Question about Hauppauge WinTV-HVR-1250 MC - White Box (DHHAUP1187CN) TV Input
I need to change some information on the configuration menu from Clear QAM digital cable to Analog TV (cable). I am running WinTV for the first time and because I can not get a TV station I need to access the Device Setup Wizard again.
    Guru:
  • 377 Answers
Go through this link i hope you will get what you want
http://www.hauppauge.com/site/support/support_faq_wintv6.html
Posted on Sep 05, 2010
Ematic AT102 How do you program it to receive the cable channels when no cable box is needed?
Unfortunately, the Ematic AT102 does not have a tuner for cable television. It only has a ATSC (digital over-the-air) tuner. You need to connect it to an TV antenna and then search for channels. Depending on where you live, you may need an external antenna to get sufficient signal strength to receive local channels. See http://www.tvfool.com for signal strength information in your area.
Older cable signals are NTSC (same as analog over-the-air). Newer digital cable is QAM. (Some channels are broadcast as clear QAM which don't need a cable box with some tuners/TVs.)
To record your cable, you will need a different type of DVR/set-top box. An old VCR or DVD recorder with an NTSC tuner would work to record analog cable. There are a few ATSC converter boxes that also support clear QAM. This is one of the models: http://www.solidsignal.com/pview.asp?p=CM-7003 .
I wish that I had better news for you. Other options are available for NTSC, ATSC or QAM tuners. Please add a comment with more information about your cable service if you'd like extra information on these options.
Feb 23, 2017 | Televison & Video
Can a dta be used with cable antenna?
Most cable systems provide digital channels in a QAM format where Broadcast is in the 8VSB format. The RCA unit makes no mention if it is able to demodulate QAMs and should not be expected to. In addition, most cable QAMs are encrypted and need an addressable converter supplied by your cable system to view. A lot of cable systems provide local broadcast stations in the "Clear QAM" format and are not encrypted and viewable with digital televisions that support the QAM format, (most do). Most over the air broadcast DTA converters do not support the QAM format and will not demodulate the cable QAMs.
Dec 15, 2013 | RCA DTA-800B1 Digital To Analog...
Does my tv have a QAM tuner
The Polaroid FLM-323B does not have a QAM (clear digital cable) tuner. It only has NTSC (analog) and ATSC (digital OTA) tuners. Retrevo has the manuals for the Polaroid FLM-323B here: http://www.retrevo.com/support/Polaroid-FLM-323B-TVs-manual/id/279ag018/t/2/ . You will need to enter a code to access the PDFs.
I wish that I had better news for you.You will need a set-top box if you want to watch digital cable.
May 21, 2012 | Polaroid FLM-323B Television
No problem, I just want to know if this tv has a digital tuner? It says it has a "digital comb filter". Is that the same thing?
A digital comb filter is not a tuner. It helps improve the appearance of digital content by splitting the luminance (brightness) and chrominance (color) of a digital video signal (DVD, or other set-top box). This filter is only needed when digital content is going to the TV over RF (coax) or composite (analog) inputs. http://electronics.howstuffworks.com/tv-buying-guide18.htm has some details on the filter,
Please provide the model number of the TV for additional information about the tuner. Normally the tuners will be listed as NTSC (analog), ATSC (digital), Clear QAM (unencrypted digital cable) in the US. In other countries you have PAL (analog) or DVB-T (standard definition digital terrestrial) or DVB-C (standard definition digital cable) signals.
I hope this helps.
Apr 15, 2011 | Televison & Video
Do I need a convertible box with the new sanyo dp32640
You don't need a digital to analog converter box. The TV has NTSC (analog), ATSC (digital) and Clear QAM tuners.
I hope this helps.
Nov 26, 2010 | Televison & Video
I am trying to hook up a digital labs, 19'' lcd tv/dvd combo and when i do the initial channel scan it doesnt pick up anything from the satelite at all, i have hooked them toghther anyway i can think of...
Most HDTVs have ATSC, QAM and NTSC (analog) tuners. It sounds like yours does not have an NTSC (analog) tuner. QAM tuners only pick up digital cable channels. You may need to switch to your cable company's digital service if your not already on it. Call your cable company for further info
Dec 26, 2009 | Televison & Video
No channels scan in
you have to use an old fashioned set of tv top rabbit ears with a uhf loop just like the good old days if you have cable hooked up it will not work..
Nov 08, 2009 | Hauppauge WinTV-HVR-950Q TV Input
How can i watch cable tv.
I assume you are not trying to steal service, that you just want to use your cable signal on a TV without using a cable box. The NTSC (analog) and clear QAM (digital) signals will work on many recent TVs. Encrypted signal require a box from your cable company. BTW, the cable company are not allowed to encrypt local channels but will certainly do it for all premium channels and may do it for all digital channels except the locals. This assumes you bought a TV with QAM.
-Ken
-Ken
Jul 28, 2009 | NEC LCD4215 42 in. LCD TV
Rca 14" truflat
This set was made before it was required to have digital tuning built in. You would need a digital converter box if you want off-the-air reception. (The federal program at www.dtv2009.gov that is giving $40 coupons toward purchasing a converter is out of money right now and is only putting people on a waiting list. It also looks like the changeover to digital is going to be delayed again, so you might not need to worry about it for a while longer.)
Feb 06, 2009 | RCA 27F534T TV
Connection Hauppauge WinTV HVR-1250 tuner?
you are not going to get anything once you disconnected from the provider. It is the same thing as just pull the cable from the wall.
you can get TV signal (normal basic-brocasted) by using the roof top antenna, I don't know what kind of antenna will be require after 2/09. when the TV broadcast change to digital signal. but in the mean time, you need a converter box from analog to digital for the TV.
Nobody want to pay the monthly fee. if you have the equipment, you can set up the receiving station from the satellite. then you don't have to pay anything. As far as I know, no body have such equipment. cable company spend millions of dollars to set them up, so you have to pay for it.
Jul 04, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Hauppauge WinTV-HVR-1250 MC - White Box (DHHAUP1187CN) TV Input Logo
114 people viewed this question
Top Hauppauge Televison & Video Experts
Iqbal Husain
Iqbal Husain
Julie Endres
Are you a Hauppauge Televison and Video Expert? Answer questions, earn points and help others
