Question about Troy Bilt Walk Behind Chipper/Shredder/Vacuum 205cc
Troy-bilt 8 HP Briggs no spark. Oil level full, safety switch connected. sat 4 months but ran fine last time used. Wont even tingle a finger at the plug wire.
#1 Taper
  • 1040 Answers
SOURCE: Can't find the oil drain plug on Troy Bilt with 5.5 Honda engine
You may want to look under the deck. They sometimes put them there. And if it is a self propelled, you will probably need to remove or loosen the plastic cover that protects the self propelled belt.
You are looking for a nickel sized plug that has a square peg. Use an extension piece for a socket set if you don't have the proper plug removal tool.
Jim
Posted on Jun 21, 2009
steve_lima
  • 181 Answers
SOURCE: Describe your Troy Troy-Bilt® Briggs and
there should be a set screw in the impeller holding it on the shaft.take the set screw out.then the impeller should come off.if it doesn't come off easily you need to heat the hub that the set screw was in.this expands the metal so that the impeller will come off..........there is no easy way to do this job........hope this helps,let me know..................
Posted on Jun 26, 2009
  • 1129 Answers
SOURCE: How do I clean the fuel line on troy bilt 5hp chipper vac?
unscrew the nut on the bottom of the carburetor and remove the float bowl it must be emptied and cleaned , debree and water gets into the bowl and blocks of fuel flow reinstall the bowl and start, some carbs don't have a float bowl requiring you to remove the gas tank and carb which is a more involved cleaning.
Posted on Jul 14, 2009
SOURCE: how do i put a troy-bilt tiller 3 hp.into free
The way to move without the motor running...
1.on each wheel pull pin in center of hub
2.push wheel closer to motor.
3.put pin back in to axle but not though hub
4.do the same steps to other wheel
now you can push tiller
Posted on Aug 05, 2009
rwvanlue
  • 486 Answers
SOURCE: Misplaced operation manual for Troy-Bilt Briggs
Straight 30w NOT 10w-30
prefer air-cooled engine oil from mower dealers or some auto supply stores have air cooled engine oil.
Posted on Nov 08, 2009
My Kohler Command 20 HP running fine, shut down, won't restart. How should I troubleshoot this problem?
check for fuel try starting fluid if it fires on that then you have spark if it does not then you have a spark problem and seeing the command engine has two coils check the safety switches on the mower side
Aug 11, 2012 | Garden
My briggs & Stratton won't start. Changed spark plug.
check for spark is there a low oil shut off and the oil level is a little low ?
Jul 01, 2012 | Troy-Bilt Chipper Shredder
Will not start
If you have a spark plug wrench take out the spark plug look at it if it is all wet engine is flooded with gas,dry it and clean it if it is dry its not getting gas, try putting in a new spark plug. is there gas in tank , is switch on, is gas turned off, is the tank full, is the gas old and stinky? has the tiller sat for months carb may be plugged check ,engine oil level, try a little shot of engine starting fluid or gas sprayed into carb needle valve in carb may be pluged, float in carb may be stuck. tap on carburetor good luck
Jan 31, 2011 | Troy-Bilt Garden
I have a 18 hp briggs and stratton engine that will not start
A few more things to check.
1. The oil level. If the oil level is low the oil level sensor will ground the ignition.
2. Check the wiring from the seat safety switch to make sure it is connected.
3. Follow the black wires from the ignition control module to make sure none of them are chaffing and do not have a chassis ground.
If you still have problems disconnect ONE lead from the oil level sensor and see if you have spark. Most of the time these oil level sensors are the common failure.
Kelly
Apr 29, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Misplaced operation manual for Troy-Bilt Briggs & Stratton Super Tomahawk Chipper/Shredder 8 HP Can it be downloaded? What kind of oil does the chipper use?
Oct 07, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Troy-bilt TBP6040 4-cycle stalls out after about 10 minutes. Started doing this the 2nd time I used it. After it stalls out it will not start until it completely cools off. Fresh fuel in it. Arrestor...
I have the same model from Troy-Bilt. I have only had it about 4 or 5 months. Mine has started using a LOT of oil. I noticed a significant increase in temperature compared to my old Husqvarna 2 cycle. Mine does not completely stall, but it does start to sputter when it gets hot. I am going to take mine back to Lowe's where I bought it. So far I am VERY unhappy with the TBP6040.
Aug 24, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Our Troy bilt lawn tractor wont start. It seems like a short
Unless something catastrophic has happen internally, fuel and spark are about all you need. If you are sure of the fuel supply, pull the spark plug lead and let it arc to ground so you can check ignition health. You should have a bright blue spark visible. If you do, then pull the plug and replace it; the insulator may be cracked and robbing some of the high voltage. If it still doesn't start, you may have flooded it and when this happens to me, I make sure no spilled gasoline is present but I then pull the plug and use a charcoal or fireplace lighter and place it in front of the sparkplug hole. It should pop and help exhaust the excess fuel.
Aug 14, 2009 | Troy Bilt 5.5hp Self Propelled Mower
I have a Troy-Bilt 31cc 2-Cycle Gas Powered that doesn't start
Coil bad or wire to coil bad. I tell everyone what Ill tell you,when it comes to small engines,troy bilt,poulan,weedeater brand all JUNK,JUNK JUNK! Theyre made cheap,not built to last,theyre throwaways. Carbs are made in china. If youre ever in walmart next time go back to the garden section and pick up a weedeater or poulan brand chainsaw or trimmer. Look at the package good and look at the factory life expactancy. Its not in months,not even days,but in hours. If I was you I would tell myself NO MORE! I would buy a dolmar or stihl,pay the extray,cause you wont be aggrevated in the long run. P.S. Dolmar offers a 100% coverage for ONE YEAR on all equipement.
Aug 10, 2009 | Troy-Bilt Garden
10 hp Troy Built chipper pull start frozen
If a branch was already being chipped when it ran out of gas...you must clear the hopper of any chunks of wood in it. Pull the plug wire and use a metal pry bar to dislodge any pieces of wood. when the flywheel runs free, put the plug wire back on and the choke on. Try it now!!!
Jun 14, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
May 17, 2009 | Briggs & Stratton Garden
Troy Bilt Walk Behind Chipper/Shredder/Vacuum 205cc Logo
176 people viewed this question
Top Troy Heavy Machinery Experts
Roland W VanLue
Roland W VanLue
Matt Olenzek
Matt Olenzek
Paul Sikkema
Paul Sikkema
Are you a Troy Heavy Machinery Expert? Answer questions, earn points and help others
