Question about Honeywell HZ-510MP Ceramic Heater
Once the heater gets hot it won't restart for a long time. whats the fix ??????? thanks charlie
  • 120 Answers
Most likely the thermal overload is defective and kicking off.when it resetts it will work again..it needs replaced
Posted on Sep 05, 2010
  • 3 Answers
Posted on Sep 06, 2010
My heater do not blow hot
along with what Charlie said I would do a reverse flush on the heater core. junk can build up in the core overtime and reduce if not eliminate the flow of coolant/heat.
flush it with low pressure multiple times in both directions when vehicle is cold.
Feb 24, 2015 | 1998 Honda Accord
My dyson hot fan will not give out air under 24 degrees?
Hi Charlie, it's Jack at Dyson.
When you adjust the target temperature of your Dyson Hot fan heater (shown on the LED display on the base), you're setting the target temperature you would like the room heated to. The actual temperature of airflow produced by the fan heater will not vary.
If the heater won't run below 24 degrees, this is likely to be because the temperature of the room you're in is equal to or warmer than 24 degrees. The heater will only turn itself on if the temperature drops below 24 degrees, and once the room temperature reaches this target once again, the fan will turn itself back to monitoring mode.
I've attached our Getting started video below which shows how to adjust the temperature, using the remote or the controls on the base.
I hope this makes sense. It sounds as if your machine is working correctly, but if you'd like any further advice from our experts you can reach us at 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 01, 2013 | Dyson Hot Heater Fan AM04 - Blue
Portable patio heater is a DCS Phoenix Professional Patio Heater Model PHF8-DWBZ-L. Burner ignites and operates for a few minutes. Then teh flame is reduced to a short yellow flame. Regulator is covered...
The regulator covered with frost is the problem. It freezes the gas and the gas line up. But, usually this only occurs when it has been exposed to subfreezing (in the teens) temperature for a long period of time. The quick fix, is to soak a bath towel in hot water, ring it out and quickly wrap it around the regulator. Once it thaws, the gas will start flowing again and you can light the burner. Generally, once it's flowing and being used, it won't freeze up again, right a way. Most propane companies add ethanol to the propane in the winter, to help keep it from freezing in the lines and the regulator.
Hope this helped answer you question and provided, at least a quick fix solution.
Apr 21, 2011 | DCS PHFS Phoenix III Outdoor Patio Heater
My 2004 rodeo ac/heater fan is not working. once in a while it will. i need to know where to search for my fan and/or connections. Plus in summer my condensation leaks in the passenger side of truck. Need...
Replace fan motor and resistor at the same time to fix it. A bad fan motor will burn out a resistor. Clean drain tube at bottom of evaporator case
Jan 02, 2011 | 2004 Isuzu Rodeo
Rheem hot water heater problem
If by the hot water over flow valve you are refering to the T&P valve. It is activated by high temp. or high pressure. It is possible that when you flushed the lines it caused this to open. It is also common for these once open to get a little debris in them and cause them to continue to leak. Sometimes you can open and close them a few times and get them to reseal. Other times you have to replace them. Hope this helps.
May 07, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Led flashes all the time heater won't start
some how the hot and neutral became reversed,i don;t know if it happened when a breaker sparked in the box or what . i reversed the hot and neutral at the input of furnance abd it is working at this time.
thanks for your help
Nov 24, 2008 | Goodman GMS90703BXA Heater
Honeywell HZ-510MP Ceramic Heater Logo
87 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
