before the meat should be done.
Test your meat with a thermometer for for an internal tempreture of 160 degrees for medium and 170-180 degrees for medium well to well
Note: Apply the sauce quickly to avoid loosing the heat in your smoker if you leave it open too long it will allow the heat and smoke to escape, increasing the cooking time.
Close the lid if it needs to continue cooking till you reach the right internal tempreture
7...Test your meat with a meat thermometer after a few hours of cooking time.
Make sure your meat is at least 160 degrees internal tempreture for medium and more than 170 degrees for medium to well.
Close the lid and maintain your heat if it needs to continue cooking.
Please take time to rate me.
Aug 27, 2011 | Brinkmann Smoke 'n Grill Double-Grill...
Grill will not turn on
I assume you are referring to the auger motor. If so, have you checked the electric receptacle the g=auger motor is plugged into? Plug another electric appliance, like a lamp into the receptacle to see if the lamp works. If not, look for a tripped circuit breaker in your home's breaker panel. If one is tripped, make sure nothing is plugged into the offending receptacle and reset the breaker. Plug the auger motor back in to see if the breaker trips again. If does, there's an electrical issue with the auger motor or the cord.
If none of the above is the problem, i have included a link to Traeger Industries website. There you can find and download the Owners Manual for your Grill-Smoker, which also has a Trouble Shooting Section.
http://www.traegergrills.com/
Feb 21, 2011 | Traeger Industries BBQ070 All-in-One Grill...
The auger on my 9 yr old grill has stopped and my family is not happy! I do not have a Mr Fix-it husband so am on my own. Any suggestions?
Make sure that there electric power to the auger motor. If it's plugged into an exterior wall outlet, unplug it and plug in another electric device (like a lamp) to make sure that outlet still works. If it doesn't, go to your home's Circuit Breaker Panel and check for a tripped breaker. If you find one that's tripped, reset it and try plugging in the auger motor and turn it on. If it starts working then suddenly stops, it probably tripped the circuit breaker again. That would indicate one of three things: The cord from the auger motor may be bad; the auger motor itself may be shorting out; the circuit breaker may be failing. If it's the receptacle or the circuit breaker, I'd advise you contacting an electrician to have them check and replace it. for the Auger Motor, go to Traeger's website home page and look for Trouble Shooting or Customer Support. Better safe, than sorry.
Hope this helps solve your problem.
Feb 08, 2011 | Traeger Industries BBQ075 All-in-One Grill...
My electric smoker keeps tripping breakers
My Brinkmann 810-7080-4 Gourmet Electric Smoker was tripping my GFI after it sat for the winter. Would heat for about 3 minutes then trip the GFI. would keep tripping GFI until it cooled down and once again would trip after about 3 minutes.
--SOLVED: took 00 steel wool and olive oil to the heating element and removed what looked like a green fungus. Element is working fine now, not tripping the GFI and will run a full four hours for smoking!
Hope this helps save someone some money in purchasing a new heating element ($40).
Nov 26, 2009 | Brinkmann Smoke' n Grill Electric Double...
Where to purchase replacement electric burner for brinkman model 810-7080-k.....????
You can spend approx $35 for a replacement element at
http://www.brinkmann.net/shop/Detail.aspx?category=Outdoor+Cooking&subcategory=Charcoal+Smokers+%26+Grills+Replacement+Parts&sku=116-7000-0&series=CGS-7080-K&seriesname=Gourmet%20Electric%20%28810-7080-K%29&id=72
Aug 07, 2009 | Brinkmann 810-7080-K All-in-One Grill /...
Last summer closed up grill had no problems..today not working
unhook the tank and hook it up again being sure that the regulator is right side u p.
these new grills have a safety valve that often partially closes and causes problems.
Apr 27, 2009 | Brinkmann Charmglow 810-7400-S Propane...
Brinkman electric smoker
The pan for the wood chips is a round shallow (1/2 or so high) pan, about 8 inches in diameter, that sits right on top of the heating element. The element doesn't get too terribly hot, so you could probably substitute a foil pie plate or even a double wrapped package of aluminum foil with some holes punched in the top. When you see the smoke - its time for the meat!
Good eats!
Pat
Jun 29, 2008 | Brinkmann Smoke' n Grill Electric Double...
4501649
4160214
May 27, 2008 | Char-Broil Electric H2O Smoker
Char-Broil Electric H2O Smoker Logo
55 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Jim Thurston
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
