Intertherm rooftop air conditioner problem
I am trying to figure out a problem with an older Intertherm roof top air conditioner that has a heat strip installed.The air conditioner seems to work fine with all the fan speeds but when I attempt to turn on the heat, it feels like there is some heat there but fan either only blows out very low or none. This is on a houseboat that has two of these and the other unit seems to blow fine with heat strip on. I do not know if the is a heat strip failure of some relay or control problem or what. Also if you can diagnose can you tell me where the best supplier of parts for this brand of unit. Do not have the model # [sorry] but do know the boat is a 1983 and I am quite sure it is original.
  • 828 Answers
With two units of the same make and one works right and the other does not you can use an OHM meter to check the resistance through the heaters on the good one then compare it to the readings on the one which is not performing. NOTE: with the power off of course.
Posted on May 13, 2008
How to remove Heat strips from intertherm furnace to make an air handler? Wiring schematics
WHAT??? Removing heat strips does not make an air handler. Air handlers have heat strips, please explain
Jun 17, 2017 | Intertherm Heating & Cooling
How do I know if my intertherm sch-rv a series roof mount air conditioner has heat
The thermostat will have a setting for heat if the unit has a heater
Nov 15, 2014 | Heating & Cooling
Intertherm feh 015ha
either the heat strips, fusible links on elements or sequencers.
Sep 21, 2013 | Intertherm E3EB010H Electric Furnac
My Intertherm heat/ac in my camper does not heat. a/c works great, but no heat. Any ideas??
The electric heat strips inside the unit could be burnt out or the thermistor that contols HI limit could be open.
Apr 29, 2011 | Dometic Rooftop RV Air Conditioner
Intertherm ac roof top ac fan want turn
Try turning it by hand to make sure it isn't seized up. If it won't turn replace the motor. If it will turn, check the capacitor for the fan motor and replace if necessary. You can also verify you have power going to the fan motor.
Sep 06, 2010 | Dometic Rooftop RV Air Conditioner
How difficult / expensive is it to install a heat strip in a Dometic roof top AC? The unit I have has a mark on the knob for heat, but I suspect it was never installed.
Fairly easy. The only thing that you must figure out is how many amps the heat strips will draw. Make sure the fuses and the breaker switch can handle them. And be aware your electric bills will shoot up.
Oct 20, 2009 | Dometic Rooftop RV Air Conditioner
Intertherm furnance chimmly icing up
it sounds like there is a restriction on top of you're flue pipe top, not allowing the air to escape in a normal way, ike bird nest, leaves or the position down on the pipe.
Jan 30, 2009 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
199 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
