Question about Refrigerators
My Refrigerator temp is on max it is not cold but cool and it is but 10 years old?
  • 15,935 Answers
Things to check:
Damper stuck closed (failed solenoid or iced up damper).
Defective defrost timer or adaptive defrost board.
Defective thermostat.
Low refrigerant.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
Refrigerator temp too warm. Have adjusted to coldest setting. Problem is getting worse. Condenser is clean. Fridge is 13 years old.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 16, 2011 | Frigidaire Refrigerators
Hi, my Kenmore is 10 years old. Refrig isn't cold. Freezer temp is okay. Checked manual to check temp. Doesn't adjust. Now everything spoiled. Does it need new compressor?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | Kenmore Refrigerators
I have a Hotpoint, model # Hsm25gfre sa, that is cooling and freezing unevenly. Everything onthe bottom half of the freezer is frozen and the top half is thawing. Also, the water in the ice maker is not...
Make sure that the freezer fan is working and circulating the cold air. Then check the damper assembly to make sure that cold air is being circulated into the refrigerator. And lastly make sure that the self defroster is working - if not the evaporator will freeze up, freezer temps go up, and ice maker will not work if freezer temps are 10 degrees or higher. A digital refrigerator thermometer will confirm freezer temps being high.
Aug 26, 2017 | Hotpoint HSM25GFRSA
Why does freezer get cold but not refrigerator side?
Check the freezer temp (available in most grocery and home improvement stores). The temp should be between 0-10 degrees F (not just barely below freezing).
You can also try to find a solution on www.repairclinic.com or click here.
Aug 13, 2009 | KitchenAid KSRG25FKSS Side by Side...
AC,DC, gas RV fridge Dometic
You more than likely need to replace the control cable between the upper and lower board. It comes as a kit with the upper board. You can also do a bypass test by unplugging your thermoster from the circuit board. The thermoster is the temperature control for the refrigerator nothing to do with the freezer.
rvtech@myway.com
www.coachtech.info
734 777 6432
Jul 26, 2008 | Dometic NDR 1292 Refrigerator
Whirpool conquest refrigerator-about 8 years old-not cold enough
  • if it does not cool at all then i would suspect the start switch on the side of the compressor or the compressor itself.
  • if the previous repair included tapping into the freon line then it could be the freon leaked out.
  • if the thermostat was bad then the refrigerator fans would not be running,
  • and if the defrost timer was bad (stuck in defrost = not cooling) then the fans would not be running.
  • i don't know of any bad history with this particular model
  • double check the back wall of the freezer to make sure there is no buildup of frost, because this would be a defrost issue.
  • if it is getting a little cold but not cold enough then let me know the temps
Jul 05, 2008 | Refrigerators
Refrigerators Logo
74 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
