Question about Electric Razor Pocket Rocket Ride-on Motorcycle
The bike never gets to full speed and fades fast
  • 15,935 Answers
This is a battery problem. It needs replacement. There is likely a dead cell. Usually this happens from improper charge or not fully discharging.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 05, 2010
Buy a new charger and new battery. There's a big chance it will start working again.
Posted on Jul 08, 2013
What is the top speed of a 2002 Honda CR250R 2 stroke?
The only figure I could find was 70 mph. But from all the research, what the bike is known for is power and reliability. It is also extremely strong and can take a tremendous pounding. It is right up there with the comparative Yamaha'sn Suziki's and the KTM. Good ,uck.
Apr 08, 2011 | 2002 Honda CR 250 R
Hi, my 2003 suzuki epicuro has top speed problem. It only reaches top speed of 70 km/hr. During its top speed, the engine was like choking or like a car that has speed limiter that achieve it top speed....
i have this problem too iv changed front and back variators and rollers iv tryed 13g and the standard 10g but still can only get 52mph i have a friend who has the same bike and it does 75mph and when i get to 52 it feels like theres a electroninc device comeing in like a fade in power kind of feel its nippy up to that point i have a Giannelli full pipe on will this be the problem ??
Dec 09, 2010 | 2001 Suzuki Epicuro
When I first start my 99 electra glide classic, it idles at about 1k. If I then blip the throttle, the idle drops to about 400 rpm. It remains there until I ride for about 20 minutes. Then it stays at...
If your bike is fuel injected, this is typical. What is happening is the fast idle is keeping your engine running until you blip the trottle. When you do this, the fast idle relaeses the idle speed control. Once the engine gets to full operating temp, the idle speed is correct.
Good Luck
Steve
Oct 26, 2010 | 2001 Harley Davidson FLHTCUI Electra Glide...
1995 kawasaki 750 jet ski overheats when going fast
Check your plug color. You may be having a high speed mixture problem. Is your ski spitting water out the tiny hole on the side? You should try flushing the engine, you could have a motor full of sand if you beach the craft but do not wash the sand out of the back before starting. Also inspect the engine water tubes for cracks. From the hull to the motor and from the hull to the jet pump.
Aug 26, 2010 | kawasaki Full Suspension Mountain Bike Men
How to play the text animation with out clicking
AVI video file of animation
To create this animtion, follow these steps:
  1. Insert a text box from the Drawing toolbar (in PowerPoint 2007, go to Insert tab> Text Box), and type your text. Center justify itthe text by clicking Center on the Formatting toolbar. (In PowerPoint 2007, right-click the text box and choose Center from the mini toolbar.)
  2. Click the text box's outline and copy it to the Clipboard. Paste it two times onto the slide.
  3. Drag the three text boxes apart from each other. Eventually, you'll place them on top of each other, but it's much easier to select them when they're separated. Notice that I have a plain white slide and one word.
  4. Change the properties of the text to create variations. I used 96, 72, and 48 point text, with light gray, dark gray, and black colors. Of course, if you want a different effect, you can do something different.
  1. Choose Slide Show > Custom Animation (in PowerPoint 2007, Animations tab> Custom Animation) to display the Custom Animation task pane.
  2. Select the first text box and choose Add Effect> Entrance> Fade. (If you don't see the Fade animation, click More Effects to find it.) Set the Speed to fast. Leave the Start as On Click (the default).
  3. Select the second text box and choose Add Effect> Entrance> Fade. Again set the Speed to fast, but this time set the Start to After Previous.
  4. As soon as the second text box comes in, you want the first one to fade out. So select the first text box again, and choose Add Effect> Exit> Fade. (You may need to choose More Effects to find it.) Set the Speed to Very Fast and the Start to After Previous. (I discovered by trial and error that I wanted the Speed set to Very Fast; otherwise, you wait too long for the third text box to come in.)
  5. Next, you want the third text box to fade in so select it and choose Add Effect> Entrance> Fade. Set the Start to After Previous and the Speed to Very Fast.
  6. Finally, you want the second text box to fade out, leaving just the third text box. Select it, and choose Add Effect> Exit> Fade. Set the Start to After Previous and the Speed to Fast.
Note: You can always change the order of your animations by selecting an item in the Custom Animation task pane and dragging it to a new location or using the Re-order buttons at the bottom.
  1. Save your work and test the animation to see what it looks like. Either go into slide show view or click the Play button in the task pane.
  2. To center the three text boxes on top of each other, select all three text boxes. From the Draw toolbar, choose Draw> Align or Distribute> Relative to Slide. (In PowerPoint 2007, choose Format tab> Arrange group> Align drop-down list> Align to Slide.)
  3. Now choose Draw> Align or Distribute> Align Center. (In PowerPoint 2007, choose Format tab> Arrange group> Align drop-down list> Align Center.)
  4. Choose Draw> Align or Distribute> Align Middle. (In PowerPoint 2007, choose Format tab> Arrange group> Align drop-down list> Align Middle.)
Save and try out your animation!
Fade in variations of text, one on top of the other plus magnify
You can add another animation to your objects to increase the intensity of the animation. For example, try adding a Magnify entrance effect to all three text boxes. Set the speed the same as the Fade In animation and place the animation in the task pane right after the Fade In. Set the Start to With Previous. You can see how it looks.
AVI video of both animations
Typewriter text
You can make text appear letter by letter; to add to the effect, you can add a typewriter sound. You can see the animation here. Sorry, I couldn't include the sound.
AVI video of typewriter text.
Follow these steps:
  1. Add a text box from the Drawing toolbar (in PowerPoint 2007, go to Insert tab> Text Box), and type the text.
  2. Select the text box.
  3. On the Custom Animation task pane, choose Add Effect > Entrance > Appear.
  4. Click the animation item in the task pane. Click the down arrow and choose Effect Options.
  5. On the Effect tab, choose By Letter from the Animate Text drop-down list.
  6. Set the delay between letters. I chose 0.3 seconds.
  7. From the Sound drop-down list, choose Typewriter and click OK.
Try the animation. I had the following problem -- there was no clicking sound for the last letter. That might not bother you, but it bothered me. I solved the problem by adding another letter at the end of the word and making it the same color as the background (so that it was invisible). This worked!
0010101 GIG hacker 1010101
www.gighacker.blogspot.com
Feb 02, 2010 | Computers & Internet
Printer display reads 'waste ink near full' and print quality is fading fast.
Those are 2 different issues, the waste ink absorber when it shows full will not print until it is changed and the count reset by a shop. The quality fading could be a printhead issue or even just a good cleaning of the cleaning and capping unit.
Jan 29, 2010 | Canon SmartBase MP360 All-In-One InkJet...
How fast can you ride the m50 w/o over reving the
Motorcycles and cars are designed so you can't over rev the engines in high gear. Air resistance will keep your speed low enough so the engine can't over rev. However, in a lower gear, you CAN over rev. If you don't have a tachometer on the bike, read your owners manual for suggested top speed in each gear. Or do a Google search for your bike and and "speed" and "gear".
Sep 07, 2009 | 2005 Suzuki Boulevard M50
Jet
if bike is fast up to 20mph then sounds like jet ok, speed is limited by gearing and this is controlled by the variator, the pulley half that moves is controlled by the rollers which you've just fitted. sounds more like a problem there. when the engine speeds up, the force of gravity spins out the rollers which moved the pulleys together, as they come together they squeeze the belt out effectively making the front pulley larger and increasing the gearing. if the rollers can't move or the pulley is jamming you will be stuck at a speed determined by where the pulley is.
Aug 14, 2009 | 1979 Yamaha XS 650 SF
Radio fades in and out
does it do it when you drive fast and slow down
are your windows open
deos it fluctuate with the speed u r driving
Dec 11, 2008 | 2008 Ford Focus SE Sedan
Speed
Speed of the GS 500 F is 115 MPH but I had my bike up to 200 KPH and still had room on the tach thats 124 MPH not bad for a 16 year old design
Nov 10, 2008 | 2005 Suzuki GS 500 F
Electric Razor Pocket Rocket Ride-on Motorcycle Logo
719 people viewed this question
Top Electric Toys Experts
Robert A. Watson
Robert A. Watson
Tom Chichester
 Russ Hill
Russ Hill
Are you an Electric Toy Expert? Answer questions, earn points and help others
