Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Whirlpool Refrigerator Ice maker quit working
  • 9 more comments
  • Anonymous May 25, 2008
    ice maker will not crush ice in crush mode. Fridge makes funny noise in regular ice mode
  • Anonymous May 26, 2008
    changed filter and still not making ice
  • Anonymous May 28, 2008
    no water. replaced water relay but still no water. maker makes all the running noises but no water. is there a way to call for water manually?
  • Anonymous Jun 22, 2008
    Everything seems to be working fine except for the ice maker - it just stopped working the other day! We've tried everything too!
  • jkamrath Aug 08, 2008
    Same as everyone! Water is great, no ice? Everything is turning in the ice maker, but no water is injected?
  • pshart42256 Aug 23, 2008
    First of all there was water all over the floor. Now there isn't any water coming out to make ice. The ice maker still works. I replaced the filter. Still no water comes out. But water still comes out for drinking. What next. Thank you
  • wrestling83 Nov 24, 2008
    Water started pouring out the icemaker side and after it stopped no water would come out. Water dispenser side works fine, but now no ice is being made. No water coming out for icemaker.
  • Anonymous Dec 07, 2008
    ice machine does not work
  • Anonymous Feb 02, 2009
    ice maker is not working. water from dispencer is fine. auger is turning fine.
  • Anonymous Feb 05, 2009
    ice maker not working water dispenser working fine
  • MarHov Mar 05, 2009
    Ice maker quit making ice.
I just found the answer to the same problem on mine.
You need to remove the ice maker on the left hand side there is a square cover, under the cover is a plastic gear the piece holding the gear in the center is partly broken and the gear has switched teeth. When I replace the gear in the proper position it worked just fine, I ordered the gear holder that is partialy broken $41.00 will have it in a week.
Hope this helps.
Rick
Posted on Mar 17, 2009
ICE MAKER NOT WORKING REPLACED THE FILTER IN BOTTON OF FRIG,NO LUCK. ARE THERE ANY OTHER FILTERS IN THERE?
Posted on Jun 16, 2008
  • MRTUGG Jun 16, 2008
    water in the door works great just no ice. no water getting in the ice maker...help
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 28, 2010 | Whirlpool 21.8 cu. ft. Side-By-Side...
Ice maker quite working
heatman101
Sep 17, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Ice maker quit working and is causing ice build up on the back of the freezer
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 20, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Model ED2CHOXK005 Whirlpool refrigerator with ice maker the ice maker quit working still puts ouf water but no ice
The problem is most likely your water control valve for the ice maker. There are 2 one for ice maker and the other is for the dispenser. Fill your ice maker with tap water. Let it freeze and if it dumps and does not refill then the water control valve part number 2188542 let me know if you need more help, Sea Breeze
http://servicepartstec.blogspot.com/
Aug 19, 2009 | Whirlpool Refrigerators
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side by side refrigerator, model # ED25PQ
Under the right side of the fridge in the back there is a dual valve for water and ice. Try changing it out, most likely the ice side is not working. Make sure you unplug the unit first
Nov 19, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
what happened you reset the computer (mother board) chances are you had a brief glitch in your power and it made the computer go hey wire
Dec 15, 2007 | Whirlpool ED5FHEXMQ Side by Side...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
237 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
