Hi i have this samsung la32r71bdx LCD tv and i am having a problem with its sound control as everytime i try to increase my volume from tv mannually it automatically decreases it to 0 volume ( the tv remote is also not working ever since this problem started ) as if TV is fighting back with me. any help would be really appreciated thank you..
likha
  • 790 Answers
SOURCE: Sound Problem
ok paola! the problem is the headphone connector inside the TV.. maybe did not turn back the switch to speaker mode. check the headphone connector (at inside the tv). small problem goodluck paola!!!
Posted on Sep 14, 2007
  • 98 Answers
SOURCE: Won't turn off, and won't respond to remote or side panel.
I think that better to check the cables of S/W module.
Please check the s/w board placed in or chipped by bracket.
If nothing wrong with external appearance, then need to replace the IR module or Main Board.
Posted on Feb 24, 2009
SOURCE: Samsung LCD Flat Screen TV LN-S2651D - Volume Problem
I lived with it for about six weeks, then took the back off the TV. Just now it seems to be fixed, but I don't know if it will last.
I disconnected the wire leading to the channel up/down, volume up/down and source board, turned on the tv, turned it back off, reconnected the cable, and everything seems fine now.
Posted on Mar 14, 2009
  • 1779 Answers
SOURCE: TV won't stop changing channels
Main board needs replaced !
Posted on Jul 03, 2009
SOURCE: sound volume fluctuates
You may need to replace the Tact (push) Switches. These are the small buttons that are pressed when a control button is manually pushed on the TV set. The thing with this is you will need to replace all of the Tact Switches. Simply replacing the switch that corresponds to the issue might not solve the problem. The other issue is finding replacement parts. I recommend partstore.com. From there they can recommend a part if the one you need is no longer available. If you have a remote controller for the tv, you don't have to replace these parts, just remove them from the circuit board. Just make sure you don't remove the remote sensor :)
Posted on Mar 02, 2010
How do i fix volume problem , i have samsung 46 inch lcd , picture working fine but no sound?
Hi is your television running through a foxtel box or something else that has volume control, If so you might have one or the other turned all the way down, turn both volumes up and control every thing through one remote control.....
Mar 15, 2016 | Samsung LN46B550 46 in. LCD HDTV
Poor quality sound - low volume on Netflix. Everything fine on regular TV programmes.
You have to go to the sound mixer on your PC and increase the volume on Internet Explorer, Microsoft Silverlight also.
To find the mixer try clicking on the speaker on the taskbar.
Mar 05, 2014 | Samsung LA32A450 32 in. HD-Ready LCD TV
Volume bar stands at 200 every time i start my Samsung LCD
set the volume down extremely low power the tv down by plugging out and put on again should be then at set volume,the tv's now days have memory so it should start up at volume preset
Dec 21, 2013 | Samsung LN-S2651D 26 in. LCD Television
Volume working
Code for NEO 1451 TV?(universal remote control)
Aug 14, 2013 | Samsung TV Remote Control
I have a Harmon Kardon HK 3370 Stereo Receiver and a Samsung LCD LE40C530F1W. When I connect the stereo Aux jack to the LCD Audio jacks ( red and white rf cables ) I get no sound out via the receiver.
Obviously make sure your stereo mode selector is set to AUX and the volume on the stereo is turned up at least a little when you test it.
If you still have no luck then try increasing the volume on the TV as well. You may have it set so that the level of the audio signal leaving the rear output connectors on the TV varies with the TV volume. That way if your TV volume was turned down or muted when you tested it, then you would not hear anything coming through your stereo.
There should be a setting in the AUDIO OPTIONS menu of your TV where you can switch between a VARIABLE AUDIO OUTPUT and a FIXED AUDIO OUTPUT level.
With the FIXED audio output level, you control the volume of the TV audio coming through the stereo speakers with the stereo remote only.
Otherwise it should work.
Good luck.
Jul 16, 2011 | Harman Kardon HK 3370 Receiver
Poor sound quality
A new LCD TV has expansion sound capabilities requiring adjustment to acheive viewer experience. First, the TVs default sound is what is heard soon as the powered on. Tempering with the remote controls volume fucntionalities to achieve adjustment suitable. The volume feature on the remote produces adjustment either reduceable or increasing sound magniftude. Hower, the LCD TV is capable of producing extensive qualility sound with separate devices that generate sound. For example, acquring an external speaker system mentionable as home theatre system has already build blusting capabilities requirements. Once an external home theater sould producer devices are connected to the LCD TV, the expansion capability is increased. For example, the home theatre devices have woofers as bass magnifiers, tweeters as sound impression magnififers, and additionally, speakers with magnifier capacities. The LCD TV is designed to accomodate any extenal devices only mentionable example as the home theater sound sytems acquirable at retail. LCD TV sound capacities are capable of being modulated by using the remote control to access the settings areas on which sound is alteratered. Consult the LCD TV user guide for additional details on manipulating audio sound functionalities.
goodluck
Jan 08, 2011 | Vizio M370VT 37 in. LCD TV
Volume/sound will not increase up on my Samsung HL61A650
If the volume indicator appears and respond as you increase the volume but the sound does not respond, there might be a problem on the audio section.Ask for a repairman to check it. If the indicator does not respond, try using manual control instead of using remote control.Also some units have features to turn speaker off or on. Go to menu scan for audio check if it is turned off or on.
Oct 21, 2010 | Samsung HL61A650 TV
Samsung 46 '' HDTV 1080P --------no sound
what is the complete model number of your tv?
does the volume control display pop up with a headphone or speaker sound on tv mode?
Mar 20, 2009 | Samsung 46 in. Flat-Panel LCD HDTV
Hi, I have a samsung le32r74bdx lcd tv and the volume has just gone to 100 and i can't turn it down?
First, start by unplugging set to try to reset. Then make sure that all settings in audio menu are correct. Also look for stuck volume up button on set and on remote. Sometimes buttons get lodged under surrounding frame. Also try to push volume down button on tv and watch for display on tv to see any change. If when you release button volume increases by itself, remove batteries from remote to eliminate it as cause. If nothing you try works expect to replace main pcb. You can probably price it online with model number. Good luck, Russmann.
Jun 09, 2008 | Samsung Televison & Video
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
