Question about Maytag MDE6200AY Electric Dryer
The dryer is not heating. I suspect the heating element is shot. Is this likely the problem? How easy is it to replace the part?
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
KENMORE DRYER JUST STOPPED HEATING UP WHAT CAN I DO TO REPAIR IT?
Replace the Heating Element. The heating element is usually located behind a panel on the back. To replace you will need to remove the back cover of the dryer, then locate the heating element. The heating element is screwed into place and is easy to unscrew and replace. Be sure to have the dryer unplugged while doing this.
Here is the part for it:
http://www.repairclinic.com/Kenmore-Dryer-Model-11060602990-ID-501912-Heating-Element-Parts
Mar 13, 2013 | Dryers
Kenmore dryer not heating
Heating element is the usual suspect but there are also a couple of sensors that could go bad. Very easy to replace and fix. Remove the back of the dryer and it will be right in front of you with about 3 or 4 screws holding it on. Should have the part number on it as well.
Sep 28, 2012 | Dryers
My kenmore 600 dryer will not heat up, what could be the problem?
No heat problems are caused by several things.
First lets do the easy thing and turn off the Dryer CB by pushing it HARD to off and then back on. Re-test for heat.
Next try different cycles as in Air Fluff, Delicate, regular etc... Air fluff is no heat but see if it heats on other heat temp selections. If you get heat on a different heat selection then the problem is probably an open thermostat. If you still get no heat the most likely suspect is the heating element. If the heating element is fine then your looking at the motor switch or wiring as the problem. Component of last resort to replace is the timer.
At this time I suspect either a high limit thermostat or an open heating element.
Mond you since you did not include your complete model number this response if for an electric dryer. IF your dryer is gas respond with a model number please so I can point to other things that cwill cause a no heat symptom.
Thanks for choosing FixYa, Kelly
Aug 04, 2011 | Kenmore 600 6962 Dryer
Heating is not hot
Either the wires to the heating element have burned out, the heating element is shot, or the temperature sensor is shot. Unplug the dryer and check the heating element for continuity, check for burned wires between the relay and the coils, and check for continuity across the cold temperature sensor. Replace any defective parts.
Dec 01, 2009 | Frigidaire GLER341A Electric Dryer
I have replaced the heating element and cycle thermostat on my electric dryer but it still does not heat
have you checked the hi-limit switch on the heating element case, then the one shot thermal fuse in the line also
Nov 17, 2009 | Roper REX4634KQ Electric Dryer
Dryer runs, but no heat. Is there a heating
No heat is not always an element. It could be the thermal fuse (check this first), a thermostat or a leg of your 240VAC missing. Replacing an element is relatively easy depending on ones mechanical abilities. Depending on the model it is accessable from either the front or the back. Back one is easiest.
Eric
Oct 12, 2009 | Kenmore 62602 Electric Dryer
Kenmore Dryer, Model # 11063102100, does not dry.
Does the drum still turn. If so probably just needs a new heating element. VERY easy to replace. Usually instructions to replace on or in new element box or just google instructions.
New heating element would be my first move to repair dryer.
Also, if you use softeners or dryer sheets, Wash lint screen with dawn and soft scrub brush to remove oils and residue (even if it dont look like there is none there there is) to extend your heating element use.
Sep 26, 2009 | Dryers
Motor does not turn
if coils is heating are you sure motor isn't running or just the drum not turning ? if drum not turning suspect belt ..if motor not running but element still heating suspect element is contacting outer case ..with coil touching case 110 volts is present even without motor turning if timer is turned to heat position element will not heat to capacity but will get hot enough to eventually blow element fuse
Dec 19, 2008 | Dryers
GE Dryer
NO the heating element comes with the whole unit.
May 11, 2008 | GE DSXH43EAWW Electric Dryer
No Heat
more than likely that u have blown heater element u can test your element with a power cord connect it to the live earth and neutral and plug it in and element should heat up if not it will be your element that has blown
Dec 29, 2006 | Hotpoint TDC32 Electric Dryer
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
