Question about Bugaboo Cameleon Stroller
FRAME DOESNT LOCK THE HANDLE - Bugaboo Cameleon Stroller
When bumping up stairs handle bar extends, and feels loose (handle bar is very wobbley)
The Bugaboo is not the ideal stroller for bumping up and down stairs, The reason being it's core design. Most stroller handles have two or more mounting points to the frame but most strollers have baby facing forward and facing the big bad world and not Mummy. The Bugaboo is very clever, the handle can be locked ether way and the seat face either way but the handle has only one point where it attaches to the frame and that point has to rotate and lock. To give you an idea of the forces involved a crow bar the length of the Bugaboo handle can pull six inch nails out of hard wood!
Unfortunately Bugaboo have not used the best material solutions in this critical handle lock. They use a plastic disk to move aluminum locking pins and they fail if you bump down to many stairs. This happened to our Bugaboo in New Zealand. I repaired ours and now I help others by making or sourcing the better quality parts to repair them. I use aluminum for the disk and stainless steel for the pins.
If you are lucky another to have a Bugaboo less then two years old and still have proof of purchase documents Bugaboo will replace the frame for you. If it's older you can buy a new frame for around $400 but this will also increase you resale value by around $200 when you sell it. Lastly you can repair it for around $100 a side depending on parts required, Click on my name and you'll find many posts on how to repair both the Handle lock and the Handle extension lever or wing-nut. macnutz_23.jpg
Nov 26, 2010 | Bugaboo Cameleon Jogger
My frame is crooked. how to fix?
Crooked? Bugaboo frames are very strong and it would take considerably force to bend any of the frame members. The Handle Lock and the Handle extension lever lock are another matter all together. They do fail making the frame loose and bendy. I have given detailed instruction on their repair in other posts. Click on my name and you'll find out lot's about your Bugaboo.
How do i put the chassis up and down
Push in the little white button on the frame handle and pull the 2 buttons on either side of the handle - if the frame doesnt fold doew gently move the handle a bit untul you hear a click then should fold
Jun 18, 2010 | Bugaboo Frog - Black Stroller
Bugaboo chameleon frame not locking into place
www.buggypitstop.co.uk are the only company that repair bugaboo handles.Highly recommended they will fix it at a faction of the price of a replacement handle
Feb 24, 2010 | Bugaboo Cameleon Jogger
How do you remove the inside paneling to fix a broken door handle?
4-Cylinder Engines
  1. Remove the screw in the door handle trim, slide the handle assembly forward, and out to access the lock rod clip. Release the clip, disconnect the door lock switch and remove the door opener handle assembly.
  2. Carefully pry off the cap(s) in the armrest pocket, then remove the screw(s).
  3. Carefully pry off the cap under the armrest and remove the screw.
  4. Using a suitable trim panel removal tool, unsnap the door panel from the door frame.
  5. Unplug the electrical connectors for the power windows, power mirror and courtesy light.
  6. Carefully lift the door panel up and away from the door frame.
  7. Installation is the reverse of the removal procedure.
V6 Engine
  2. Carefully unsnap the rear of the speaker grill, lift and pull back to release it and remove the grille.
  3. Remove the panel mounting screws located around the perimeter of the speaker.
  4. Remove the cap and screw in the pull pocket of the armrest.
  5. Slide the pocket back slightly to release the front hook, then lift up, detach the electrical connectors and remove the pocket assembly.
  6. Using a suitable trim panel removal tool, unsnap the door panel from the door frame.
  7. Carefully lift the door panel up and away from the door frame slightly and disconnect the speaker connector.
  8. Installation is the reverse of the removal procedure.
Oct 13, 2009 | 1999 Honda Odyssey
Bugaboo Frog Handle Bars Not Locking into place
Try to contact Bugaboo Service 1-800-460-2922 or serviceus@bugaboo.com
Jan 07, 2009 | Bugaboo Frog Stroller
Doorhandle forced when locked. now it will not open when unlocked
most likely the door frame is out of alignment due to the force of the weight.
you can try to open the door from the opposite side. push instead of pull.
if that doen't work, use a nail and hammer, remove the pins from the hinges pop open the door off the frame. (have someone braced the door before you push it.)
once you have it open check the alignment of the door frame, and realign it as necessary.
Oct 25, 2008 | Hardware & Accessories
Bissell 3595 handle release pedal spring(?) missing
I just fixed this on my Bissell PowerForce model #6594 vacuum myself. Woo Hoo for me. :-)
I called the local vacuum repair guy and he told me he'd repair it for me if I insisted but that since my machine only cost about $80 (a lot of money for me) it would not be worth the $40-$50 repair. I should just buy a new vacuum (from him I assume).
My machine works great so I sat down on the floor and after removing 5 screws and a little tinkering I got my machine apart. I had to take the brush and belt area off and then the upright part came off the base. Make sure you unplug your unit before working on it.
Next I could see where the Handle Release Pedal (HRP) on the bottom of the unit had been cracked. It's a molded piece that has a slight curve in it that allows it to spring back into position to hold the vacuum in the upright position or to keep the vacuum from going totally flat.
How it was installed I don't think they meant for it to be easily replaced but after using a screw driver on one side and a letter opener on the skinnier side I pried the molded houseing out from around the HRP just enough to let the it release. I did need a third hand for that part.
Aug 30, 2008 | Bissell 3522 PowerForce Bagged Upright...
Bertini M5 Shuttle
hi I think I could help I bought a bertini shuttle as well if you stand behind the pram on the right run your hand down the right side of the hood there is a push up lever there mine is grey ok you need to push the grey? lever but also on the left and right there is a black lever you must push up al together hope this helps good luck from debbie
Jan 09, 2008 | Bertini M5 - TS City Stroller
Main Chassis bar won't lock on one side
We had a similar problem, the right-hand hinge of the frame would not lock and the button was permanently down. What had happened was the handle extension switch housing had come unscrewed and slipped up the frame, causing a small spring to fall out. The lock switches each have a spring which pushes down on a rod inside the frame to lock the hinge. To access the spring, unscrew the handle extension housing and slide it up the aluminum frame. I replaced the missing spring and the frame works perfectly. If the problem is with the spring, this should work. Alternatively the problem may lie inside the lock switch housing, which contains a very simple mechanism which slides the lock rod up and down. This can be unscrewed as well. As far as I can tell, the actual hinge assembly itself is a sealed unit and can't be opened, but hopefully, you won't have to.
Good luck,
Ben
Aug 28, 2007 | Bugaboo Cameleon Jogger
Bugaboo Cameleon Stroller Logo
35 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
