I have a Whirlpool top loader that runs beautifully until it hits "rinse." Often it just stops completely, with the tub remaining full of water. If I turn it off, then on again, setting the dial in the middle of the rinse cycle, it will sometimes drain and spin... other times, it makes a clicking sound for a couple of minutes, then, nothing. When it does run completely through all cycles, I detect what seems to be a slight odor of burning rubber (?) maybe. HELP! thanks
  • 15,935 Answers
The timer has failed. There is no other "fix" besides replacement.
Thanks!!
Posted on Sep 05, 2010
Whirlpool top loading washer won't fill completely
did you shorten the stand pipe for the outlet drain ?if not try putting a short extension on the top .
Nov 18, 2017 | Whirlpool Washing Machines
Whirlpool washer stops after agitation cycle
Maybe check the belt is it cracked worn or fibers showing if so replace it
Jul 26, 2009 | Whirlpool Washing Machines
Washer stopped after wash cycle
The lid switch is the culprit. Push down on the lid it should start. It needs to be adjusted . the tab on the lid is not activating the switch. Try triming the door bumpers.
Apr 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Spin cycle not removing enough water from clothes
your manual states that it can be caused by cold rinses and or spin cycle not getting completed. please try to rinse in hot or warm and see if that does not solve your problem
Dec 20, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
My washing machine wont drain fully _ Help
Looks like the drainline is partly clogged.Hence it is not able to complete the drain cycle before the timer kicks in. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port.
Jul 14, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Wahser top loader
possibly cold water should be running into the tub at the same time as the cold to regulate the temp.by only having the hot on, it could possibly have timed out and while still being short of water
Jul 08, 2008 | Whirlpool LSB6200KQ Top Load Washer
Hot water continues to run after rinse, filling tub overflowing
sounds like you are right the water inlet solenoid on the hot side is sticking remove the hoses and clean th escreen out and the valve try agin with a fill on hot to see if it stops on a small load if not replace the water inlet valve
Mar 15, 2008 | GE WVSR1060A Top Load Washer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
