Question about Zoom ADSL 5554 X5 Router (5554-00-00)
Router Zoom adsl lights : What is the Lan IP Address for this modem? Thx
The default Lan Ip is 10.0.0.2
Posted on Apr 06, 2013
4 Suggested Answers
  • 9 Answers
SOURCE: ADSL Router wont get ip address from operator
sir if your ISP account is PPPoE or using username and password to connect, try to open your router using web interface configuration, locate your account and try to disconnect then connect.  hard reset afterwards(on/off the device)
if your using a dynamic account, try to RESET your modem and do the hard reset.  check your IP using command prompt, to do this type ipconfig /release, when it releases to zeros, type ipconfig /renew to have your IP's back...check internet connection then
Winsor
Posted on Sep 02, 2008
jsbasrao
  • 54 Answers
SOURCE: TRENDnet TEW-432BRP router cannot obtain IP through DHCP
it seems that ur PC & cable modem configuration is ok, now the problem is with ur router WAN interface configuration. the problem would be one out of 2 - first to check whether ur router wan interface is configured properly to obtain IP address from DHCP (if possible, u can give the static ip address with same series as cable modem) second to check with ur ISP.
Posted on Mar 20, 2009
arvinds88
  • 108 Answers
SOURCE: Belkin F5D8236-4 Wireless Router will not connect
1) With direct connect with modem, check the IP address and default gateway.
(I came across such a modem, it gave default gateway as 192.168.1.254)
I also had the doubt of configuring as a dynamic connection
But it won't work!
Contact your ISP to completely bridge the modem and configure the dsl modem as PPPoE connection with correct username and password.
Finally connect the modem to router and do a complete network power cycle, i.e.: Unplug power from router 1st, then power from modem, unplug the telephone line and now do the exact reverse process... Plug back the tel. cable, then power to modem... now WAIT for lights on modem to come back, then plug in the power to router. This will surely work.
Posted on Jan 15, 2010
MR814 does not get IP address from my ADSL modem
try power cycle modem to clear out the computers onfo then it should connect to the router
Aug 10, 2012 | NetGear MR814 Wireless Router
I have no internet connection when i connect my adsl router with enhwi g2 router in WAN, then from lan1 connect my pc. Please solve my problem. Tnx
First test to see that you can connect to the Internet by connecting directly to the modem.
If yes, then check that the cables are connected correctly and that the LEDs are on. (Just a check :). Telephone line to LINE IN on modem then Ethernet/Cat 5 from LAN port on modem to WAN port on Encore router, then Ethernet/Cat 5 cable from LAN port on router to PC.)
Use browser (Internet Explorer, Safari, Mozilla) to connect to web interface of router (make sure your TCP/IP settings on PC are set to obtain IP address using DHCP).
Open browser and type in the IP Address of the router (192.168.1.1 is the default) where you usually type in the name of the website you want to go.
Go to the LAN Interface Setup page (you are now inside your router).
Change the IP Address from 192.168.1.1 to 192.168.89.1 (leave the subnet mask as it is).
Change the DHCP Client Range from 192.168.1.100 - 192.168.1.200 (the default) to 192.168.89.100 - 192.168.89.200.
Click on Apply Changes button.You may lose connectivity to the router, but you can reconnect by typing in the new IP Address 192.168.89.1. You may need to renew the IP address of the PC, but that can be easily done by rebooting the system if it doesn't happen automatically.
Let me know how you go, or leave a message if you still can't connect. I would ask that you tell me the model of the ADSL modem however.
Cheers
Dec 17, 2010 | Encore 802.11G WIRELESS LAN ROUTER...
No Internet via zoom X6 wireless router to desk top, lap top ok.
Access your zoom router by using the laptop which still has access to the router.
Your going to have to open your Wireless Network Connection Status window located under your network settings.
If you see this window your going to left click the (details) button
Now you should see a IP DNS server address
for example: 192.168.1.xxx
Type that address onto the address bar of your web browser.
it should take you to your router setup page.
There you will need to check if the lan port is enabled
Feb 04, 2010 | Zoom X6 Adsl Modem/router Rohs...
Our modem will not connect to the router, the lan activity light will not shine... unless we connect through to modem. Our modem is Comtrend ADSL PPPOE.
You have to chage the router ip address other than the modem ip. The modem is 192.168.1.1 change your router to 192.168.9.1
Nov 21, 2009 | D-Link DIR-625 (790069292637) Wireless...
ADSL ISP provides same address for IP and Gateway
Can you manually change the WAN IP on the router?  If so, give it an IP like 123.12.167.5 and set the gateway address to 123.12.167.1.  If it asks for a subnet mask, give it 255.255.255.0.
If she has a Linksys router, you may need to change the operating "MODE" on it.  A lot of Linksys routers have 2 modes of operation---Router mode and Gateway mode.  For her configuration, make sure the Linksys is in Gateway mode.  This will fix the NAT problem.
Cheers!
Mar 26, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Can't access Config Manager for Router - Zoom x6 5590
- Reset the router (10 seconds)
Access the configuration page (10.0.0.2)
or
Try to assign a static IP address to the computer (IP 10.0.0.52 Automated SubnetMask, Default gateway 10.0.0.2)
(Note: Make sure that your computer is physically connected to the LAN ports of the router and your modem is connected to the WAN or Internet port.)
Mar 08, 2009 | Zoom X6 Adsl Wireless Gateway Rohs Router
Zoom adsl x6
If the Internet light is off it means you are not either authenticated at your provider or your configurations are wrong on the modem. If you go to your command prompt and type ipconfig and check your IP address and your default gateway. The IP address on your default gateway would be your router put that IP address on your browser and should be able to see your modem setting and any error messages that could help resolve your issue
Feb 18, 2008 | Zoom X6 Adsl Modem/router Rohs...
Need Zoom X6 help unresponsive
make sure your ethernet port is set to 'obtain address' and 'DNS' automatically (IE use DCHP and not static IP address) The software should be able to 'find' the zoom modem then.
Jan 22, 2008 | Zoom X6 Adsl Modem/router Rohs...
Router instalation
this should be set up using a lan cable, installation cd and not wirelessly initially while being set up. you may need to check that the lan card adapter on your pc is set to obtain an ip address automatically in its tcp/ip properties. you should also be able to access the router through your web browser by typing 10.0.0.2 for quick start instructions click below http://www.zoom.com/documentation/adsl/5590_QuickStart_Eng.pdf
Sep 16, 2007 | Zoom (5590-00-03) Wireless Router (G66115)
Zoom ADSL 5554 X5 Router (5554-00-00) Logo
66 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
