I need a manual for a bosch WFK2801 - Washing Machines
3 Suggested Answers
SOURCE: washing wont spin or turn but takes water in and pump out without spinning
Electronic door lock faulty.Replace
Posted on Nov 05, 2007
  • 159 Answers
SOURCE: bosch wfk2801 yellow spots on washing
That sounds like oil but there's nowhere the oil would be coming from except the rear bearing but that would be more of a grey or black colour.Is your fabric softener yellow.it could be fabric softener.try not using any for a couple of loads & see.I don't know if the dots are washing off but fabric softener stains will normally wash off.oil won't.
Posted on Jun 04, 2010
Bosch wfk2801 manual
Best place is to contact Bosch direct, they will often email a copoy free of charge
Apr 07, 2014 | Washing Machines
Our bosh wfk2801 has started to squeak badly from inside of the drum- sounds like it needs oiling - ! Any ideas? Thanks Ben
Check if there is any object such as a nail or some of that nature sticking thru the spinner drum that could touch the outside drum
Dec 05, 2010 | Bosch WFK 2401
Bosch wfk2801 yellow spots on washing
Jun 04, 2010 | Washing Machines
I need a bosch WAS24466GB user manual
click on the link below and download the manual,if asked you will have to enter model number or else you can download user manual directly from the link:
bosch user manual
thanks.
Aug 31, 2009 | Bosch Washing Machines
My Bosch wfk2801 has died and keeps blowing fuses, I've changed the carbon brushes & no change, every time i turn it on it seems to be struggling - the motor moves a little, then crackles a bit then...
hi there.......from your description of the fault it would appear that your motor is short circuit.....remove the plug from the motor replace the fuse and switch the machine on...if the fuse dosent blow replace the motor..be careful its also possible the control module is also damaged
regards Sir Galahad
Aug 18, 2009 | Washing Machines
Bosch wfk2801 washing machine drum does not rotate
Remove rear panel and check the belt is o/k, if it is, then remove belt, undo 2 bolts that hold motor, unplug the motor connector, lever motor back with a screwdriver, and remove motor.
Check the brushes, they should be at least 5mm long, \any shorter, then replace.
Plz rate my solution.
TRhanks.
Jan 11, 2009 | Bosch Axxis+ WFR 2460 Front Load Washer
Manual for Bosch WFB2005
PLS I NEED A MANUAL FOR BOSCH WFB 2005
Dec 23, 2008 | Washing Machines
Washing Machines Logo
376 people viewed this question
Top Washing Machines Experts
